2015powerwagon
Post
by 2015powerwagon » Sun Apr 19, 2015 8:41 pm
Finally got around to getting my leveling kit installed , after mths of looking for a manufacture of a kit for the 2015 pw I ended up getting a 1.5" kit custom made for my pw by truxxx.com . very good quality part,s before level truck measured to the top of the wheel wells was 44" back , 41" front , after the level kit its now 44" rear and 43" front . sits perfect with still a minor rake that I wanted for payload . Boss air bags are going in soon . Got 100 plus kms on the kit so far truck rides as smooth as stock and handles great .
before kit
after level
Install was simple with proper tools had to disconnect sway bar end links , trac bar bolt , and shocks . use to jack to evenly lower the front axle a buddy helps for this , install the spacers and shock extensions .
some flexin after the install today
bvpw
Post
by bvpw » Sun Apr 19, 2015 8:45 pm
I actually just asked this question. Could you send me a part number
Maximum Steel 2015 slt
2015powerwagon
Post
by 2015powerwagon » Sun Apr 19, 2015 8:53 pm
There isn't exactly a part number they built this kit specifically by my request , don't go over 1.5" or you will with the truck nose high . this is why I had it custom made in 1.5" most kits for the regular 2500 rams only come in 2" and 2.5" since the pw already had 2" of lift over the regular 2500 ram u will most likely have issues . e-mail them at
sales@truxxx.com they will hook you up . here is there info
Robyn Andrew
USA Sales Manager
Truxxx.com
sales@truxxx.com
Toll Free: 855-668-0541
bvpw
Post
by bvpw » Sun Apr 19, 2015 9:27 pm
Ok I will do that thanks a bunch.
Post
by 04Ram2500Hemi » Sun Apr 19, 2015 10:55 pm
Are you planning on bigger tires anytime soon with the leveling kit?
PS- love that blue color, it's really sharp!
Post
by adeluca73 » Sun Apr 19, 2015 11:41 pm
Any change in drive, suspension travel, articulation, caster, toe-in, alignment ? Did you have an alignment done after?
2015powerwagon
Post
by 2015powerwagon » Mon Apr 20, 2015 6:32 pm
I have not taken the truck for an alignment as of yet , it drives perfectly fine honestly don't notice any difference . I think the 1.5" is just enough where I still have 1" of rake and it does not make a huge difference where it would need to be realigned , if this were a cv axel and not a solid axle I would get it aligned right away . but in saying that I am getting a set of 35x12.5x17 bfg ko2's soon and I will be putting there on an aftermarket wheel ( was going to stick them on the stock wheels but the stock wheels are only 8" wide and bfg recommends a 8.5-11" wheel for these tires ) , while I am at the garage I am planning on getting them to check the alignment just to be safe .
MSCH2112
Post
by MSCH2112 » Mon Apr 20, 2015 7:44 pm
i don't like leveling kits, but that is a great looking kit you have allowing for a slight rake.
mike
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
Post
by adeluca73 » Mon Apr 20, 2015 11:13 pm
MSCH2112 wrote:i don't like leveling kits, but that is a great looking kit you have allowing for a slight rake.
^^^WHY?^^^
Post
by olyelr » Mon Apr 20, 2015 11:35 pm
With the cross over steering, there is really no alignment needed with a leveling kit. The caster is going to be off a bit, but there is not really any way to adjust that unless you get aftermarket radius arms (or some type of drop bracket on the axle that adjusts it (like AEV's kit). Your steering wheel should have been off center a little though after the level. Did you have to recenter it?
2015powerwagon wrote:... I am getting a set of 35x12.5x17 bfg ko2's soon and I will be putting there on an aftermarket wheel ( was going to stick them on the stock wheels but the stock wheels are only 8" wide and bfg recommends a 8.5-11" wheel for these tires )
I have been running 35x12.5x17 BFG KM2's on my stock Jeep wheels which are only 7.5" wide and have had absolutely no issues. They are wearing perfectly. But, most large tire shops (like Discount Tire) will not mount them due to all the legal bullshit. I had to find a smaller local type place to have them mounted up.
2015powerwagon
Post
by 2015powerwagon » Tue Apr 21, 2015 3:55 pm
I did not re-centre the steering wheel , never found it to be off really .
TrueBlue13PW
Post
by TrueBlue13PW » Tue Apr 21, 2015 6:02 pm
mike
I agree with you 100% I want my truck to have a rake. But I use my truck to haul and pull quite a bit and don't want it to look like it's dropping a load with a little weight in the back. I don't like the look of a level truck but respect the people that do. Glad the op is happy with the kit and with his truck.
Op I'm running 315/70/17s on my stock rims. I bought and had them installed at discount tire. They didn't say a word about the rims being too small. If they do just tell them you have power wagon rims that have the internal bead lock. Most of the guys at tire shops won't have clue what you're talking about and will say yeah they'll be ok then.
MSCH2112
Post
by MSCH2112 » Wed Apr 22, 2015 7:41 pm
TrueBlue13PW wrote:MSCH2112 wrote:i don't like leveling kits, but that is a great looking kit you have allowing for a slight rake.
mike
what he says! does anyone know how much articulation is lost with leveling kits?
mike
Gooseneck
2016 Volvo XC90
Post
by olyelr » Wed Apr 22, 2015 10:48 pm
mike
[/quote]
As long as longer shocks are installed or extension brackets are used there really isn't any loss in articulation to speak of.
