Cooper or Maxxis?
Cooper STT Pro or Maxxis Razr MT?
Cooper STT Pro
7
70%
Maxxis Razr MT
3
30%
Total votes: 10
16PW
Cooper or Maxxis?
Post by 16PW » Mon Oct 22, 2018 1:41 pm
It's time for a tire upgrade! The truck came with 33" Ironman AT, but I need bigger tires and an MT. I will be going with 37x12.50r17. I was initially set on Cooper STT Pro's as I have read so much good stuff about them, especially for the price. I had a set of 35" Cooper MTP on my 1500 and they were great so I have been wanting to try the STT Pro for quite some time. I just recently did quite a bit of research on Maxxis Razr MT and came across a lot of good reviews so they might be in the ball game. I know there are many other great MT's out there but most are much more expensive and/or heavier than the STT. I'm not sure what the weight of the Maxxis is, but might be similar to the STT.
What do you guys think between these 2 options?
13powerwagon
Re: Cooper or Maxxis?
Post by 13powerwagon » Mon Oct 22, 2018 6:37 pm
I have the STT pros in the stock size, been a good tire so far, 26000 miles and 12/32 tread left. They are wearing evenly, I rotate them every 5000 miles. I did tear a side lug on a wheeling trip in west Texas, but no air leaked. The tire is still on the truck with no issues.
2013 tradesman
EasyDoesIt
Post by EasyDoesIt » Mon Oct 22, 2018 8:18 pm
I've got the 37-1250-r17 STT Pros, great tire and after 5k miles they still look great and aren't very noisy.
A little heads up the the 12.50" wide is closer to 13" wide. I've got them on stock wheels with no width issues.
16PW
Post by 16PW » Mon Oct 22, 2018 11:04 pm
I'm assuming you have a little rub on the control arm and sway bar at full lock? Seems like with stock wheels they only rub a little on those parts.
Post by RustyPW » Tue Oct 23, 2018 12:33 am
I got the Cooper STT 35's when they first came out. Great tire. Never had an issue with them.
Suspension flex. Here's tire flex. :lol:
16PW
Post by 16PW » Tue Oct 23, 2018 1:11 am
That's some serious tire flex! :lol: What psi was that at?
EasyDoesIt
Post by EasyDoesIt » Tue Oct 23, 2018 12:21 pm
You got it, just rub at full lock. I had to trim a little plastic and beat back a pinch weld but that took all of 30minutes.
16PW
Post by 16PW » Tue Oct 23, 2018 1:15 pm
I wonder if the 2018 rims have a different offset than the steel rims. I read some guys have no rubbing on plastic or pinch weld with the stock steel rims on 14+. Did you just hammer away at the pinch weld or cut it too?
Post by olyelr » Tue Oct 23, 2018 4:07 pm
Steel?
16PW
Post by 16PW » Tue Oct 23, 2018 4:27 pm
Steel?
"Steelies" as I see so many people on here refer to them as.
Post by olyelr » Tue Oct 23, 2018 5:11 pm
Stock steelies? On a 14+? Ive never seen them or heard of them.
16PW
Post by 16PW » Tue Oct 23, 2018 5:23 pm
Where's the shrugging emoji. lol What are these rims?
Post by RustyPW » Tue Oct 23, 2018 6:24 pm
20 psi.
ghaugo
Post by ghaugo » Wed Oct 24, 2018 10:00 pm
I got some of the STT Pros on my truck this year, and so far they have been outstanding. I have 315 70 R17 size, and I replaced the control arms on my 2012. They have been really good off road. I am looking forward to taking them into the woods hunting this fall. I am looking to test out the mud/snow capabilities.
16PW
Post by 16PW » Thu Oct 25, 2018 9:10 am
As far as reviews go, they are supposed to be great in the mud and pretty good in the snow/ice for it being an MT.
Rodeoflyer
Cooper or Maxxis?
Post by Rodeoflyer » Thu Oct 25, 2018 9:10 am
Stock steel wheels. I know... it’s an 11-13 year truck but for illustration purposes.
https://youtu.be/LO71Fb-Xw1E
16PW
Post by 16PW » Thu Oct 25, 2018 9:18 am
Thanks for clarifying. I have read about stock steelies all throughout the forum so I just assumed.
Post by olyelr » Thu Oct 25, 2018 3:52 pm
Well, those might be stock steel wheels for a Ram truck, but the power wagon was never offered with them.
NovA ProspekT
Post by NovA ProspekT » Sun Oct 28, 2018 11:40 pm
I've heard great things about Maxxis tires, although I have no personal experience with them.
However, I do have 37" Cooper S/T MAXX's on my truck, which are the same tire as the STT PRO, aside from the tread-pattern. They've been a great tire. They're both made in the USA, if that matters to you, and both have a special reinforced 3-ply sidewall. They ride comfortable and stable on the road, even at 32PSI with a lightly loaded/empty truck. Both also have a relatively soft tread compound, which is great for traction on and off-road, although at a reduced lifespan.
If you want something really aggressive, the Mickey Thompson Baja Claw TTC Radial might be worth a look. Mickey Thompson is owned by Cooper Tire, and the Baja Claw TTC Radial has the same special 3-ply sidewall as the S/T MAXX and STT PRO. They're also $100 off a set right now.
Depending on how you plan to use your truck, I would strongly recommend considering the Cooper S/T MAXX, especially if you do a lot of driving on the road. They're a hybrid between an aggressive A/T and an M/T. They look great, are much quieter than an M/T (even with studs), work much better in the snow than an M/T, and still work fantastic in the mud(been there, done that).
Also, keep in mind that only a dedicated winter tire with a soft tread compound and studs, such as the Nokian Hakkapeliitta LT2, will work well on ice. Even my studded S/T MAXX's are just okay in that regard.
Of the two you listed, my vote is for the STT PRO.
Also, the Power Wagon was never equipped with steel wheels from the factory, aside from the spare.
16PW
Post by 16PW » Mon Oct 29, 2018 11:51 am
Thank you everyone for your input. I have ordered the Cooper STT Pro and should have them on tomorrow.
Post by olyelr » Mon Oct 29, 2018 3:11 pm
What size?
Post up some pics :)
16PW
Post by 16PW » Mon Oct 29, 2018 4:15 pm
What size?
37x12.50r17 :excited:
I'll definitely post some pics. Maybe I'll start a build thread, even though it will be a slow work in progress. I have a Procal on the way as well.
Post by olyelr » Mon Oct 29, 2018 5:38 pm
:rockon:
16PW
Post by 16PW » Fri Nov 02, 2018 9:48 am
37 Cooper STT Pro's are finally on! It's amazing how big these tires are in person compared to stock size. I was really surprised how much higher the truck seems. These 37's look right at home on power wagons.I have the obvious rub on the control arm and sway bar, but no rubbing on plastic.
Parking in the garage at work was interesting. 7' clearance and it was close!
Post by Bill2014 » Fri Nov 02, 2018 11:38 am
Good thing you don't have marker lights on the cab like some of us do... They might scrape in the parking garage! :o
