545rfe fill tube grommet question
ACL123
Post by ACL123 » Thu Mar 19, 2020 7:07 pm
I got the oe grommet and its sealed on top. Do o just push the fill tube down through it? Or cut a slit in it?
2005 Bright Silver PW
2005 Mineral Grey PW
ACL123
Re: 545rfe fill tube grommet question
Post by ACL123 » Thu Mar 19, 2020 7:10 pm
Wont let me post pics but here is a link to the grommet
https://www.google.com/search?safe=off& ... 6748046875
ACL123
Post by ACL123 » Sun Mar 22, 2020 9:20 am
Post by coder » Sun Mar 29, 2020 9:41 pm
So what does this actually do?
ScubaSteve
Post by ScubaSteve » Mon Mar 30, 2020 9:28 am
Looks like the grommet that would seal the transmission dipstick tube where it goes in to the case above the tranny pan.
I would imagine you need to cut a hole in it. If you can use the dipstick tube and push it through on a piece of cardboard that might be best. Put the tube in from the wrong side and push down on a cardboard or wooden surface so the end of the tube cuts through like a hole punch. Don't insert it in the transmission and then try to shove the tube through, that'll leave debris in the transmission.