Jnallison
Post
by Jnallison » Wed Apr 22, 2015 11:06 pm
I like it and I final;ly got the 1" rear kit on from Traxxda. Cured my problem of having it nose high with a trailer. I took pics while I installed it, one of these days that build thread will start. Thanks again for the link to the spacers.
Hellboy
Post
by Hellboy » Sun Jul 19, 2015 1:36 pm
How is the 2.5 kit working for you? Any issues? I am getting the run around on weather I can level my 15 pw.
PurdellMGP
Post
by PurdellMGP » Thu Aug 13, 2015 10:52 pm
How are you liking your Traxda kits? I've been thinking of installing that kit on my truck, only company I found that does front and rear for the newer Rams.
Post
by olyelr » Sat Aug 15, 2015 9:07 am
PurdellMGP wrote:How are you liking your Traxda kits? I've been thinking of installing that kit on my truck, only company I found that does front and rear for the newer Rams.
If you want more of an entire kit, and spend a lot more, yiu could get the aev lift. It is basicaly just a bunch of spacers and drop brackets and new shocks.
TruckBoatTruck
Post
by TruckBoatTruck » Tue Sep 08, 2015 3:32 pm
Hey guys been following the forum for awhile and have recently been considering leveling my 2015 PW. I Really like jnalinsons 2.5" with the 1" in the rear. I have been looking at Traxda website and came across this kit that would really be nice if it would work in my truck.
http://traxda.com/dodge-lift-and-leveli ... -rear.html
Just wanted too see what you guys have to say about it. If anything I will do the 2.5 and 1 in the rear but this kit looks like it will make the truck look great with 37's on it, which is my ultimate goal.
14PowerWaggy
Post
by 14PowerWaggy » Wed Sep 09, 2015 2:31 pm
TruckBoatTruck wrote:Hey guys been following the forum for awhile and have recently been considering leveling my 2015 PW. I Really like jnalinsons 2.5" with the 1" in the rear. I have been looking at Traxda website and came across this kit that would really be nice if it would work in my truck.
I have the 1" rear spacers, brand new in the box... Never used... I will sell them to you for $80 and free shipping if you are in the United States... PM me if interested...
Jnallison
Post
by Jnallison » Wed Sep 09, 2015 8:00 pm
I have no issues at all with articulation, tire wear or any other BS. The only thing I can feel is a very slight amount of bump steer, again very slight. Mine sat to level so I added the 1" in the rear and like it. I don't have any issues loading the truck down. My goal is also to run some 37" tires eventually.
Jnallison
Post
by Jnallison » Wed Sep 09, 2015 8:05 pm
I am not sure I would do 3.5" without a more complete kit. I have been installing lilfts for years on numerous different types of vehicles and never go beyond 3" without a complete kit. And that is usually for a pavement truck. I think that if you went this high you would also need shocks and its hard to say how the front arms would take it. I dont think a 3.5" shock extension is strong enough. It seems that it would move the axle backwards with that much, but I could be wrong. FWIW, my truck is capable of going anywhere I have ever been comfortable to take it with what it has and I am not afraid of much. I have a history of rock crawling with some built rigs and buggies. The 37' tires should fit nicely once I have the front bumper built. Remember this is only my opinion and I am sure someone out there is running it without issue, but I doubt the truck with it is being built for hard trail use.
TruckBoatTruck
Post
by TruckBoatTruck » Wed Sep 09, 2015 11:46 pm
Jnallison wrote:TruckBoatTruck wrote:Hey guys been following the forum for awhile and have recently been considering leveling my 2015 PW. I Really like jnalinsons 2.5" with the 1" in the rear. I have been looking at Traxda website and came across this kit that would really be nice if it would work in my truck.
I trust what you have to say, I figured that was a very large kit for the little it offers. Do you recommend your level kit with 35's? I would be using this for semi hard use and need something that can get me home from my hunting property regularly. I don't want something that can't take what I need to throw and it and even more. Thanks for your help.
Jnallison
Post
by Jnallison » Thu Sep 10, 2015 12:29 am
Yeah, the truxx kit is fine. I have run it in Moab on some tough trails and use my truck for daily driving/towing. The traxda in the rear has never given me an issue either. If it was junk, I wouldn't run it and the shock extension is the secret to keeping the articulation. I think some people put way to much thought into things sometimes and over think or over engineer in their mind what works and what doesn't. I am normal guy that likes to play hard and kill animals to. I only buy or use stuff that works and make sure I install it correctly. If it doesn't do as it is supposed to, I will immediately take it off and send it back and shop for a better product. I have no reservations saying these 2 items with 35" tires will fit the bill for what you want to do and more. BTW, there is no shock extension in the rear for the 1" spacer. I just live with the small loss of articulation (1")in sacrifice for a level truck when the bed is loaded or a trailer is hooked up. Never noticed a difference off road.
sunny1881
Post
by sunny1881 » Tue Apr 05, 2016 11:25 pm
I have truxxx 1.5" leveling kit on my 2015 PW and front springs are bowing a lot. Im sure others have had this problem... is castor just way off now and can be adjusted/aligned back to normal? If not how is this fixed?
