Another Government Wagon Auction
Re: Another Government Wagon Auction
I paid $13k for my '11
That seems pretty reasonable. Thats the trick with auctions, sometimes things go low, sometimes high. Just have to know your limit.
A clean looking 08 in El Dorado Hills, CA.
Closes on 1/20/18. Maybe I should buy it for spare parts!
2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Full SmartBar Bypass®,  Abel Components Nanny Kill Switch®,  2000 Watt ProMariner TruePower Plus Pure Sine Wave Inverter, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God,  Share the Umbrella, Make sure you're right with God before you meet him!
Almost looks like it just rolled off the assembly line.... nice!!Retired BLM Rig wrote: ↑Thu Jan 18, 2018 3:07 amA clean looking 08 in El Dorado Hills, CA.
The government shutdown caused all these auctions to be put on hold.
If I was one of the bidders...
				EasyDoesIt
I bid on several before I bit the bullet on my 2018.  I really wanted a 2012 but bids kept going over $20k which was too much in my mind.
I wonder what the 2014s will go for once they start showing up?
I bet that 2010 goes pretty cheap. It looks a little rough around the edges and has 153K on the clock, I'll be surprised if it hits $10K. It's ready for retirement and civilian life (someone to give it a little TLC).
An 07 in Sparks, NV. Sold for $13200.00
A 12 in San Antonio, NM. Sold for $8241.00
Both auctions end on 3/14.
					Last edited by Retired BLM Rig on Tue Apr 03, 2018 9:17 am, edited 1 time in total.
That 2012 is an exact copy of my 2011 and came from only a few hours away from where mine did. I guess they like PW’s in New Mexico
That one needs a T-case too.DamageWagon wrote: ↑Thu Mar 08, 2018 1:50 amThat 2012 is an exact copy of my 2011 and came from only a few hours away from where mine did. I guess they like PW’s in New Mexico
 There must be some connection.
This 2005 is in Brewerton, NY, so you east coast guys have a chance on this one.
It says that the battery is dead and may need other repairs. With only 83285 miles, I bet if you put a battery in, it would drive away. If nothing else it could be a good parts truck for someone.
Current bid $3510.00, ends in 3-1/2 days.
Edit: This ended up selling for $8915.00
					Last edited by Retired BLM Rig on Tue Apr 03, 2018 9:12 am, edited 1 time in total.
Says the winch is rusted and cable won’t come out...wonder if a good dousing in PB Blaster would free the winch cable? Current bid $5K...temptingRetired BLM Rig wrote: ↑Mon Mar 19, 2018 3:13 amThis 2005 is in Brewerton, NY, so you east coast guys have a chance on this one.
- Garmin BT Power Switch Powering:
If the winch goes in but not out it's most likely the thermal disconnect switch is not working it can be easily bypassed. It's a common problem on early 3rd Gen PW's. I did the bypass as a preventative measure not to long after I got my truck, see my signature below "Winch Thermal Protection Bypass".
It’s now at $5500, much higher and that 13yr old truck suddenly gets far less attractive
Wow! - That 2005 is almost the same as my 2003 except I don't have the PW package.
I do have more rust on the body/fenders but the interior & topper on mine are nicer.
I would say it is worth $5500 if that is the price range someone is looking for.
Trucks:  2003 4x4 Dodge 3/4 ton, 1972 4x4 Ford 3/4 ton (factory hi-boy), shopping for new Power Wagon (maybe 2024?)
If the lockers work, it is worth more than current bid in spare parts !
Next vehicle for your consideration: A 2010 with a lovely three tone paint scheme, high milage and missing parts, in Eldorado Hills, CA.
This ended up selling for almost $15K.
Maybe the brown stripes were just vinyl stickers.
Here's a 2012 in West Valley City, UT. with Ramboxes. 135K miles.
I see a winch cradle but no hook or cable.
I wasn’t planning on buying another truck but man that could be a solid deal
When i got mine the winch cable was still zip tied to the drum.
Less than 12 hours to go, holding at $9700 for the last couple days.
2012 DODGE RAM 2500Retired BLM Rig wrote: ↑Sat Apr 14, 2018 12:34 amLess than 12 hours to go, holding at $9700 for the last couple days.
Sale-Lot Number:
81QSCI18155015
City, State:
Current Bid:
17,890 USD
Bidders:
13
Close Time:
04/14 12:11 PM CT (Closed)
Time Remaining:
Sold for below fair condition book value...
Another 2010 in Eldorado Hills, CA.
Lower miles than the last one, but it has a dimpled tailgate, tweaked front bumper and a missing console/seat, just to name a few obvious things.
A 2011 in Taos, NM.
This one may go cheap due to the holes in the body, unless you got creative with stickers, emblems, massive fender flares or a wrap to cover them up.
It looks like one of DamageWagon's siblings.
Or there's this 2012 in Coeur D Alene, ID. that appears to be intact.
