2012 with bds long arm lift just finished 01/07/13
Re: 2012 with bds long arm lift just finished 01/07/13
Rotfl ya that would Deffinately help!!TwinStick wrote:LOL, you need one of these: http://www.northerntool.com/shop/tools/ ... _200360239
or
http://www.northerntool.com/shop/tools/ ... _200617743
or
http://www.northerntool.com/shop/tools/ ... _200581023
You gonna coat the shiny aluminum with anything to prevent corrosion ?
- Stickman
Damn those look sexy. The whole thing looks sexy. That last pic of the front with it on the ground looks badass, those rims look good. Did they increase the ride height any? Or is that just with a full charge in them? Looks like it's sitting a little higher, or maybe that's just me.
You're making me want to do all of this to mine and make it look like it's twin.
I'm heating from skydram that I don't really have to he says the triple plate bilstein coating works well aha isn't corrosion he showed me a pic of his Truck which lives in michigan after 3 years their still shining!TwinStick wrote:Looks awesome !
I think they did alittle bit ! Only have 90psi of air pressure in them now just to drive it around the shop and my front yard until new Thuren coils come and brake lines so I can actually use this insane amount of travel without my coils saying good bye and taking the brake lines with them! Also have to chop my exhaust and lower it so the driveshaft can actually articulate to the full width of the Tavel now too!Stickman wrote:Damn those look sexy. The whole thing looks sexy. That last pic of the front with it on the ground looks badass, those rims look good. Did they increase the ride height any? Or is that just with a full charge in them? Looks like it's sitting a little higher, or maybe that's just me.You're making me want to do all of this to mine and make it look like it's twin.
Ps I think the bilsteins are a steal resi! :pTwinStick wrote:Looks awesome !
Very nice. I greased the bolt before I installed it (makes for an easier install and quieter, but not cleaner lol) then greased them once mounted. Made them move easier. Enjoy!
Truck looks awesome. I have the 2010, same color. I'm ordering the BDS lift today and have a quick question for you. I haven't seen an aftermarket steering stabilizer in your photos. Did I miss it or was there no issue with the lift and tires affecting the driving/handling of the truck? I don't want to purchase one at the moment if it's not necessary and the drivability is unaffected. Also, what did you use for spray/paint your grill and body? Was it LineX or just bedliner in a can that you can buy at your local store. Thanks.
- Mr.Smith
X2...this is what I also did for installation.05PWrockcrawler wrote:Very nice. I greased the bolt before I installed it (makes for an easier install and quieter, but not cleaner lol) then greased them once mounted. Made them move easier. Enjoy!
Got a Carli low mount!! Drive ability was fine with stock one but I heard the Carli one is better so I tried it and I've been liking it so far!! If you could afford line x I would go with them! But ya I used duplicolor bed armour for the side of the truck and for the grill I used another smoother bed liner. And then a flat black plastic acrylic over top to give it the same color as the flares which are also done in bed linerslimstick wrote:Truck looks awesome. I have the 2010, same color. I'm ordering the BDS lift today and have a quick question for you. I haven't seen an aftermarket steering stabilizer in your photos. Did I miss it or was there no issue with the lift and tires affecting the driving/handling of the truck? I don't want to purchase one at the moment if it's not necessary and the drivability is unaffected. Also, what did you use for spray/paint your grill and body? Was it LineX or just bedliner in a can that you can buy at your local store. Thanks.
Okay so they can get a few pumps of grease after being installed! And grease the centre section of the bolt also??Mr.Smith wrote:X2...this is what I also did for installation.05PWrockcrawler wrote:Very nice. I greased the bolt before I installed it (makes for an easier install and quieter, but not cleaner lol) then greased them once mounted. Made them move easier. Enjoy!
Thanks for the reply. Yeah, found a local LineX shop that will do the grill for a $100 and the bumpers for $150 each if I remove and bring them in so will more than likely go that route. Noticed you left your rear bumper in chrome...I'm considering doing the same since I have chrome exhaust tips but would really like the truck to match up all the way around so might consider shortening the tips/exhaust to further under the truck.2wagons1driveway wrote:Got a Carli low mount!! Drive ability was fine with stock one but I heard the Carli one is better so I tried it and I've been liking it so far!! If you could afford line x I would go with them! But ya I used duplicolor bed armour for the side of the truck and for the grill I used another smoother bed liner. And then a flat black plastic acrylic over top to give it the same color as the flares which are also done in bed linerslimstick wrote:Truck looks awesome. I have the 2010, same color. I'm ordering the BDS lift today and have a quick question for you. I haven't seen an aftermarket steering stabilizer in your photos. Did I miss it or was there no issue with the lift and tires affecting the driving/handling of the truck? I don't want to purchase one at the moment if it's not necessary and the drivability is unaffected. Also, what did you use for spray/paint your grill and body? Was it LineX or just bedliner in a can that you can buy at your local store. Thanks.
