PSC steering pump box and hydraulic assist please help
Powerwagonmark
Post by Powerwagonmark » Mon Jun 10, 2013 2:50 pm
Hey guys I was wondering if you could help me out my steering box crapped out on me and my pump crapped out I need a new steering box and pump while I'm there I figured I would do the PSC hydraulic assist I know while Whitey black and a few others have this mod on the power wagons already and I was just wondering how you guys like it what part numbers I should order any questions I should I ask PSCand any other info would be greatly appreciated thanks 2008 power Wagon with a 4 inch BDS long armkit
2008 Dodge POWER WAGON
Re: PSC steering pump box and hydraulic assist please help
Post by RustyPW » Tue Jun 11, 2013 12:45 am
whitey
Post by whitey » Tue Jun 18, 2013 10:04 pm
PSC has been pretty good for me. No problem in years. I recommend getting a 2nd radiator in line with the stock radiator. I also use royal purple fluid. Placement of the ram was a really hard decision for me. It was originally attached to the drivers side but I kept making contact between the ram brackets on the drivers knuckle and the trac bar bracket. so I switched to passenger knuckle even though its really hard to protect offroad. I think you will be amazed at how strong the steering will be.
Post by 05PWrockcrawler » Wed Jun 19, 2013 2:18 pm
Call DOR that's where I got my new gearbox and PSC hydro assist and pitman arm.
Powerwagonmark
Post by Powerwagonmark » Sat Jun 22, 2013 9:59 am
Thanks for the replys guys. Whitey could you post up a couple pics of your hydro set up. Thanks
whitey
Post by whitey » Sun Jun 23, 2013 11:39 pm
jsut saw your question. I'll get them on tonight.
whitey
Post by whitey » Mon Jun 24, 2013 12:02 am
My first hydro assist system below. the brackets on the drivers side knuckle made strong contact with the trac bar bracket when offroad.
Hope this helps.
whitey
Post by whitey » Mon Jun 24, 2013 12:06 am
I'll try to get pics of how it all looks now. I had to bend my axle skid plate this weekend so I should be able to get a clear shot now.
Post by 05PWrockcrawler » Mon Jun 24, 2013 9:06 am
How does the setup with the black ram work. I like how it's mounted higher up. Can you get a better pic of the mounting point on the drivers side. I have a PSC kit but haven't mounted mine yet. Thanks.
Powerwagonmark
Post by Powerwagonmark » Wed Jul 31, 2013 8:47 am
Hey whitey could you post up some pics of your setup with it on the passenger side. Thanks
whitey
Post by whitey » Wed Jul 31, 2013 2:36 pm
I'll try to get some pics tonight after I leave work
Powerwagonmark
Post by Powerwagonmark » Wed Jul 31, 2013 5:52 pm
Thanks a lot Whitey :notworthy:
Powerwagonmark
Post by Powerwagonmark » Fri Aug 02, 2013 5:14 pm
Hey whitey I need those pics ASAP the guy installing my hydro is having some problems getiing full lock left. Thanks
Post by 05PWrockcrawler » Sat Aug 03, 2013 5:17 pm
I would like to see the pics also. Need to mount mine real soon. Thanks
