HD Lift Parts: 2" Front, 1.5" Rear
I un-lifted the truck this weekend and will be going with a stock size tire. Several reasons for this, but there is nothing wrong with these parts and they worked great. The have only been installed a few thousand miles. Both are from Top Gun Customz. $50 for 2" front spacer and $80 for the 1.5" rear spacers or both for $120 shipped. These will run you $185 new.
- VA_Wagon Man
Re: HD Lift Parts: 2" Front, 1.5" Rear
My rear blocks are double pin, yours look like single pin. Am i missing something?
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
These have a single pin on one side and three holes on the other. Don't remember which way is up...
If these will work on an 06 with everything else stock I will take them.
The blocks are sold but the front spacers are still available. And yes, they will work on an 06.
I was hoping for the set, now I am trying to picture what the truck will look like with the lift up front and the stock height in the rear. Let me put a jack under it tonight (or first thing in the morning if it is dark when i get home) and see what it looks likemyoung84 wrote:The blocks are sold but the front spacers are still available. And yes, they will work on an 06.
Any one have photos of there truck with 2" up front?
I've got about 3" of rake, so with the front lifted 2" you'll still have a little rake but it will appear to be very close to level. When I installed the lift components, I did the front first and it looked good. Only reason I did the rear was to get my rake back so I'm not nose high when towing. With my ATV in the bed and boat hitched up I'm close to 1200 lbs, which drops me about 2.5".
