I ripped the wires out of my front harness where it attaches to the front differential. New harness is a month away. I can fix this one but only know for sure the location of 1 wire.
Can someone please take a picture of the four wires location as they enter the harness st the diff? Thanks for the help!
Front Locker Disconnect harness
Re: Front Locker Disconnect harness
Of course they are out of stock, but there is a wiring USB that Mopar is releasing.
https://www.techauthority.com/en-us/pro ... 855&type=7
The 2017 is in stock, but don't know how much difference there is.
Just search the forum. The answer is here already. Locker Bypass has all the diagrams. That has been the same for a long while. Nothing different there on your wire than my 2015 from what I see. All the same colors too. I have a video even talking about those wires.Ajchampion2018 wrote: ↑Sat Apr 13, 2019 3:26 pmI ripped the wires out of my front harness where it attaches to the front differential. New harness is a month away. I can fix this one but only know for sure the location of 1 wire.
Can someone please take a picture of the four wires location as they enter the harness st the diff? Thanks for the help!25930504-6F0C-4BB2-B293-57CCB1AC2A8A.jpeg
Welcome to the forum Ajchampion2018!
Here's the place to find the connector pin positions for the wires, including color and wire gauge size.
Here's a source for the connector housing and terminals that you need. Select 4 pin female w/terminals.
This is the terminal crimping tool you need to do the job right.
Thank you for the diagram. It all makes sense, but I have a yellow wire with a grey tracer. The diagram describes it as yellow/bu. The other three match and there’s only one wire left, but I’d rather be sure than assume. Thanks
Here's a link and screen-shot of the front locker harness connector replacement kit it has the colors of the wires mapped to the connector.
Link to the Mopar harness connector site.
https://connectorrepairkit.mopar.com
- 2018 PW Locker Harness Kit.png (32.68 KiB) Viewed 1967 times
