Fuel Filter? Zo dumb to find?
CombatWombat
Post by CombatWombat » Thu Mar 30, 2017 11:08 am
Hello
I want to Change my Fuel Filter on my 2009 PW.
In my other Cars i had thrown away all the Stock Filters and reroutet the Fuel Line so i can fit a easy maintainable Fuel Filter.
But....
I cant find the Filter on my Powerwagon?
Where can i find that sneaky Bitch?
Or....isnt there any?
You can go fast.
I can go anywhere.
Dodge Powerwagon
Re: Fuel Filter? Zo dumb to find?
Post by TwinStick » Thu Mar 30, 2017 11:11 am
Fuel filter is in the tank as far as I know. Like a screen/sock over the fuel pump, IIRC.
https://www.youtube.com/watch?v=saMh3Cgn-9Y
Now this shows a separate one on the frame rail.
https://www.google.com/search?q=Where+i ... 40&bih=791
Keep us posted please.
CombatWombat
Post by CombatWombat » Thu Mar 30, 2017 1:18 pm
No Filter exept this retarded placebo Mongoloid Sock???
Mhhh.
You can go fast.
I can go anywhere.
Dodge Powerwagon
CombatWombat
Post by CombatWombat » Thu Mar 30, 2017 1:20 pm
The google search also shows a Diesel Filter on the Framerail.
Not for us Gassers....
You can go fast.
I can go anywhere.
Dodge Powerwagon
Post by coder » Thu Mar 30, 2017 1:37 pm
Hello CombatWombat, it's not considered a maintenance item on your vehicle no need to change it.
Post by OffroadTreks » Thu Mar 30, 2017 3:29 pm
Yea there wasn't an external one on my 2010 5.7 Hemi either. It's not a maintenance item. The days of fuel filters are passing. Used to be something back in the day you'd change after like 100k.
Post by cruz » Thu Mar 30, 2017 9:31 pm
coder wrote:Hello CombatWombat, it's not considered a maintenance item on your vehicle no need to change it.
X2 what coder said, unless you really think you have a problem ...
CombatWombat
Post by CombatWombat » Fri Mar 31, 2017 6:56 am
Thanks for your Answers.
Will find a Way to cut in the Fuel Line and build a bracket for a Filter....somewhere under the Bed i think is enough Room.
You can go fast.
I can go anywhere.
Dodge Powerwagon
Post by Bill2014 » Fri Mar 31, 2017 7:48 am
CombatWombat wrote:Thanks for your Answers.
You can go fast.
I can go anywhere.
Dodge Powerwagon
What type of issues are you having that you require a fuel filter?
CombatWombat
Post by CombatWombat » Fri Mar 31, 2017 11:08 am
Will prevent issues.
My Fuel Filters are black inside after about 25000km on my other vehicles.
So there is definately Dirt in the Fuel.
So without filters all the dirt goes throu the injektors.
I dont want that
You can go fast.
I can go anywhere.
Dodge Powerwagon
Post by RustyPW » Fri Mar 31, 2017 10:42 pm
No outside the tank fuel filters on fuel injected vehicles for a long time. All have been inside the tank. Some look like a sock, others may look like a flat square or round pancake. If you are planning on adding a outside the tank fuel filter. Be careful, because you are dealing with fuel pressures over 50 psi. Some systems are at 100 psi. A plastic filter will not handle the pressure. If you just cut the metal tubing and slip rubber hoses over the ends, and use hose clamps. Chances are that it will leave you walking. The pressure will push the rubber hose off the tubing. Seen it happen. :lol:
Post by Bill2014 » Sat Apr 01, 2017 7:35 am
CombatWombat wrote:Will prevent issues.
I dont want that
You can go fast.
I can go anywhere.
Dodge Powerwagon
If you truly have "dirty" fuel, then fix that by getting your fuel somewhere else and solve this problem at its source. This is a much better and safer solution than trying to add an external filter. :cheers:
verdesardog
Post by verdesardog » Sat Apr 01, 2017 10:21 am
I have an external 2 micron fuel filter on my ctd...larger than a typical gasser oil filter. Of course the injectors on a high pressure common rail diesel are subject to much more abuse than a gasser.
Post by Colibri » Sat Apr 01, 2017 10:28 am
I've looked into doing this myself, the cleanest method I've come across is using a -AN to pushlock adapter either at the tank or the fuel rail and plumbing an inline filter between the stock line/components or if you want to go completely overboard do an aftermarket fuel system from fore innovation, starting with dual pumps in the oem position and run forward with -AN hose and billet fuel rails etc.
-AN to factory style connection
Inline filter
Cool guy billet dual pump assembly
Fore innovation complete fuel system
