That's about the avg cost Ive been quoted in my area....
What you guys been payin for these?
Reloaderguy wrote:Good job numbnuts.
That is a factor of control arms and wheels. If you are rubbing the fender liner, cut out the section you need. If you are rubbing control arms or pinch welds, that is a control arm length or wheel offset issue.Numbnuts wrote:Reloaderguy wrote:Good job numbnuts.Thx Loader.....I don't reload but I do quite a bit of competitive pistol shooting...someday I will reload tho.
On a stock height 2011 PW these 35x12.5x17 R/T Toyos DO RUB at almost full lock
So If anyone thinks that they don't rub at STOCK HEIGHT they are incorrect.
https://www.thurenfabrication.com/tech/ ... tment.htmlNumbnuts wrote:I wish it were the fender liner. The control arms are rubbing. How is this resolved?
DamageWagon wrote:Olyelr you could weld something onto the steering stops. They are not adjustable on our trucks like they were on the old Dana 60's. The extended u-joint life is a perk! hahahaha
