Helpful link: http://www.rubicon-trail.com/jeep101/chains.html
I need some 35x12.5R17 chains. Looked at these chains in the correct size, specifically for a Toyo Open Country MT...TwinStick wrote:http://www.clothierproducts.com/default_site.htm
Best quality ones i have seen. Cross chain every 2 links, instead of every 4 or 5 like the rest.
Hey BigMike! Living in the mountains, I'd bet you can find someone to make a set for you. Big rig shops will likely know locals who can do it. I've also cut down to size, used rig chains that have been cycled out of commission.BigMike wrote:It's been a pain in the butt trying to find HD chains for 35x12.5R17! Anyone use Tirechain.com? Who else is out there?
Those look like they would be a nightmare to keep tight, way too much slop in the side rails.BigMike wrote:Anyone hear or know anything about the Rud Olympia Sprint tire chain?
I completely agree. Not even close to heavy duty, complicated , no caming device, too much chain and to little strenght. The hooks are a joke as they could let the chain go if they come loose. Likely would be difficult to store without getting them all twisted and messed up. The rails on the sides aren't straight tensioned due to the light chain in the middle that's used to pull up the slack. That light chain would be your weak point. Poor designed garbage if you ask me. The design that was in the pictures I showed are simple, strong, tried and true. Once you use the cams you'll see what I mean. If you snug fit the chain, and lock those cams it will literally squish your tire. Absolutely zero slack. I've put chains on my work trucks (crane and pickup) just this year alone no less than fifty times and God knows how many times in my career on both pickups and rigs for both work and play. You want tight strong chains cause if a side rail breaks or the chains slip off and wrap around your axle, they'll likely need to be cut out after they destroy your brakes and anything else they contact.Trouble Maker wrote:Those look like they would be a nightmare to keep tight, way too much slop in the side rails.BigMike wrote:Anyone hear or know anything about the Rud Olympia Sprint tire chain?
One of my Engineers bought a set of these for our Rescue Pumper. I didn't know about them until I saw them on the truck. My first thought was there were WAY too many moving parts. He attempted to take up slack in the chains with bungee cords, of all things.BigMike wrote:Anyone hear or know anything about the Rud Olympia Sprint tire chain?
