What is your favorite 4th Gen bumper?
Re: What is your favorite 4th Gen bumper?
Id like to see ram offer this one for a decent price
2012 Power Wagon, Thuren Control arms, Thuren Track bar, Thruen 2inch Coils, Thruen Overland shocks. 37x12.50x17 Toyo RTs, Locker Bypass
That appears to be a sexed up AEV bumper.Jbostick wrote:Id like to see ram offer this one for a decent price
TommyG wrote:That appears to be a sexed up AEV bumper.Jbostick wrote:Id like to see ram offer this one for a decent price
Looks like a spiced up rebel bumper to me.
- NovA ProspekT
Good catch! I forgot about the fairlead thing.Reloaderguy wrote:
The Thuren bumper does not currently fit a Power Wagon nor will it hold a winch. To make the bumper fit you have to cut the shackle gussets and weld in a fairlead mount. I know Don wants to make the existing bumper PW compatible but it may be some time before it happens.
I suppose you mean the gussets on the bumper have to be cut? What would that interfere with, the winch?
The styling for sure looks like the Rebel.olyelr wrote:TommyG wrote:That appears to be a sexed up AEV bumper.Jbostick wrote:Id like to see ram offer this one for a decent price
- Rodeoflyer
ADD is now offering bumpers for the PW with factory winch. Costly...but aren't they all?
http://www.addictivedesertdesigns.com/f ... ory-winch/
http://www.addictivedesertdesigns.com/2 ... %20Bumpers
Beware - Lists as:Rodeoflyer wrote:ADD is now offering bumpers for the PW with factory winch. Costly...but aren't they all?
*Powerwagon ONLY*
*Uses Factory Winch*
But:
**Winch Plate Limit is 10,500 lbs., use only winches at or under this approved pull rate to retain Bumper Warranty.
Looks like they took some styling cues directly from AEV with that bull bar and the two tow hook areas. But the sides and center are clearly Rebel inspired. It's the bumper we should have. The Rebel bumper belongs on the PW more than it belongs on the Rebel.olyelr wrote:Looks like a spiced up rebel bumper to me.
Why even buy that stupid bumper then? That's less than the factory winch is rated at. Also, it's a fugly bumper.Bill2014 wrote:Beware - Lists as:Rodeoflyer wrote:ADD is now offering bumpers for the PW with factory winch. Costly...but aren't they all?
*Powerwagon ONLY*
But:
Tube bumpers solve all of the above stated problems. And they are lighter, and make you go faster. And are super cheap if you make it yourself. The list goes on, but everybody already knows how sexy this is:
Needs more light bars.DamageWagon wrote:Tube bumpers solve all of the above stated problems. And they are lighter, and make you go faster. And are super cheap if you make it yourself. The list goes on, but everybody already knows how sexy this is:
There's room right above the tires there.
Most of the time, tube bumpers do nothing for me, aesthetics wise. At least on a new/stockish looking truck. The stock one or AEV have my vote as far as looks go.
What about chopping the lower portion of the stock bumper off (at desired angle(s)/height) and then adding in any needed support/skids etc? That has been running through my noggin for a while, but i have never looked much at it before.
I was thinking about cutting the bottom of mine off with a cut off wheel.
If I ever find that approach is a problem for me, mine will be getting the cutoff wheel treatment. I could do that and change my mind a few times for the cost of a fab'ed bumper.
There is a perfect line across the bottom of our front bumpers that I think would be easy to follow with the wheel. And should look clean afterward. Haven't measured it, but it looks to be about 2 inches to my memory.
Low_Sky wrote:If I ever find that approach is a problem for me, mine will be getting the cutoff wheel treatment. I could do that and change my mind a few times for the cost of a fab'ed bumper.
MikeKey wrote:There is a perfect line across the bottom of our front bumpers that I think would be easy to follow with the wheel. And should look clean afterward. Haven't measured it, but it looks to be about 2 inches to my memory.
Yes, yes. Then maybe add in some type of braced tube/skid right at the base of where the cut was made that would take a good solid hit from trying to push up over a rock or tree or Raptor.
Dude that's what the walrus teeth are for
The shackle mounts are gusseted and interfere with the winch cradle. It's a relatively easy production change from what Don said. He is designing a bolt in Fairlead. He measured my truck when he had it last but his business is booming so it's going to be a while.NovA ProspekT wrote:Good catch! I forgot about the fairlead thing.Reloaderguy wrote:
I have Newbumperitis and I'm not sure I'll wait.
A user here did a review of that bumper and it was not very pretty.Rodeoflyer wrote:ADD is now offering bumpers for the PW with factory winch. Costly...but aren't they all?
Here's a better shot showing the AEV bumper doesn't do much to improve the approach. And since it's designed for the diesel, it's also sticking out further than stock.
2018 RAM 2500 Power Wagon
I like mine.
2012 RAM Power Wagon
I like that one too juday!!
- 14PowerWaggy
stumbled across these when looking for something else in the pic thread... I believe this is the bumper he made for a PW?MikeKey wrote:Somewhere he made one for a PW. But I didn't dig far enough into his instagram. These are built to order.
Hammerballs
So I have been looking at bumpers on http://bumpersuperstore.com/c-960409-sh ... -2017.html simply because it was a good site to see a lot of different bumpers in one place. I have a 2016 Laramie PW. So far the Aluminess front bumper is at the top of my list because I don't have to relocate/re-orient my factory winch setup. I like that. I don't want to do that. As I was looking through the different bumpers I noticed some of the non-winch bumpers with the long light bar openings in the middle. They are usually lined up with the recovery hooks which usually line up with the main frame mounting brackets. After looking at my factory bumper with the winch behind it I notice that it really does tuck back there nicely even the roller fairleads. This got me wondering if one of these low profile non-winch bumpers with the large and long light bar openings might work? They actually look like they might bulge out more then our factory bumpers so it seems like there might be room unless there is some internal ribbing that would interfere with the factory winch mounting bracket. I'm sure others on here have had to look into this. Anybody?
http://bumpersuperstore.com/i-23181707- ... -2017.html
http://bumpersuperstore.com/i-23911115- ... -2016.html
Even this one I might be able to have a fab shop cut out that center pillar and mount a Hawes fairlead in its place. That cut out is perfectly in line with the stock recovery hooks which it re-uses. Our factory winch location is perfectly in line with the recovery hooks.
http://bumpersuperstore.com/i-20991693- ... -2017.html
2016 Laramie Power Wagon
