Forum Move Discussion Here
Re: Forum Move Discussion Here
Just an FYI this dolphin phone browser is very good phone browser and once the learning curve of double tapping the screen to zoom to a thread and the use of the tabs becomes the norm then I think it works great. And its free too!
http://dolphin-browser.com/
It also accepts the Last Pass add on that secures your passwords on your phone. The PC version is free but for use on your phone it is $12 a year for the LastPass Premium Only Features.
https://lastpass.com/
Ken
PS: I also think an IPhone and Android apps section may be helpful as there are may coll apps for our forum and PW needs.
Ken
- VA_Wagon Man
Old Gunni is jumping the gunni..........
SHHHHhhhhhhh.....................................
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
Just added a Gadgets, Gizmos and Gear topic area under Miscellaneous category (go to the Board Index to see) where I started a SmartPhone apps thread.azracer wrote:PS: I also think an IPhone and Android apps section may be helpful as there are may coll apps for our forum and PW needs.
2023 Power Wagon
Previous Truck
Previous Truck
- VA_Wagon Man
I saw that. It's coming together nicely.ldgregory wrote:Just added a Gadgets, Gizmos and Gear topic area under Miscellaneous category (go to the Board Index to see) where I started a SmartPhone apps thread.azracer wrote:PS: I also think an IPhone and Android apps section may be helpful as there are may coll apps for our forum and PW needs.
Long Gone:
Looks like the cat is out of the bag DT is down and I suspect they are going to retaliate.
Sure hope you guys got the stuff you needed as it may just be possible we will be locked out.
We may be able to register again but using a new ID and IP only I suspect.
Could be a false alarm but they have been watching us close as of late and someone not not naming names seems to have fully put them on alert.
- VA_Wagon Man
Here is what they say:
http://www.dodgetalk.com
18:30 pm (EST)
DodgeTalk.com is currently down for maintenance while database repairs are being conducted.
We should be up in approximately 1 hour.
We will provide an update at around 19:30 pm (EST) if needed
Thanks for your support!
DodgeTalk.com team
As soon as it came back up, I could log on just fine.
Long Gone:
Gunni!!!! Bad boy! Go stand in the corner! You're in time-out mister!azracer wrote:Looks like the cat is out of the bag DT is down and I suspect they are going to retaliate..
Well, it was bound to happen sooner or later. Start tagging people in PMs as much as you can if you haven't already.
2023 Power Wagon
Previous Truck
Previous Truck
I think it would be silly of them to do something like that and block/delete all of those threads and people because we decided to " follow their rules" and take it somewheres else such as this forum, or do business away from the forum. We are just simply following their rules. Besides, they have other members there that belong to other forums and are either moderators and/or administrators away from DT. At best it would be Holocaustic in a sense, where as they would be doing a partial genocide of their forum, eliminating folks who had decided to join another forum or simply move on. What kind of example would that have on them? It wouldn't reflect well on their part in my opinion. We wanted to do things a little different here, while not worrying about what our views are going to be perceived as out of order or unacceptable. If they are understanding, as I have no reason to believe they are not as of now, they will leave things as they are. There are alot of threads on there that could be thought as or bend into thinking they are not acceptable. There is no excuse to let them be there otherwise they could be perceived as not doing their job. An example is why a t-shirt sale is ok and info about a snorkel is not ok? It seems a bit odd in my opinion. I could bend it and say it's border line dictatorship but whatever it is actions speak for themself. I would think it would be in the best interest of DT to let things be the way they are. I don't dislike them I just find it better on here and more fitting for my style.azracer wrote:Looks like the cat is out of the bag DT is down and I suspect they are going to retaliate.
sent using outdated Bell Labs equipment via Tapatalk TOO
I found out about this forum on DT catus red had a link to it...so what...In the words of Kurt Cobain"oh well, what ever, never mind"
I didn't read every post in this thread...but I hope you guys can get the freq ask/mod thread from DT...you guys are doing a good job, and I thank you. Ben
- VA_Wagon Man
Very true Pit. Your perspective is probably pretty accurate. We'll just take slow, and try to get our info over here asmuchas we can.Pit Slave wrote: I think it would be silly of them to do something like that and block/delete all of those threads and people because we decided to " follow their rules" and take it somewheres else such as this forum, or do business away from the forum. We are just simply following their rules. Besides, they have other members there that belong to other forums and are either moderators and/or administrators away from DT. At best it would be Holocaustic in a sense, where as they would be doing a partial genocide of their forum, eliminating folks who had decided to join another forum or simply move on. What kind of example would that have on them? It wouldn't reflect well on their part in my opinion. We wanted to do things a little different here, while not worrying about what our views are going to be perceived as out of order or unacceptable. If they are understanding, as I have no reason to believe they are not as of now, they will leave things as they are. There are alot of threads on there that could be thought as or bend into thinking they are not acceptable. There is no excuse to let them be there otherwise they could be perceived as not doing their job. An example is why a t-shirt sale is ok and info about a snorkel is not ok? It seems a bit odd in my opinion. I could bend it and say it's border line dictatorship but whatever it is actions speak for themself. I would think it would be in the best interest of DT to let things be the way they are. I don't dislike them I just find it better on here and more fitting for my style.
