Is this place still alive?
- Just Passin'.jpg (19.52 KiB) Viewed 53515 times
may this day be good for you & yours!NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
- fker.jpeg (49.2 KiB) Viewed 53491 times
Feetball Sunday.
lit up two new cameras last week, 100ft up a tower.
First shots from the Axis on the top of the candycane. "It works... smile"
the Flir was grumpy but eventually got it working
it's a cool camera.
it's a cool camera.
gtomike60
What's the purpose for the cameras?
2012
Wildfire detection, primarily.
Every few minutes the cameras spin around and build a 360° pano, then run those pano's through algo's to identify fire activity.
When the AI detects a fire, it spins the camera(s) to that az/el, and flags the site as an alert.
If two or more cameras "see" a fire, the system plots a bearing line from each of the cameras, and X marks the hotspot for a quicker and more efficient response.
Logged in this afternoon and the Axis (visible camera) had alerted on someone burning leaves in their backyard nearby.
Mule wrote: ↑Mon Nov 13, 2023 7:36 pmWildfire detection, primarily.
Then they can send a ticket to that address for having too large of a carbon footprint.
https://www.youtube.com/watch?v=eiyfwZVAzGw
High Cascades Elk Mt Hood
High Cascade 2023 Elk hunt-no bulls yet-cows, yearlings, & deer. Pics in prev. post are - Mt. Hood; Olallie Butte; Mt. Jefferson; Sisi butte lookout
No,,, but these are areas they would love am certain of that. Am from Colton, Oregon,,,,N
Between Molalla & Estacada,,,,stories list these areas,,,,
2023-no bull or squatches this year,🫤,,,good to be able to access areas closed for the past 2-1/2 years-horrendous fires, then fire remediations, then slides,,,animals still there,,,forest floor foliage, plants, coming back, streams, springs, doing well,,,nature’s resilience is amazing,,,
Mule007 wrote: ↑Sun Nov 19, 2023 9:56 am2023-no bull or squatches this year,🫤,,,good to be able to access areas closed for the past 2-1/2 years-horrendous fires, then fire remediations, then slides,,,animals still there,,,forest floor foliage, plants, coming back, streams, springs, doing well,,,nature’s resilience is amazing,,,![]()
we hope Thanksgiving gives each of you & yours time to share w family & friends to appreciate all we have to be thankful for!NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
Happy Thanksgiving!2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Full SmartBar Bypass®, Abel Components Nanny Kill Switch®, 2000 Watt ProMariner TruePower Plus Pure Sine Wave Inverter, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God, Share the Umbrella, Make sure you're right with God before you meet him!
Happy Thanksgiving to all you turkeys.
Football Sunday.
good morning! May your day be blessed! Enjoy!!NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
Morning fellow donut makers.
Late to the party but still here.
