[/quote]
I don't think so the specs all seem to be very similar to the Toyo MT except the inflated section width showing .6" wider they're identical IF they turn out to be garbage my next set will be back to the Toyo because I've had good luck in the past with them on Wranglers.
Toyo specs Yokohama
Tire Size : 37X12.50R17LT 37X12.50R17LT
Load / Speed: 124Q 124Q
Load ID: D D
Tread Depth (1/32"): 21 21
App. Rim Width(in.) : 8.5-11 8.5-11
Weight (lbs.): 84 76
Infl Diameter (in.): 36.8 36.8
Infl Width (in.): 12.5 13.1
Max Load (lbs.): 3525 3525
Max Pressure (PSI): 50 50
Revs Per Mile: 565 565
https://www.yokohamatire.com/tires/geolandar-m-t-g003
https://www.toyotires.com/tire/pattern/ ... tion-tires
