!!!WHEELS!!! for the Power Wagon
Re: !!!WHEELS!!! for the Power Wagon
So I'm kinda confused about the legality of beadlocks fit Street use...
My understanding is that to have a DOT legal beadlock you have either:
1. Have a beadlock that can also transition back to a standard type wheel. You also have to have it transitioned for street use when on the street. Meaning it is installed over a lip on the inside like a normal wheel.
2. You have to have a double-beadlock, which is a standard beadlock but also includes a loner inside the wheel the acts as a crush sleeve to pinch the tire. This method goes beadlock-tire-inner beadlock-tire-fixed side of wheel. I think his is the method that Hutchinson uses to make their beadlocks legal. This is the same method used in my HMMWV wheels (I believe made by Hutchinson)
You may be right but for one exception: Centerline ICE wheels were DOT approved and I don't think they met either criteria. (maybe they could be run without the locking portion? But, I doubt it, they were designed to be used by the military on road and off with the locking ring in place. (they only lock the outer bead) They were sold for civilian purchases for a few years but were nearly $700 and HEAVY!!! They were stout though, forged!!!)DamageWagon wrote:My understanding is that to have a DOT legal beadlock you have either:
For years I've debated buying the Staun internal beadlocks. The inflatable ones that can act as a run flat. I still would likely go that route vs a dedicated beadlock
If just for cost reasons, both initial purchase and replacement cost when I break a wheel, I like the idea of those inflatable ones. I wonder how much of a pain they are to install, but it seems like a very good idea. You can get pressures pretty low with them. I'm not sure if they work for the primary purpose I would want though. If you were rock crawling they would be great, although not quite to the lowest pressures you can achieve with real beadlocks. My concern and want for beadlocks is when I'm aired down, going fast and come into a turn or hit a rut, and the tire pops off the bead and gets pushed in towards the middle of the wheel. I'm not sure that those inflatable ones would really help as much there. Really you would need a double-beadlock to save you there though, and only the real HHMWV wheels use that. And the ones I have are 17lbs per wheel, just for the inner beadlock... Pipe dreams.nts007 wrote:For years I've debated buying the Staun internal beadlocks. The inflatable ones that can act as a run flat. I still would likely go that route vs a dedicated beadlock
For me I don't deflate for any high speed stuff. I only air down for technical type where flotation and grip are key so for me the Staun ones always seemed best. And I don't think they would be that hard to install and could be swapped from wheels to new ones later
For the stauns you have to drill your wheel to accept a secondary valve stem. Trailready makes double Beadlocks by using an inner clamp ring of the same design as the outer, the hutchinsons are functionally identical to the hhmwv military wheels in design
I saw a set of 20" car rims the other day at tire shop and they are double drilled!??!?? One hole is for a stem with stock tpms and the other is a filler. So one is in the middle of the rim. It says on them if tpms un used then just put in a standard stem. Lol. No problems drilling a new hole for the Staun stem
That's weird about those car wheels lol. Of course you're not put off by drilling your wheels, you're a crazy badass Canuck
These two wheels are already drilled for dual valvestems. Sharp looking wheels, I'm contemplating them. There are others by other manufacturers as well!
http://www.discounttire.com/en/buy-whee ... 8l/p/77799
http://www.discounttire.com/en/buy-whee ... ug/p/77778
Ducky's Dad
Technically, if you want to be street legal, your beadlocks will have to carry DOT approval. But as with offroad lights, the chances of getting caught are minimal if you don't do stupid things. If you do get caught, it's a fixit ticket around here (CA), but then you still need another set of wheels/tires to get the ticket cleared. There are a few (very few) aftermarket wheels with DOT approvals, but rather expensive. And some tire shops won't mount or balance true beadlocks.
Black Rhino has some pretty cool wheels for the 2500. The Warrior is the best IMO.
http://www.blackrhinowheels.com/off-roa ... arlord.php
Razorback is also very cool.
http://www.blackrhinowheels.com/off-roa ... orback.php
2018 RAM 2500 Power Wagon
The Tracker Pro 8 look great. I love the classic look.RAM4ROKS wrote:These two wheels are already drilled for dual valvestems. Sharp looking wheels, I'm contemplating them. There are others by other manufacturers as well!
Here's a link to some 17 wheels. Replicas...
http://www.hubcaphaven.com/p/24039/2017 ... hined.html
The factory rims are nice enough that it's one of the few stock wheels on vehicle I have no intention of replacing. Although if I did, the only wheel I would ever consider is the internal bead lock Hutchinson Rock Monster Wheels:
http://www.rockmonsterwheels.com/produc ... duct=dodge
http://www.hutchinsoninc.com/CMS/index. ... y-Beadlock
I would love a set of Hutchinsons, I wish I would have bought them back when I first looked at them, they used to be $400, now they are $483 or so!Zybane wrote:The factory rims are nice enough that it's one of the few stock wheels on vehicle I have no intention of replacing. Although if I did, the only wheel I would ever consider is the internal bead lock Hutchinson Rock Monster Wheels:
Hammerballs
I like these wheels a lot but are they an appropriate backspacing for our trucks? I have a 2016 Laramie PW. I get confused with backspacing and offset. If these have +.39" of offset and are 8.5" wide then does that mean they have about 4.6" of backspacing? Don't our factory wheels have something like 6" of backspacing?RAM4ROKS wrote:I would love a set of Hutchinsons, I wish I would have bought them back when I first looked at them, they used to be $400, now they are $483 or so!Zybane wrote:The factory rims are nice enough that it's one of the few stock wheels on vehicle I have no intention of replacing. Although if I did, the only wheel I would ever consider is the internal bead lock Hutchinson Rock Monster Wheels:
2016 Laramie Power Wagon
I talked with this guy about his Hutchinsons, and all he could do was praise them.
Hammerballs
That truck looks exactly like mine. I would go black wheels though to go with the black bumpers and rock sliders I'm adding.olyelr wrote:I talked with this guy about his Hutchinsons, and all he could do was praise them.
Does Hutchinson make different offsets than what is listed on their site? -10mm is about 1" too much offset.
Im not sure.Reloaderguy wrote:Does Hutchinson make different offsets than what is listed on their site? -10mm is about 1" too much offset.
This site shows them with 4.5" of backspacing, which I agree would be too much offset http://www.filthymotorsports.com/Hutchi ... hinson.htm
This site shows them with 5.28" of backspacing, basically +10mm offset. Wouldnt that be about ideal? http://rockmonsterwheels.com/products.php?product=dodge
If the factory wheels are 8" wide with 6" of backspacing, one set would be sticking out about 2" farther than the stockers and the other would be sticking out about 1.25" farther than the stockers. I think
Given how they look on one of our trucks (including at least two Ram concept trucks that I have seen with them) my guess would be that the 5.28" backspacing is more likely correct. If I can figure out a way to swing the $$$ would love to have a set!!!! Should be just enough to get my tires off my control arms without going super wide and requiring body cutting!
They have multiple options not really listed on their website, I'm running the 5.28" backspace with 37x13.50 toyo mt's and they work awesome. Zero rub with 35's ever and minor rear wheel well trimming for the 37's on my 3rd gen. Can not praise them highly enough.
My Centerline wheels are 17x9 with 5.25" BS. With 35" Toyo's. They barely rub my stock control arm on my 3G.
Which concepts please?RAM4ROKS wrote:Given how they look on one of our trucks (including at least two Ram concept trucks that I have seen with them) my guess would be that the 5.28" backspacing is more likely correct. If I can figure out a way to swing the $$$ would love to have a set!!!! Should be just enough to get my tires off my control arms without going super wide and requiring body cutting!
