Air box mods
Easttnrhino
Air box mods
Post by Easttnrhino » Fri Apr 14, 2017 3:24 pm
On the 6.4 is there any mods where it draws through fender or to box itself to help airflow at WOT. Thanks
Enjoying beautiful east TN
Re: Air box mods
Post by Reloaderguy » Fri Apr 14, 2017 5:38 pm
The factory airbox does draw through the inner fender.
Re: Air box mods
Post by OffroadTreks » Fri Apr 14, 2017 7:41 pm
Yea, just gotta cut a hole in your fender.
Re: Air box mods
Post by nts007 » Fri Apr 14, 2017 8:30 pm
A bigger hole will allow more air flow. Also you can make cardboard wind deflectors to enhance the flow direction using masking tape to hold them in place.
Re: Air box mods
Post by OffroadTreks » Fri Apr 14, 2017 11:01 pm
It works really well. Gained like 10HP
Re: Air box mods
Post by nts007 » Fri Apr 14, 2017 11:01 pm
The proof is in the pudding^^^^^^^
Easttnrhino
Re: Air box mods
Post by Easttnrhino » Sun Apr 16, 2017 11:12 am
Inside of airbox is this to reduce noise?
Calvinm119
Re: Air box mods
Post by Calvinm119 » Sun Apr 16, 2017 3:11 pm
You can also use a 3 in hole saw to cut out an airway at the bottom of the airbox and run airduct hose from the hole to the to the front of the vehicle. You'll need to buy a few things to make it look cosmetically good. I did that on my last truck and it worked pretty good.
Gone but never forgotten:
2006 Dodge Ram Power Wagon
Re: Air box mods
Post by OffroadTreks » Sun Apr 16, 2017 3:49 pm
My Airbox already had an inlet that ran into the fender on my 2015. Before even adding the AEV intake.
Rodeoflyer
Re: Air box mods
Post by Rodeoflyer » Sun Apr 16, 2017 10:15 pm
Easttnrhino wrote:Inside of airbox is this to reduce noise?
More likely for airflow control. Probably a good thing.
Re: Air box mods
Post by nts007 » Sun Apr 16, 2017 11:02 pm
Or a place to attack a shop vac hose to
