Disclaimer : Yes, I'm pretty much a noob, untrained, knuckle busting, only changed the oil in previous vehicles non-mechanic.
That's got to change. Found all kinds of crap hack jobs done to the last truck at the dealer.
And I've fallen victim to the mod bug. been reading lots of threads here. Ordered too much already. Amsoil, Filtermags, tailgate assist, Carli Front diff guard, Factor 55 flatlink, etc... So:
Bought all the FilterMag products.
1 for the oil filter. Think I have this one covered, but I'd sure take any tips in case I'm missing anything.
1 for the outside bottom of the transmission pan. Didn't say it on their website before I bought it, but with the instructions it says placement may interfere with the operation of trans., relocate if problems. Has anyone else here installed one of these ? Any issues ? If no issues-where did you put it ?
And finally, 1 for each Diff. Looks fairly straightforward as to removing the diff covers, except for some brackets holding brake lines on the rear.
Smaller bracket looks like it's held on by a flat retaining nut. Larger bracket not so sure, and both brackets instead of having a bolt head facing out, have threads facing out. Can anyone who has been here and done this give a little guidance as to how to remove and replace correctly without screwing up parts (Which would probably be the most likely outcome of me diving in solo) ?
Thanks
PS : Cheers and Happy Friday !
