Towing-Hitches/Curt-Adjustable-Multi-Ball-Mount
tat6272
Post by tat6272 » Mon Feb 04, 2013 1:31 pm
http://www.autoaccessoriesgarage.com/To ... Ball-Mount
Anyone had any experience with this product? I like the idea of one and done.
PWRider
Re: Towing-Hitches/Curt-Adjustable-Multi-Ball-Mount
Post by PWRider » Mon Feb 04, 2013 1:55 pm
Might be handy but also how often you need anything but 2" ball. If you do than sure. If you own a trailer than get appropriate drop hitch and be done. Little point for lugging around extras you will never need. Adds more rattles and something to catch the ground.
myoung84
Post by myoung84 » Mon Feb 04, 2013 2:23 pm
Here's what I run. Trimax Razor with Reese interchangeable balls. I rarely use 1 7/8" or 2 5/16" but I have them when needed. It's also much cheaper than some of the billet alternatives. Hitch is about $100 and balls were about $30.
http://forum.powerwagonregistry.org/vie ... 273&p=3921
http://www.amazon.com/Reese-Towpower-74 ... sim_auto_2
http://www.amazon.com/gp/product/B005TC ... 02_s00_i00
Post by 04Ram2500Hemi » Mon Feb 04, 2013 3:50 pm
I have the Rapid Hitch 10" for my truck
http://www.andersenhitches.com/Catalog/ ... hitch.aspx
verdesardog
Post by verdesardog » Mon Feb 04, 2013 5:43 pm
Here's what I'm going to get for the camping trailer I'm building:
As much articulation as a pintle hitch without all the clanging and banging.
http://locknroll.com/
tat6272
Post by tat6272 » Mon Feb 04, 2013 5:51 pm
04Ram2500Hemi wrote:I have the Rapid Hitch 10" for my truck
I like this one a lot. Which did you get? The greaseless or the original?
tat6272
Post by tat6272 » Tue Feb 05, 2013 9:18 am
Last question, do you guys find that you really need the 10" or would the 6" work ok? My PW has not been lifted. I'm going to order one today just not sure which size or whether to go with the greaseless ball or not. Decisions, decisions.......
vanished
Post by vanished » Tue Feb 05, 2013 9:43 am
I like these. :) But my concern would be our factory hitches integrity without using weight distribution... Thoughts?
tat6272
Post by tat6272 » Tue Feb 05, 2013 5:59 pm
vanished wrote:I like these. :) But my concern would be our factory hitches integrity without using weight distribution... Thoughts?
They have a similar set up that does have the weight distribution. Looks like three height adjustments on this one.
http://youtu.be/HRoQ_yQZQwQ
Post by cruz » Tue Feb 05, 2013 8:35 pm
tat6272 wrote:Last question, do you guys find that you really need the 10" or would the 6" work ok? My PW has not been lifted. I'm going to order one today just not sure which size .
Although there is NO standard, MOST trailer couplers are about 18" from the ground to top of ball.
vanished
Post by vanished » Tue Feb 05, 2013 9:23 pm
Thanks tat. That's pretty sweet setup. But considering I already have a Reese wd setup I just need to get the longer drop to get my trailers level... Biggest question I have is how do all the other work truck 2500 & 3500 rams that are towing lowboys with bobcats, tractors & backhoes on them do it safely? They gotta have a higher tongue weight than my camper or 3 horse slant trailer and rarely ever have wd bars...
tat6272
Post by tat6272 » Wed Feb 06, 2013 8:33 pm
This was helpful. Thanks. I went with the 10 inch greaseless.
MOPARManiac
Post by MOPARManiac » Thu Feb 07, 2013 8:55 am
I use fixed receiver hitches, lest chance of failure IMO. I use a 6" drop for my flatbed trailers and a 4" drop for our camper (it sets up pretty high).
tat6272
Post by tat6272 » Fri Feb 15, 2013 7:06 pm
Got the Andersen Rapid Hitch 10" with greaseless balls. This hitch is a thing if beauty. Solid aluminum (yes, aluminum, but it's heavy as hell). Probably should have gone with the 6" though. 10" is probably better for a lifted truck.
blathrop99
Post by blathrop99 » Thu Jan 30, 2014 8:09 pm
I have one. Have had it for several years. It works great and is really convenient.
Post by 04Ram2500Hemi » Fri Jan 31, 2014 8:57 am
tat6272 wrote:Got the Andersen Rapid Hitch 10" with greaseless balls. This hitch is a thing if beauty. Solid aluminum (yes, aluminum, but it's heavy as hell). Probably should have gone with the 6" though. 10" is probably better for a lifted truck.
You're not kidding- the 10" is heavy. However, I never want to have to buy another hitch again, so that's why I went with the big one.
Stickman
Post by Stickman » Sat Feb 01, 2014 2:20 am
Actually just ordered one of these today, in a 7", comes with a 2" and a 2 5/16" ball. Most people run a Reese around here, unless you can afford a B&W, quality stuff:
Check them out: http://www.turnoverball.com/ (site isn't working now, was this morning)
verdesardog
Post by verdesardog » Sat Feb 01, 2014 3:04 pm
I didn't get the hitch I orginally posted I got this one:
No ball! Can't pop off unless something breaks......
