2017 bug deflector
HeavyDuty
2017 bug deflector
I ordered a avs bugflector II. For a 2500 ram, which I figured would fit. Went to install it and didn't seem quite right. Managed to get it on but when I slammed the hood it seemed real tight. Took a closer look and the screw which they supply to hold the corners in we're hitting my headlights. I'm damn lucky I didn't crack them. I should have let the hood down a little easier to test fit Whoops.... so my question is has anyone found a bugdeflector that fits the .17 powerwagon? Which ones do you like? Thanks
“ROCKY MOUNTAIN” TESTED
Re: 2017 bug deflector
Is yours the new grill? My '15 has an AVS for Ram 2500 that fits without any issues...
13BlkPowerWagon
I have a Stampede on my 13, and I can't use the screws over the headlights either... maybe if I shimmed the hood open another hundred thousands it would clear, but not the way it is now. It doesn't make a difference on mine, the stampede is a little narrower, so they don't really move around at all.
HeavyDuty
Yes. Mine is the new grill. I thought the geometry looked the same but I guess not.
HeavyDuty
Was chatting with a Lund ,Avs employee today and they don't make a bugdeflector to fit the powerwagon submodel
How is it any different from any other model?HeavyDuty wrote:Was chatting with a Lund ,Avs employee today and they don't make a bugdeflector to fit the powerwagon submodel
- Rodeoflyer
2017 bug deflector
How is the '17 different? I added a Lund aeroskin II under the secondary avs hood protector for xtra coverage as it's listed for 09-17. Bugs (springtime) and road debris are terrible here. I've considered bedlining the entire front end. Not sure if you can see it in the pic but a huge rock smacked my plastic avs. It would have destroyed the hood.
HeavyDuty
Not sure. I installed a avs bugflector II and the part above the headlights "wings" wouldn't fit right. And the mounting screws were digging into my heAdlights. I contacted the manufacturer and they said they did not have one that would fit the powerwagon sub model.
Just installed the avs aero on my new PW love it and matches the black grill and bumber
HeavyDuty
Damn that does look good. That’s the one that adheres to the hood itself? How bout a few more closer pics
I have the EGR shield on my 2016 and fits with no issues.
Only picture that I have right now I ll get some more soon
Sorry about the picture being upside down
