Locker Bypass Rebirth
Re: Locker Bypass Rebirth
Post by Retired BLM Rig » Thu Nov 29, 2018 10:08 am
In other news... After reverse engineering this locker bypass system and finding all the components, I had success communicating with CajunPW, who was the last person to sell this system. It turns out I'll be buying all his old inventory of parts, as well as all the supporting documents and info about this product. :rockon: So this won't be a bootleg system after all, it's gonna be the real deal! :D
The big difference is, this time the 3rd Gen's are included! :rockon:
Post by DamageWagon » Thu Nov 29, 2018 12:09 pm
So the secret code to communicate with Cajun was only unlocked after you had fully reverse engineered the thing
Post by RustyPW » Thu Nov 29, 2018 4:28 pm
Question on the 3G. Will it have a separate switch like the older bypasses, or it goes through the factory knob?
Post by RustyPW » Thu Nov 29, 2018 4:30 pm
Post by Retired BLM Rig » Thu Nov 29, 2018 5:15 pm
It will function through the factory knob.
It’s going to use a different control box housing mounted behind the knee bolster under the steering column. I tried finding a good location in the engine compartment to mount the control box, but it just seems too tight. Since the T harness needs to plug in under the dashboard, it just seems easiest to mount the control box under the dashboard as well and then route the harness to the fuse box and lockers. I should be building a prototype this weekend.
Post by RustyPW » Thu Nov 29, 2018 7:40 pm
What would the price be?
Post by Retired BLM Rig » Thu Nov 29, 2018 11:00 pm
It's looking like all of these kits are going to be $450 to start with. If I can find better prices on the components from different vendors, the price will come down. A portion of the money from each unit will be donated to PWR for providing a platform to make this all possible.
aleelopez
Post by aleelopez » Thu Nov 29, 2018 11:17 pm
06 Arizona Wagon
Post by 06 Arizona Wagon » Fri Nov 30, 2018 6:12 pm
Please put me down for a 3rd gen kit 2006. Can not thank you enough for making these....
Kevin
06 Arizona Wagon
2006 PW, 315/70r17 BFG KO2s, Whiteknuckle Offroad sliders, 08.5 steering upgrade, DOR diff covers, 'Protop' reinforced shell, Line-X'ed, Frontrunner platform rack, Superchips tuner, Thuren shackles, Fox 2.0s
Post by Retired BLM Rig » Sat Dec 01, 2018 1:16 am
The current locker bypass list:
1. Lancer29 (2005)(Building a prototype 12/2 thru 12/3)
2. Olyelr (2016)
3. AlaskaTRX (2017)
4. TankerZak (2016)
5. EasyDoesIt (2018)
6. Jakestopp244 (Late 2012)
7. RamV (2016)
8. Snowho (2018)
9. w2dodge (2005)
10. aleelopez (2008)
11. Idaho RC (2017)
12. 06 Arizona Wagon (2006)
Post by olyelr » Sun Dec 02, 2018 10:51 pm
Quick few questions on these units...
So this setup essentially bypasses the brains in the smart bar, correct?
Using this setup should essentially make it much quicker for the lockers to lock/unlock, correct?
When in 4-low with this setup, it still by-passes all the brains in the smartbar, correct?
My main reason for wanting this is to get a much quicker lock/unlock response out of the lockers. I typically prefer to drive around unlocked until I know I need them, and with this stock setup it is almost a joke to be able to do that. I may have just gotten spoiled with my Rubicon, but those damn things were instant on and off every time (which were by-passed). Different animal, I know, but that is what I am hoping for with this kit.
Post by Retired BLM Rig » Sun Dec 02, 2018 11:53 pm
Yeah, this should probably be called a “SmartBar Locker Bypass”. So yes, it bypasses the brains in the SmartBar and gives you direct control of the lockers. It’s basically plug and play hardwired lockers using the O.E. dash knob, and yes it makes it instant on and off in any transfer case range. No more blinking locker light!
Post by Retired BLM Rig » Mon Dec 03, 2018 3:32 am
It's been a long day.
The first ever 3rd Gen. control box and T-harness.
Comparing the new, smaller 3rd Gen. control box on the left to the original 4th Gen. control box on the right.
A little different layout internally.
A little shorter to fit under the dashboard better
Tomorrow, finish the harness, test install, write new installation instructions, box it up and ship it out.
This one has your name on it Lancer29.
Post by Retired BLM Rig » Mon Dec 03, 2018 3:57 am
2. Olyelr (2016) On hold until after the holidays
3. AlaskaTRX (2017)
4. TankerZak (2016)
7. RamV (2016)
8. Snowho (2018)
9. w2dodge (2005)
11. Idaho RC (2017)
13. RPS1030 (2016)
Post by Mule007 » Mon Dec 03, 2018 6:22 am
Good work Retired BLM Rig, WOW am impressed! Thank you !
lancer29
Post by lancer29 » Mon Dec 03, 2018 7:09 am
Fantastic! Thanks so much for your work on this. Just PM me and we can work out the payment and shipping details. Thanks again.
2005 Dodge Power Wagon
1977 Ford Bronco
1980 Toyota FJ40
Post by RustyPW » Mon Dec 03, 2018 9:04 am
This answered the other question I had running around in my head. :rockon:
Put me in for one too. 3G 2008.
Post by olyelr » Mon Dec 03, 2018 9:07 am
:excited:
Thats what I wanted to hear!
Do you have instructions made up for this yet? If so can you post up a picture of them? Just curious what all is entailed.... a man of my caliber will probably mindfawk this install for two days before taking a full day to actually install it.
Post by Bill2014 » Mon Dec 03, 2018 10:12 am
This is indeed awesome work!!!
Common sense warning - I hope we all understand the following:
Everyone needs to be aware that there can be some severe consequences if the dial now inadvertently gets switched on - on the highway at high speed - by a child or wife - and either or both differentials actually lock up. Just imagine the possibilities... Also, don't ever turn the dial when you are stuck with the wheels spinning...
Post by Retired BLM Rig » Mon Dec 03, 2018 11:15 am
All valid points to be aware of. There's about 100 of these out in the wild from previous builders, I wonder if anyone with an original unit has ever experienced accidental engagement?
The easiest way to overcome this fear is to just pull the fuse if you know that you're not going to be using it, or put a toggle switch on the ground wire.
Post by TankerZak » Mon Dec 03, 2018 11:35 am
Anyway to wire in a disable switch?
Post by Bill2014 » Mon Dec 03, 2018 12:30 pm
:rofl: A bypass bypass :rofl:
Post by Low_Sky » Mon Dec 03, 2018 12:32 pm
Bill2014 wrote:
Retired BLM Rig wrote: All valid points to be aware of. There's about 100 of these out in the wild from previous builders, I wonder if anyone with an original unit has ever experienced accidental engagement?
I was thinking the same thing but I wasn’t gonna say it.
Post by olyelr » Mon Dec 03, 2018 3:22 pm
Joke all you want. I think its a good idea. Seriously. David, you say simply wire in a switch on the ground... can you do this on mine (without much extra trouble) while you are making it? Or is that something that I would have to add in when I get it. I honestly want it like that.
Thats the way I had my rubicon setup, and it even had added switches for the lockers. But in order for them to work, I had to flick a toggle switch first. Loved that setup.
Post by RustyPW » Mon Dec 03, 2018 3:30 pm
I have one of the very first bypasses. Just pissing around with it. I locked my rear axle down go the highway at 70 mph just to see if it would lock, and unlock. It will without much drama. Making a turn with it locked. The PW wanted to push the front to the outside of the turn. But it will turn.
