"Frankenwagon" short and sweet.
Re:
I ran mine tight, I think I set it at .004 just because I did a lot of low speed rock crawling and wanted to have little to no slop and my pre-load was set tight too. Perfect for low speed high horsepower rock beatings, but it WILL heat up the highway HOT.... For highway use/all around use, I would do what you are doing to keep the heat down. Dep. on what you are doing with the rig... If you break them in correctly, they will be bullet proof.. Run a 80w90 first for about 1000 miles while driving at variable speeds, and stop and let those gears cool down (they will run hot for the first 500 miles) try not to do a highway run to break them in (not good) then at 1000 miles I swapped the fluid to 140weight.
I have to swap my fluid out in both my diffs every 5th trail ride because the oil gets black really fast. A buddy of mine said that because my diffs are set tight for strength, and when you beat on them on the rocks, they heat up fast, and with the friction load and shock loads it burns my fluid really fast.... Maybe I ought to swap to a synthetic oil... But I figure keep with the cheap gear oil because I swap the fluid so often... It has held up for 3 years now, so I figure stick with what I am doing.
Keep up the pics,,, I am interested to see how you set up the Truss on the axle:) Great job....
Re: "Saggin wagon" short and sweet.
Gunna be really simple like this just an upper
Tho. I always run full synthetic I think I will do 75w90 for the first 1000 miles like you said and maybe add Lucois oil stabilizer in it also then dump it and run 75 w140 again. Again with stabilizer. I don't mind the gear clap but I do have a feeling a bit looser will be better for
Me. And the way I drive lol thanks for the advice about the highway and varying ranges I will for sure do that.
Sent from Canada
Sent from Canada
ya I really want to do the lower but this swap to the 11.5 I'm losing enough ground clearance sogun45boat wrote:OK!!!!!!! That is PIMP.... THat will look and perform flawlessly.
I think I'll be fine with the top I'm pretty sure that falls right on the breather tube line so I may have to bung a new one in.
Sent from Canada
Hmmm? I guess grind this down a bit so she fits lol
Sent from Canada
Sent from Canada
welded tubes tonight
Sent from Canada
Sent from Canada
started on the truss tonight. Shits time consuming!!!!
Sent from Canada
Sent from Canada
That's .250" wall 2" in case anyone wants to know. Surprised the bender actually bent it.
Sent from Canada
Sent from Canada
Well THAT won't be the weak link. Haha
That's what I got as the main tube on my Carli front bumper.2wagons1driveway wrote:That's .250" wall 2" in case anyone wants to know. Surprised the bender actually bent it.
Sent from Canada
She's Deffinately hefty. Was hoping to get it tacked and to my buddies shop where my "big mig" is but not sure that's going to happen as the 5.13's are getting put in the front tonight/ tomorrow
Sent from Canada
Sent from Canada
- JBM Power Wagon
You have been a busy guy Lee, lots of work to get this all done!!!!
So much shit to do still jbm. So much shit lol thankfully it looks like I won't have to spend anymore dough as most everything is purchased and waiting maybe a rear driveshaft modification but I'm hoping I can get away with just chopping some splines on the old shaft :/ well see...
Sent from Canada
Sent from Canada
Re:
He needs his truck so he can't waste any time. I know that one well. Looks good 2wags.
ya man did another pattern after I installed locker again set up bulkhead /copper line was a pain but is in and looks good working on upper truss still. Set backlash to .008"nts007 wrote:He needs his truck so he can't waste any time. I know that one well. Looks good 2wags.
Sent from Canada
new gears in front. Had to shave down the adjuster lock like the rear end cause these gears are so thick.
Sent from Canada
Sent from Canada
Re:
Pulling some good patterns out of those gears man, nice work!
lol no I drank beer while a friend did this at his shop! I didn't have the time to leave it on the hoist for the day so I figured just pay him to do it and he's done a bunch of aam rebuilds so fingers crossed it seems much quieter except he said the new had shaft has a weird dead spot in the forward cardan joint. So I'm not sure how to deal with it that must be why it's vibrating at 60+ mph since I installed it. Guess I'm sending it back next week.Colibri wrote:Pulling some good patterns out of those gears man, nice work!
Sent from Canada
Re:
I have a dead spot too. 15-20°. Always have2wagons1driveway wrote:lol no I drank beer while a friend did this at his shop! I didn't have the time to leave it on the hoist for the day so I figured just pay him to do it and he's done a bunch of aam rebuilds so fingers crossed it seems much quieter except he said the new had shaft has a weird dead spot in the forward cardan joint. So I'm not sure how to deal with it that must be why it's vibrating at 60+ mph since I installed it. Guess I'm sending it back next week.Colibri wrote:Pulling some good patterns out of those gears man, nice work!
Sent from Canada
I don't think that's the vibration. More likely vibration in the shaft. Maybe get it balanced locally. Only will charge u 30-40 bucks if it's good. If you're still chasing it down
actually Jess at HAD shafts said he'd pay for shipping back and have a look at it. I ran the truck this morning with hubs locked and front shaft spinning new gears and bearings and no more crazy bad noises from front. But like 80-100km high speed driveline vibe from right under my feet since I put this shaft in. Maybe it's damaged or something or a new Cardon is bad well see I am sending it away hopefully this week is ups come to my shop tomorrow etcnts007 wrote:I have a dead spot too. 15-20°. Always have2wagons1driveway wrote:lol no I drank beer while a friend did this at his shop! I didn't have the time to leave it on the hoist for the day so I figured just pay him to do it and he's done a bunch of aam rebuilds so fingers crossed it seems much quieter except he said the new had shaft has a weird dead spot in the forward cardan joint. So I'm not sure how to deal with it that must be why it's vibrating at 60+ mph since I installed it. Guess I'm sending it back next week.Colibri wrote:Pulling some good patterns out of those gears man, nice work!
Sent from Canada
Sent from Canada
I Deffinatly feel a super weird spot in the forward cardan joint it does have a step to it when rotating and the rear joint ford not have that so either there's a bad spot in the locating ball or something hopefully Jess can figure it out ASAP and get it back to me before my new rear end goes in.
Sent from Canada
Sent from Canada
Re:
Hope he gets that back to you asap and in good shape man! How's the rear truss coming? That axles gonna be a beast!
You gonna be going to Moab Lee? Now that you had your mind blown? lol
Re:
If you're feeling it in your feet it's the Cardon. And it will be bad at exactly those speeds. Been there. There should be no "step" in the joint. I know exactly the feel you are describing. Jack the front and then turn the front driveshaft. Wait you have free Spin. Slowly rotate the shaft from the front joint. Not the shaft itself. Hand on the pinion. Watched the shaft. If you see it "bump" on that spot get it pulled. It will over time damage pinion seal. I could go on bout that front shaft. I'm on my 3rd....but this one is holding good.2wagons1driveway wrote:I Deffinatly feel a super weird spot in the forward cardan joint it does have a step to it when rotating and the rear joint ford not have that so either there's a bad spot in the locating ball or something hopefully Jess can figure it out ASAP and get it back to me before my new rear end goes in.
Sent from Canada
