question on rr
w2dodge
question on rr
Post by w2dodge » Wed May 30, 2012 11:44 am
im prepping the rr for steps and new a coating,my question is do i weld shut this hole ? they both have it,factory rr..whats the purpose of it?
ldgregory
Site Admin
Site Admin
question on rr
Post by ldgregory » Wed May 30, 2012 11:50 am
Before you weld it shut, fill them with helium to make your truck lighter!!! :lol:
Seriously though, I'd close them. If you get water in them, you'll just start rusting from the inside out.
2023 Power Wagon
Previous Truck
AceMan
Site Admin
Site Admin
Re: question on rr
Post by AceMan » Wed May 30, 2012 11:54 am
ldgregory wrote:Before you weld it shut, fill them with helium to make your truck lighter!!! :lol:
Lol! Better gas mileage!
Transmitted via Carrier Pigeon v2 & TRS-80 mobile @2.4k baud.
Power Wagon Owner's Club #110
Black '06 PW QC
Image Image Image
w2dodge
Re: question on rr
Post by w2dodge » Wed May 30, 2012 11:57 am
lol....yeah thats what im gonna do weld them shut..dont understand why their there....they look like weepholes
Powerwagonmark
Re: question on rr
Post by Powerwagonmark » Wed May 30, 2012 11:59 am
Could be to release the heat when there welding it together.
2008 Dodge POWER WAGON
w2dodge
Re: question on rr
Post by w2dodge » Wed May 30, 2012 12:04 pm
if thats the reason then i will do that last...
06powerwagon06
Re: question on rr
Post by 06powerwagon06 » Wed May 30, 2012 12:14 pm
Is it on the top or the bottom of the rail? I would think it would be there to let any condensation weep out. If it's trapped in there they will rust from the inside out. If you weld them shut I would pour some old oil in them to stop any rusting. It will slosh around enough while driving to coat the inside of the rail. I left my rails open for now to see if they get filled up with crap or not. I figure I can always weld a cap on anytime.
Rausch Creek Spring '12
VA_Wagon Man
Re: question on rr
Post by VA_Wagon Man » Wed May 30, 2012 3:43 pm
They are there to let the condensation out. I'd leave them open, but do what you want. if you go in enough mud, it'll plug them up. :shock:
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
w2dodge
Re: question on rr
Post by w2dodge » Wed May 30, 2012 4:44 pm
yes there on bottom of the rail
ldgregory
Site Admin
Site Admin
question on rr
Post by ldgregory » Wed May 30, 2012 4:53 pm
Ahh. That changes things. From the pic it looked like they're on top. If they're on the bottom, you could leave them open as they'll be able to drain. But if they're plugged from the get go, then they wouldn't need to drain in the first place.
Either way would work. Personally, I'd close them and not have to worry after mudding that they have water in them and got plugged by mud or something.
2023 Power Wagon
Previous Truck
w2dodge
Re: question on rr
Post by w2dodge » Wed May 30, 2012 4:58 pm
i think i will plug them also,after i alter them a bit and put another pass around the joints
GunniPWguy
Re: question on rr
Post by GunniPWguy » Wed May 30, 2012 5:44 pm
VA_Wagon Man wrote:They are there to let the condensation out. I'd leave them open, but do what you want. if you go in enough mud, it'll plug them up. :shock:
what he said. ^^
Re: question on rr
Post by RustyPW » Thu May 31, 2012 5:46 am
They're weep holes. Don't close them. The inside of the tubing needs to breath. When you fab pipe and tubing. You always leave an end open.
w2dodge
Re: question on rr
Post by w2dodge » Thu May 31, 2012 7:37 am
im going to hone them a bit with stone and drill,there is some rust visible.... maybe il pour some fluid film in them..and leave at that
