2010 Improvements
Re: 2010 Improvements
I beat on mine will. Every day. The bars have held. They are pretty strong. I still want to upgrade but not till these ones go
That's good to know
Finally changed the steering out. Broke off the stud in the pitman arm, drilled it out, little heat and persuasion, self alignment, drives like a brand new one now.
Now if I could figure out the abs light....
Well shit.... Went to pull in 4wd and shifter is loose as a swinging dick. Raining so I'll get under tomorrow morning and figure out what came apart. Something in the linkage, can slap it around from 4lo to 4hi with zero resistance.
Yep. This is a POS...one bushing gone, almost lost the linkage.
Ordered these parts today. Thanks man. That stock bushing bullshitis for the birds. I tried because local auto parts store had the bushings but never could get one in and messed it all up trying.
Son of a bitch. I can't believe how easy it is to shift the transfer case now! 2hi, 4hi, 4lo with two fingers. Thanks Colibri !!
^^^^^^^^ this
How's the steering holding up?
That is AWESOME!!!!!! can I make a quick possible recommendation If it is even possible.. Is there a way to install that rod on the other side of the shifter levers? I am saying this out of experience, but when I blew a front Driveshaft rear assembly one day on the trail, it took out my entire shifter assembly, bent the levers, and was soo close to taking out my T-case that that picture shows. When it happened I thought to myself "thank god that lever was a cheap metal/plastic assembly" and it was able to "give" With the pics I see it is VERY close to the D-shaft and when it pops, it will not "give' as well as the factory unit. Is there a way to put it on the other side? Jus thinking outside the box for when you are balls deep on the throttle, bouncing off a rock, and your D-shaft decides to shatter;)
if its possible to put on the other side for more clearance away from the D-shaft,,,,,, I might just upgrade to this bad ass shifter rod....
Great find Colibri!!!!!!!!!!
I think it would fit on the other side probably, I welded in a front driveshaft safety hoop on my truck to avoid that very problem though.
Just posted this in marketplace. FORSALE $17,000.00
Warn wireless winch remote
Amsteel synthetic winch rope
Hawk SD brake pads (went through set, now running EBC Yellowstuff)
Kenwood full speaker replacement
Brake and backup lights on switches
myoung smartbar bypass kit
Thuren Control Arms
Thuren 3" coils
Thuren Trac Bar
Thuren rear shackles
37x12.5 Hankook Dynapro MT's
El cheapo LED reverse light
Diablo Intune w/Hemifever Tune
Amsoil front and rear differential oil with the GP101 Filtermags
Thuren Custom King 2.5" Stage 3 up front with Boogie Rated Bump Stops, Stage 2 shorties with piggybacks in the rear (replaced Rancho 9000's)
Spicer axle U Joints
Dynatrac HD ball joints
Thuren Control Arms
Thuren 3" coils
Thuren Trac Bar
Sold, bought it back and now for sale again, same price. Brand new Thuren control arms and Trac Bar.
- Low_Sky
On one of the other truck forums a guy was showing off his new Thuren kit. His “installer” bolted the driver side e-brake bracket to the rear diff like some kind of cosmetic/vanity tag.
It’s amazing we haven’t devolved to living in trees and throwing poop at each other yet.
This thing it built offset, I wonder the fuck why that is? Working on trucks for a living and can't do any better!?
vie ... =13&t=2333
Low_Sky wrote:On one of the other truck forums a guy was showing off his new Thuren kit. His “installer” bolted the driver side e-brake bracket to the rear diff like some kind of cosmetic/vanity tag.
vie ... =13&t=2333
And, lets add some grease between the frame and joint so no matter how much you tighten it, it will still move around...
vie ... =13&t=2333
vie ... =13&t=2333
This is no good, that surface and the frame as got to be degreased so it can bite.
vie ... =13&t=2333
vie ... =13&t=2333
Well at least you have free new parts to work with
True but damn. Scarey, thinking about some of the folks on here letting other people install their stuff. I do my own alignment also. They had the cam bolts all jacked up. One had the mark pointing straight down, one straight up. I get the distance is the same but come on now...
vie ... =13&t=2333
vie ... =13&t=2333
Got the arms done on passenger side. Will finish and alignment next.
How many arms was installed backwards?
Only the uppers. They were installed with the offset towards the tire instead of away. I can just flip them in place. I'm pulling the Trac bar also to make sure it's the proper length and jamb nut is tight as hell. Don't trust any of it now until I go through it all.RustyPW wrote:How many arms was installed backwards?
vie ... =13&t=2333