That's correct sir. Been working good like that for me and I actually took it apart 2 days later to change holes and it was very easy. Another tip to adjust it is a small bottle jack between the rear spring and body and just jack up until hole lines up and insert bolt instead of fighting it. Good luck.2wagons1driveway wrote:Okay so they can get a few pumps of grease after being installed! And grease the centre section of the bolt also??Mr.Smith wrote:X2...this is what I also did for installation.05PWrockcrawler wrote:Very nice. I greased the bolt before I installed it (makes for an easier install and quieter, but not cleaner lol) then greased them once mounted. Made them move easier. Enjoy!
Sweet! Sounds good thanks 05.05PWrockcrawler wrote:That's correct sir. Been working good like that for me and I actually took it apart 2 days later to change holes and it was very easy. Another tip to adjust it is a small bottle jack between the rear spring and body and just jack up until hole lines up and insert bolt instead of fighting it. Good luck.2wagons1driveway wrote:Okay so they can get a few pumps of grease after being installed! And grease the centre section of the bolt also??Mr.Smith wrote: X2...this is what I also did for installation.
I wanted to do the rear also but I think I'm just going to wait it looks like way more of a pain then the front to remove and I'll probably have it replaced with a custom fab'd one that has room for a fairlead and still leaves good space between the d ring mounts and the pdc's cause I know the d ring mounts set the pdc's off all the time on the smittybilt rear bumpers which would be annoying and pointless to keep themslimstick wrote:Thanks for the reply. Yeah, found a local LineX shop that will do the grill for a $100 and the bumpers for $150 each if I remove and bring them in so will more than likely go that route. Noticed you left your rear bumper in chrome...I'm considering doing the same since I have chrome exhaust tips but would really like the truck to match up all the way around so might consider shortening the tips/exhaust to further under the truck.2wagons1driveway wrote:Got a Carli low mount!! Drive ability was fine with stock one but I heard the Carli one is better so I tried it and I've been liking it so far!! If you could afford line x I would go with them! But ya I used duplicolor bed armour for the side of the truck and for the grill I used another smoother bed liner. And then a flat black plastic acrylic over top to give it the same color as the flares which are also done in bed linerslimstick wrote:Truck looks awesome. I have the 2010, same color. I'm ordering the BDS lift today and have a quick question for you. I haven't seen an aftermarket steering stabilizer in your photos. Did I miss it or was there no issue with the lift and tires affecting the driving/handling of the truck? I don't want to purchase one at the moment if it's not necessary and the drivability is unaffected. Also, what did you use for spray/paint your grill and body? Was it LineX or just bedliner in a can that you can buy at your local store. Thanks.
I haven't put any nitro in these shocks just shop air pressure I'm very impressed already their eating speed bumps I agree with everyone's said about Carli feels firm but the faster you hit something the smoother it is!!
Nitro tank-bit the bullet and just bought one yesterday.
Also installed my lengthened driveshaft and greased the hidden zerk! Marked it with some paint to help find it. Damn it felt good taking that spacer out!!
That's right I painted it red!! Lol it's what I had in stock....matches the shackles lol
also cut and lowered the exhaust for the extended travel shocks and lower driveshaft angle now. Found some sweet exhaust clamps in my tool box from
When I worked at Audi that's fit the hemi exhaust perfect literally chopped twice with a sawzall installed these couplings and lowered it approx 3/4" -1" nice and tight no leaks way cheaper then getting a new exhaust too!! waiting on ss brake lines now and new carli diff cover to complete the front end then move to the back install shackles remove overload leafs etc! Then mod the skid plates again.
Welded in the limit straps too waiting on Thuren coils which will be here today!
So if anyone's doing a lengthened driveshaft or exhaust id suggest just getting your hands on a pair of those clamps makes life super easy and much cheaper then buying a replacement exhaust or piece to install.