Long Gone:
I would tend to agree but with the dealings I have had with the mods I'm now sure the Orange crush baby power wagon thread relocation was retaliation and not the letter of the law.
I just think going slow and tagging the info you guys want far outweighs any fun that could be had posting hints and such in the DT forums. Just sayn is all.
- VA_Wagon Man
"Thumbs - Up"azracer wrote:I would tend to agree but with the dealings I have had with the mods I'm now sure the Orange crush baby power wagon thread relocation was retaliation and not the letter of the law.
Long Gone:
- GunniPWguy
Sorry Man. Did not realize it was supposed to be a secret. Just for the record someone else spilled the beans before I did.ldgregory wrote:Gunni!!!! Bad boy! Go stand in the corner! You're in time-out mister!azracer wrote:Looks like the cat is out of the bag DT is down and I suspect they are going to retaliate..
I was messing with ya. Don't worry about it. We pretty much got all the really active and long time members moved over anyway. At this point we're just picking up the stragglers. Im not worried about getting banned, I'm just worried that content will go missing from there. We have a whole lot of historical content there. Would be a shame to lose it.
2023 Power Wagon
Previous Truck
Previous Truck
- GunniPWguy
No doubt! I need that content.ldgregory wrote:I was messing with ya. Don't worry about it. We pretty much got all the really active and long time members moved over anyway. At this point we're just picking up the stragglers. Im not worried about getting banned, I'm just worried that content will go missing from there. We have a whole lot of historical content there. Would be a shame to lose it.
If you haven't been contacting stragglers, by all means, please do. Below is what I've been sending folks..
I'm Leif Gregory, owner of the Power Wagon Registry.
A bunch of us have gotten together and ultimately decide to move the forum to a new location with much less restrictive rules and co-locating the 3rd and 4th gen PWs into a single location instead of split like we are now. We most likely won't be able to move content from DT because even if I could get DT to agree to give me the database, we're running on two different forum platforms and there's not a migration path. Secondly, the posts are copyright to the original poster and we'd need a whole lot of permission slips so to speak.
At any rate, I'd like to invite you to join the new forum at http://forum.powerwagonregistry.org
Please don't make any general announcements on the DT forum. We're not quite sure how DT will react to us leaving and we don't want them to retaliate by banning people or deleting content. Also, I apologize if you have received this more than once. I didn't think to keep track of who I already contacted and other people who have already moved might also send you a similar invite. Please spread the word via PM to other PW owners when you have time.
Thanks and hope to see you there soon.
2023 Power Wagon
Previous Truck
Previous Truck
Just letting everyone know that I am here. On DT I was PWDurangoFam, here I will be Glenn5995. I appreciate the e-mails and PMs on DT about the move, so I thought I would check in.
Missed you in Moab this year, but glad you made it over to the forum.
2023 Power Wagon
Previous Truck
Previous Truck
- Cactus Red
Yeah, I did post that all future updates to the Cactus Red mod thread would be over here. I also have done over 60 PM's in the last couple days, and I'm sure that shows up as well...GunniPWguy wrote:Just for the record someone else spilled the beans before I did.![]()
- Powerwagonmark
I wouldn't be surprised if the DT gestapo was sneaking a look at our PMs.
2008 Dodge POWER WAGON
- GunniPWguy
Should've gone with Mr. Clean!Glenn5995 wrote:Just letting everyone know that I am here. On DT I was PWDurangoFam, here I will be Glenn5995. I appreciate the e-mails and PMs on DT about the move, so I thought I would check in.
- SilverWagon05
I was just over at that other site, checking things out. Read through Gunni's spill the beans thread. You all are a bunch of funny bastards. That was pretty funny.
Did you read what I posted? LMAOSilverWagon05 wrote:I was just over at that other site, checking things out. Read through Gunni's spill the beans thread. You all are a bunch of funny bastards. That was pretty funny.
The bad part about this move is. Now I have ALOT of reading to do to catch up on this forum, and how everything works here. And I'm way behind.
Oh, I just LOVE this.
