PSC steering pump box and hydraulic assist please help
- Powerwagonmark
Hey guys I was wondering if you could help me out my steering box crapped out on me and my pump crapped out I need a new steering box and pump while I'm there I figured I would do the PSC hydraulic assist I know while Whitey black and a few others have this mod on the power wagons already and I was just wondering how you guys like it what part numbers I should order any questions I should I ask PSCand any other info would be greatly appreciated thanks 2008 power Wagon with a 4 inch BDS long armkit
2008 Dodge POWER WAGON
Re: PSC steering pump box and hydraulic assist please help
- whitey
PSC has been pretty good for me. No problem in years. I recommend getting a 2nd radiator in line with the stock radiator. I also use royal purple fluid. Placement of the ram was a really hard decision for me. It was originally attached to the drivers side but I kept making contact between the ram brackets on the drivers knuckle and the trac bar bracket. so I switched to passenger knuckle even though its really hard to protect offroad. I think you will be amazed at how strong the steering will be.
Call DOR that's where I got my new gearbox and PSC hydro assist and pitman arm.
- Powerwagonmark
Thanks for the replys guys. Whitey could you post up a couple pics of your hydro set up. Thanks
- whitey
jsut saw your question. I'll get them on tonight.
- whitey
My first hydro assist system below. the brackets on the drivers side knuckle made strong contact with the trac bar bracket when offroad.
Hope this helps.
- whitey
I'll try to get pics of how it all looks now. I had to bend my axle skid plate this weekend so I should be able to get a clear shot now.
How does the setup with the black ram work. I like how it's mounted higher up. Can you get a better pic of the mounting point on the drivers side. I have a PSC kit but haven't mounted mine yet. Thanks.
- Powerwagonmark
Hey whitey could you post up some pics of your setup with it on the passenger side. Thanks
- whitey
I'll try to get some pics tonight after I leave work
- Powerwagonmark
Thanks a lot Whitey
- Powerwagonmark
Hey whitey I need those pics ASAP the guy installing my hydro is having some problems getiing full lock left. Thanks
I would like to see the pics also. Need to mount mine real soon. Thanks
