Cool hidden features
Re: Cool hidden features
Turn the key to RUN but don't start it - then follow the seatbelt steps. For the push button ignition, push the button twice without the brake pedal depressed - then follow the seatbelt steps...
Just not working for me.  I have tried at least a dozen times now.
Truck off.  Sitting in drivers seat.
Two pushes of ignition button with no foot on brake(ignition on)
Seatbelt off. Buckle, unbuckle x3
One press to off
Have tried the same starting the belt buckled and ending with it buckled. Also have tried in accessory instead of ignition.
One press to off
Video states to begin with the belt buckled. I finished with the belt off. I'm guessing not starting with belt buckled before turning ignition to run is your issue.ramv wrote: ↑Sun Feb 04, 2018 1:44 pmTruck off. Sitting in drivers seat.
One press to off
Ok, I have tried that way too, but i'll give it another couple of shots.
Do you allow it to retract all the way? I have tried both, but hard to get three in in 10 seconds.
Just not working. Not sure why.
				joeschmidt
Is the trucks software version up to date?  I know mine is not and I can’t get mine to work either.  Curious if that’s the issue
Who knows?  I haven't been back to an FCA dealer since I bought it.  It did an auto update on the Nav etc at one point.
I will likely take it back for the recall once they get fix figured out (brake interlock). Then I will get the update done for my Procal as well (right now says adjust to 35 psi, but the light still comes on below 53 psi). Maybe they can do the seatbelt chime turnoff too.
I wasn't able to get it to work on my 2018 either but not surprised since the BCM programming has changed for 2018.
Worked for me. But I don’t have the keyless thing.
My truck is a 2015 and hasn't been in for any software updates ever. I don't think the software being up to date is required.joeschmidt wrote: ↑Mon Feb 05, 2018 7:14 pmIs the trucks software version up to date? I know mine is not and I can’t get mine to work either. Curious if that’s the issue
Hum, I don't have keyless entry either. I must be doing something wrong.
