HI LIFT BASES SHIPPED
- Mr.Smith
Re: HI LIFT BASES SHIPPED
1 Mr.Smith
2 BANGG
3
4
5
6
7
8
9
10
2 BANGG
3
4
5
6
7
8
9
10
I'm in
- Mr.Smith
1 Mr.Smith
2 BANGG
3 05PWrockcrawler
4
5
6
7
8
9
10
2 BANGG
3 05PWrockcrawler
4
5
6
7
8
9
10
- Mr.Smith
Can we get them notched for chain use & serations between?(similar to the First Responder)
- verdesardog
As you can see in the photos I drill holes for shackles to connect chain. I can cut the sides for serrations but feel it's not really necessary. The weight of the truck plants these pretty securely into whatever surface you are on.Mr.Smith wrote:Can we get them notched for chain use & serations between?(similar to the First Responder)
Mexican Import
I would like one.
- Mr.Smith
1 Mr.Smith
2 BANGG
3 05PWrockcrawler
4 Mexican Import
5
6
7
8
9
10
2 BANGG
3 05PWrockcrawler
4 Mexican Import
5
6
7
8
9
10
- bstefanic
Count me in
Sent from my DROID RAZR HD using Tapatalk
- verdesardog
Mr.Smith wrote:1 Mr.Smith
2 BANGG
3 05PWrockcrawler
4 Mexican Import
5 bstefanic
6
7
8
9
10
Half way there! I will ask my brother if he wants one.
- verdesardog
I will talk to Dan at smelter city and see what he would charge for 5 or 6, it seems like that's about all the interest there is at this time.
- verdesardog
I will be out of town for about a month. I'll get started on these then. Maybe there will be more people interested in them then.....
Versadog---are you still making or mod'dng these bases
- verdesardog
See the post just above yours....will probable have more made in August.adeluca73 wrote:Versadog---are you still making or mod'dng these bases
- SheepdogOutdoorsman
Hi Lift makes these units ... http://youtu.be/nakSPmLpWsI
- verdesardog
SheepdogOutdoorsman wrote:Hi Lift makes these units ... http://youtu.be/nakSPmLpWsI
I know about those, that's where I got the idea to make my own.
- Mr.Smith
You can not just buy the Hi-Lift first responder base, unless you have the entire unit & can prove to them...it's BULLSHIT!
That is bull!Mr.Smith wrote:You can not just buy the Hi-Lift first responder base, unless you have the entire unit & can prove to them...it's BULLSHIT!
I was just starting to spec out a hi-lift jack, is the First Responder the way to go? If so, is your base better than the OEM base, and will it fit the First Responder Jack?verdesardog wrote:SheepdogOutdoorsman wrote:Hi Lift makes these units ... http://youtu.be/nakSPmLpWsI
So after reading the specs on the Hi-Lift web site, are there any differences between the 60" Xtreme and the 60" First Responder aside from the color scheme?
Except price! It's almost $200 more!adeluca73 wrote:So after reading the specs on the Hi-Lift web site, are there any differences between the 60" Xtreme and the 60" First Responder aside from the color scheme?
- verdesardog
If you get the first responder there is no reason to get the base I make.
Except the fact that it's way cheaper to buy a standard Hi Lift jack and add your base. That saves over $100 right there. Your option is much cheaper ... cost wise that isverdesardog wrote:If you get the first responder there is no reason to get the base I make.
SheepDog...Yeah it is definitely a cheaper combo---On Amazon, a 60" Xtreme Hi-lift is $112+$50 new base, & the 60" First Responded is $236. So it's about $75 cheaper.
VerdeSarDog---Can your base take the chain and tow straps like the First Resp base? Also, I can't tell from the pics, but can that base fit the 2 4x4 cribs like the FR base?
- Mr.Smith
1 BANGG
2 05PWrockcrawler
3 Mexican Import
4 bstefanic
5
6
7
8
9
10
I'm out...ordering the 60" FR. No patience, hahahahaha!
2 05PWrockcrawler
3 Mexican Import
4 bstefanic
5
6
7
8
9
10
