2014 power wagon new tires bigger size
14wagon86
Post by 14wagon86 » Thu Nov 10, 2016 12:16 pm
Hey guys I have a 2014 power wagon and it is time for new tires and of course I need bigger. I have read lots about what tire size will fit and what will not. I would like guys with 2014 or newer power wagons to really confirm what the biggest size tire I can run on a factory setup without cutting the fenders?? I don't want rub and I would like to run a 35 inch tall tire but I am worried about the 12.5 width rubbing on full lock to lock turns?? thanks in advance guys!!
2014 wagon slt black with decals
Mufflex Magnaflow
35 inch falken at3s
Thuren springs with King 2.0 shocks, Fox ATS stabilizer, Thuren track bar, Synergy drag link, Carli diff armor
Jbw1011
Re: 2014 power wagon new tires bigger size
Post by Jbw1011 » Thu Nov 10, 2016 12:27 pm
I've got a 2016 Laramie all stock except 35 toyo mt's no rubbing at full turn
14wagon86
Post by 14wagon86 » Thu Nov 10, 2016 12:40 pm
JBW.....are the 35 Toyo's true 35x12.5 or metric?? because the true 35x12.5 are actually 13.2 inches wide under full inflation...
Mufflex Magnaflow
35 inch falken at3s
Post by olyelr » Thu Nov 10, 2016 6:18 pm
14wagon86 wrote:JBW.....are the 35 Toyo's true 35x12.5 or metric?? because the true 35x12.5 are actually 13.2 inches wide under full inflation...
And prove it with pikchurz!
:nopics:
Jbw1011
Post by Jbw1011 » Thu Nov 10, 2016 6:21 pm
Yes they are 35x12.5r17 not the metric's
Jbw1011
Post by Jbw1011 » Thu Nov 10, 2016 6:24 pm
Sorry only pic I have that is small enough right now
Jbw1011
Post by Jbw1011 » Thu Nov 10, 2016 6:29 pm
One more the drive slopes a lil so the front looks a lot lower than it actually is.
Jbw1011
Post by Jbw1011 » Thu Nov 10, 2016 6:58 pm
Sorry little dark outside
Post by RustyPW » Thu Nov 10, 2016 7:57 pm
The 35" Toyo MT's are wider then anyone else's 35's.
Jbw1011
Post by Jbw1011 » Thu Nov 10, 2016 8:09 pm
Couple more
[/attachment][attachment=0]IMG_0158.
14wagon86
Post by 14wagon86 » Thu Nov 10, 2016 9:39 pm
thanks I know now i am getting true 35 x 12.5
Mufflex Magnaflow
35 inch falken at3s
Jbw1011
Post by Jbw1011 » Thu Nov 10, 2016 10:44 pm
No problem i only test drove it with the stock tires,but can't really tell a difference other than its a tad taller. Not any rougher or louder.
hammer40
Post by hammer40 » Fri Nov 11, 2016 12:05 pm
I put 35/12.5/17 KO2's on my 2014 with stock rims before leveling. No rubbing.
zak.salhab
Post by zak.salhab » Sun Nov 13, 2016 9:50 am
hammer40 wrote:I put 35/12.5/17 KO2's on my 2014 with stock rims before leveling. No rubbing.
So i was just having this same question on my 2016 Power Wagon Laramie. Did it feel less squishy when you went from D's to E's? Also, do you think you could still fit S-Class chains on the front or rear? I'm thinking of switching out to 35/12.5/17 but in the Toyo RT to firm it up to E's for when i tow but I'm slightly worried about chain clearance.
Jbw1011
Post by Jbw1011 » Sun Nov 13, 2016 12:19 pm
I would think there would be plenty of room for chains unless you really flexed it out. From my limited time on stock tires there is less roll in the corners
zak.salhab
Post by zak.salhab » Sun Nov 13, 2016 1:02 pm
Jbw1011 wrote:I would think there would be plenty of room for chains unless you really flexed it out. From my limited time on stock tires there is less roll in the corners
I was looking at getting a set of S-Class cables and a set of square link chains. Cables for rear when i need something light... square link for the rear when I'm of road and in the nasty stuff. Theb putting chains on the rear and cables on the front if it's really slick out. Chains obviously aren't S-Class. How much room is on the inside once the tires widen out?
Post by TankerZak » Sun Nov 13, 2016 2:08 pm
Even with normal square link chains? I'd like to run cables in the front and square link on the rear. Then i can use cables or chains on the rear depending on situation or cables on the front and chains on the rear when its really nasty. With the wider tires is there clearance issues on the back if the tire to the breaklines etc?
squatch
Post by squatch » Mon Nov 14, 2016 4:30 pm
I'm running Toyo AT2 extreme in 305/70/17. love these sofar. plenty of room, definitly could have gone to 35 on my 2016. just spent a week with them elk hunting and they work great offroad. also very smooth on pavement. big improvement over stock duratracs.
Jbw1011
Post by Jbw1011 » Mon Nov 14, 2016 11:06 pm
Here's some inside the wells.
MSCH2112
Post by MSCH2112 » Tue Nov 15, 2016 1:50 am
careful if you use chains with those tires. when chains develop snow, ice, and mud, they can really be sloppy and thrash your components.
mike
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
Post by TankerZak » Tue Nov 15, 2016 2:24 am
Thanks for those pics. I had 35/12.5R17 Toyo RT's put on today. Drives so much better! No rubbing. I can only describe it as more grounded and less floaty. I think these trucks are just too heavy for D's. No more body roll when cornering.
As for chain fit, it looks like the front is tight if you get a chain that wraps around too far down the side wall. Like a camlock should be okay. The rear seems to have room for days. Thanks for all the effort and the pics!!! Really helped!
Post by olyelr » Tue Nov 15, 2016 6:47 am
By the looks of that picture, it appears the tire rubs the sway bar from time to time, which i would highly expect with stock wheels and the wide of a tire.
Jbw1011
Post by Jbw1011 » Tue Nov 15, 2016 9:17 am
Not saying it won't hit track bar, but I haven't yet. I'm in south Arkansas so not a lot of opportunities for chains. Did a little flexing last weekend trying to get it to rub so far nothing. Looks like for my use "mostly mud & a few rocks" I made a good choice in size.
Post by olyelr » Tue Nov 15, 2016 11:28 am
Jbw1011 wrote:Not saying it won't hit track bar, but I haven't yet. I'm in south Arkansas so not a lot of opportunities for chains. Did a little flexing last weekend trying to get it to rub so far nothing. Looks like for my use "mostly mud & a few rocks" I made a good choice in size.
What I was referring to is the sway bar... the tire will never get to the track bar. That picture of the front wheel turned, it looks like there is some paint wore off the sway bar right where your tire "would" hit. That is the common place for rubbing.
None the less, yea that is a perfect sizer tire for a stock wagon!
Jbw1011
Post by Jbw1011 » Tue Nov 15, 2016 12:37 pm
Yeah sorry meant sway bar was reading track bar post before this. :doh:
