Boogie bump stops AND Airbags
Post by TankerZak » Thu Mar 09, 2017 11:20 pm
So I'm putting on the Air Lift 5000 Ultimates with the internal jounce and the Daystar cradles. That has to happen because of my trailer weight (removing Timbrens). So that decision is a lock and its already in my garage.
I was reading about the boogie bump stop replacements and they sounded interesting BUT i could only do the front. Any point in even doing that if i can't do the rears also? Would the airbags balance it out some or pointless mod?
Re: Boogie bump stops AND Airbags
Post by Colibri » Thu Mar 09, 2017 11:38 pm
Front bumps see a lot more action than the rears because of the nose heavy nature of our trucks. Get the boogies up front and install your bags out back and you should be good to go unless you chase in Baja :rockon:
Post by Low_Sky » Fri Mar 10, 2017 11:34 am
Agreed. Worth it even if you can only do the fronts. (From a future boogie bump owner that is tired of contacting his front bump stops).
Post by OffroadTreks » Fri Mar 10, 2017 12:16 pm
Where are you guys getting them? I only found them for up to 2012 2500's on CJC...
Post by DamageWagon » Fri Mar 10, 2017 12:38 pm
Buy straight from Don
Post by olyelr » Fri Mar 10, 2017 1:05 pm
MikeKey wrote:Where are you guys getting them? I only found them for up to 2012 2500's on CJC...
Yea Don has them listed on his website. Can buy them with a full kit or can purchase separately.
https://www.thurenfabrication.com/produ ... stops.html
Post by TankerZak » Sat Mar 11, 2017 1:02 am
I take it we need the 1-3 inch lift set? With appropriate front mounting bracket?
Post by olyelr » Sat Mar 11, 2017 9:41 am
TankerZak wrote:I take it we need the 1-3 inch lift set? With appropriate front mounting bracket?
Yes and yes. Well, 0-3" lift.
Post by olyelr » Sat Mar 11, 2017 9:42 am
Not a power wagon and not a new ram, but this is the jist of it
https://m.youtube.com/watch?v=w0U-mqmCk-8
Post by OffroadTreks » Sat Mar 11, 2017 11:05 am
olyelr wrote:Not a power wagon and not a new ram, but this is the jist of it
Thanks that video was perfect. :cheers:
Sadly everything on this truck is just as pricey as buying stuff for my Corvette. I thought it would have been cheaper. :angry:
Post by olyelr » Sat Mar 11, 2017 2:50 pm
Cant leave the vette well enough alone either, eh :lol:
Post by OffroadTreks » Sat Mar 11, 2017 6:02 pm
olyelr wrote:Cant leave the vette well enough alone either, eh :lol:
I have to many things to spend money on. I'm just trying to spend it all before my girls are teenagers.
Post by olyelr » Sun Mar 12, 2017 9:48 am
:lol:
