Bill2014 wrote:Maybe that's my Kitchen...
Maybe I'm you and this is Fight Club?
Reloaderguy wrote:A kill-switch for electronic nannies.olyelr wrote:Reloaderguy wrote:
Looks like your in my kitchen.
Whatya got cookin?
DamageWagon wrote:Do all three of you have the same counter?
Sent from my safe space
I'm not actually going to use that switch. I bought it and then decided this is going to be much more stealth and warranty friendly. All of the wiring is complete, I had to use a little silicon to support a very small part in the fuse box so I'm just waiting for it to dry.olyelr wrote:
Well damn i almost guessed that!
Keep us updated...
Reloaderguy wrote:I'm not actually going to use that switch. I bought it and then decided this is going to be much more stealth and warranty friendly. All of the wiring is complete, I had to use a little silicon to support a very small part in the fuse box so I'm just waiting for it to dry.olyelr wrote:
Keep us updated...
Have you ever noticed that if you only have one or two garage doors that you have an extra homelink button or two? How about a remote switch programmed to the Homelink that triggers a 30A NC relay that plugs into the OE fuse port. The whole setup installs with a positive and negative nut. The relay and remote switch are attached with velcro to the side of the fuse box and the entire setup removes in two minutes.
Colibri wrote:That sir, is some James Bond shit right there
Retired BLM Rig wrote:I snapped these pictures before I left work today. The newest schematic diagram I could find was for a 2015. It looks like the ABS ground wires are connection #G802A and it looks like it is located somewhere on the drivers side frame rail below the ABS unit or battery or fuse box.
Gee, I wonder what would happen if a guy interupted those ground wires? I wonder if a guy would have to push the start button twice to start the truck? I wonder if anything else shares that ground connection? I wonder if the ABS light would turn off by itself after it was reconnected?
Golly, if I only had a 15 or newer truck with a warranty, maybe I could figure it out.
