Kill-switch for electronic nannies
NickTF
Re: Kill-switch for electronic nannies
Post by NickTF » Thu Jan 25, 2018 5:20 pm
Well shit, no cruise control with fuse out. Would someone make the switch for crying out loud lmao!?!?!?!?
Post by olyelr » Thu Jan 25, 2018 9:06 pm
It most likely wont work with the switch we are envisioning either. It basically will mimic pulling the fuse, so...
NickTF
Post by NickTF » Thu Jan 25, 2018 10:33 pm
Why would it not work with the switch in place set to “on”?
Post by olyelr » Thu Jan 25, 2018 11:04 pm
Hm. I dont know if you are referring to the "on" meaning the nannies are killed, or meaning the nannies are not killed.
As long as the nannies and ABS are usable (like factory) then you would have cruise control. Once the switch is used to kill all the nannies and ABS, cruise will go bye bye.
NickTF
Post by NickTF » Fri Jan 26, 2018 9:53 am
On would be the circuit complete and OEM functionality happening. This is definitely the key for us lazy bums that want maximum hooligan on-demand!
Post by Reloaderguy » Fri Jan 26, 2018 2:29 pm
Every time you flip the switch the computer stores a fault code. There is no integrated deactivation of the ABS that doesn't get a code unless you reprogram the ECU.
Post by Low_Sky » Fri Jan 26, 2018 3:29 pm
But I wanna do donuts on cruise control!
Post by olyelr » Fri Jan 26, 2018 3:34 pm
Lmao :lol:
Yes, i love those emails. Is there a downfall to this?
NickTF
Post by NickTF » Fri Jan 26, 2018 3:53 pm
Is there a way we can have this information recorded and placed on a public power wagon forum table to judge all 2014+ year member hooligan levels? :excited:
The internet, where you didn't even know you needed something until you read it somewhere. I MUST HAVE CRUISE CONTROL DONUTS STAT!!!!!!!
Post by Retired BLM Rig » Fri Jan 26, 2018 4:16 pm
As an experiment try unplugging one of your wheel speed sensors. It will set an ABS code and turn on the light. When the system knows that it’s not trustworthy due to missing sensor input it shuts itself off and turns on the dash light. Then see how it starts and drives. In theory if ABS is shutdown, TC and ESC should follow suit since they all work together and rely on each other. If it works get an extra wheel speed sensor and turn it into a T harness with a toggle switch to interrupt the signal whenever you want. No voltage or amperage to speak of that you need to worry about just a toggle switch. If you need to take it in for warranty service, just put your original wheel speed sensor back in.
Post by olyelr » Fri Jan 26, 2018 4:29 pm
:idea:
Look at you go!
Post by Bill2014 » Fri Jan 26, 2018 7:32 pm
Now you're on to something workable :rockon:
Post by Retired BLM Rig » Sun Jan 28, 2018 2:32 am
Well it just so happens that a 2016 CTD came in the shop today, so I had the chance to conduct a partial experiment. I disconnected the left front wheel speed sensor and started the truck with one push on the start button. The ABS and traction control lights came on and it set two codes, one in the ABS module for sensor fault and one in the drivetrain control module for implausible ABS data. Plugged it back in and the lights went out, then I cleared the codes. The connector is on the back of the shock mount tower. Slide the red CPA (connector position assurance) retainer up, then squeeze the release tab and pull down on the sensor end of the connector.
WSS Connector
Just waiting on one of you nanny encumbered 4.5 gen. hooligans to take a trip to Donut City and see how far you get. Just watch out for the cops, I've heard they like to hang out where there's donuts. :lol: :popcorn:
Post by olyelr » Sun Jan 28, 2018 7:28 am
:lol:
It just popped back into the 30s and 40s around here and we lost the majority of our snow. I will give this a whirl as soon as we get some snow again.
Post by Reloaderguy » Sun Jan 28, 2018 11:48 am
Did the truck start with any additional actions required or just normally? Do you know the part number and cost of a front wheel sensor?
Post by olyelr » Sun Jan 28, 2018 12:41 pm
Is that the sensor/wire that connects to the hub bearing?
I ask, because I do know that when that is not connected on a cummins truck the 4wd system will no longer work. Not sure if that is the case on our power wagons.
Post by Retired BLM Rig » Sun Jan 28, 2018 12:43 pm
The engine started completely normally with no additional actions required. O'reilly's shows Part # ABS3028 for $70.99. I'm sure you could find it cheaper somewhere else. I don't know the O.E. part#. It will be less $ on Amazon or Ebay.
Somebody just needs to unplug it and test the driving results before buying a sensor. It may not work due to yaw sensor input.
Post by Retired BLM Rig » Sun Jan 28, 2018 12:58 pm
Yes, hub bearing wheel speed sensor.
The 4X4 has to work on our trucks because we have a manual transfer case shifter. It may be a different story with an electric T-case or CAD.
So imagine that you're driving on your hilly unimproved property in 4Lo and you snag your harness on a piece of brush and the result is that you lose 4X4 function. That would suck! :angry:
Post by olyelr » Sun Jan 28, 2018 1:47 pm
Yes. It is a bunch of shit. We broke one on my buddys cummins truck while we were doing ball joints. He almost couldnt get out of my dads shop because there is a big hill and it was snow covered and slick. It was rediculous.
Although we do have a manual tcase, dont forget us guys with modern pw’s do have a CAD. The fact that pulling the fuse for the systems still allows the use of 4wd, I would think this mod wouldnt render our 4wd system useless either. We will soon see :D
Post by TwinStick » Mon Jan 29, 2018 7:42 pm
Even though we have a manual t-case, there is still a t-case position sensor. Is the TCPS ONLY for our lockers or would it also prevent 4wd if a WSS got snagged as you say ? I am curious.
:popcorn:
Post by olyelr » Mon Jan 29, 2018 8:06 pm
:popcorn:
Me too. Let ya know soon hopefully :D
Post by DamageWagon » Mon Jan 29, 2018 9:50 pm
:popcorn:
Only the ‘Best Year Power Wagons’ lose 4WD when the truck is being used like a truck. Turd gens keep the stupid bullshit limited to their grab handles and interior. :run:
Post by olyelr » Mon Jan 29, 2018 10:15 pm
Hey now, when I pull my ABS fuse my four double-you dee works just fine :poke:
