"Frankenwagon" short and sweet.
Re:
When are you going to do a linked rear with coilovers?
Re: "Saggin wagon" short and sweet.
At the rate he makes changes? September.
Re: "Frankenwagon" short and sweet.
:/2wagons1driveway wrote:Hahahaha exactly. Can an admin change this title to frankenwagon? Hahaha
Haha thanks man! Hey Tim a bit of bent tube?!?! And it's in the wrong spot as we discussed already haha but hey it's dropping out okay but some stuff has to be cut and moved "probably"
I'm referring to the bent pipe from
The rear mount up to the main cage beside the shock unfortunately the shock angle and the bypass tube looks like it's going to contact at full bump or before so that will
Probably have to be cut out and a new section made that being said all in all everything looks better with some shock angle etc!
Sent from Canada
Sent from Canada
Since Lee is a little too busy to be on here with an update, I'll just leave this bit here....
https://www.instagram.com/p/BKO_YJEAwcK/
Re:
Check your park brake cable and locker as well as ABS wires for being stressed and needing to be extended or rerouted. Also check drive shaft clearance at the skid plate cross brace. I had issues with my wires, park brake cable and drive shaft hitting the cross brace.
because I'm a 6" lift already a lot of that stuff had already been clearanced years ago right cause I previously had about 13" of wheel travel and now I'm around 20" but a lot more up travel than before (approx 3") so a lot is all good that being said with that much travel we got to watch for weird one off shit! Lol I'm posting some videos of testing newest bed cage design!azracer wrote:Check your park brake cable and locker as well as ABS wires for being stressed and needing to be extended or rerouted. Also check drive shaft clearance at the skid plate cross brace. I had issues with my wires, park brake cable and drive shaft hitting the cross brace.
Sent from Canada
Re:
Your driver side taillight busted up a bit. Is there a story for that one too?
yes lol went out with the localnts007 wrote:Your driver side taillight busted up a bit. Is there a story for that one too?
Pre runners club and I was behind leader on a hard charge... Missed a turn that wasn't called out that was 75* and slopped to the downwards left... And it was a right then... So hitting that fresh gravel at 120kmh my rear end locked up and I said fuck it I'll ride it out so turned into the ditch then just kinda gently slid into a fence after sliding for 70' sideways .... Tail light only broke when I put truck into reverse lol
Sent from Canada
Hahaha, now I know you have the same luck as me. Stupid fence post took out my tail light after backing up into it. What made it worse the truck was still brand new when I did it. Now I'm like whatever. lol2wagons1driveway wrote:yes lol went out with the localnts007 wrote:Your driver side taillight busted up a bit. Is there a story for that one too?
Sent from Canada
lol exactly at this point eff it. I enjoy the truck too much to worry about little stuffPit Slave wrote:Hahaha, now I know you have the same luck as me. Stupid fence post took out my tail light after backing up into it. What made it worse the truck was still brand new when I did it. Now I'm like whatever. lol2wagons1driveway wrote:yes lol went out with the localnts007 wrote:Your driver side taillight busted up a bit. Is there a story for that one too?
Sent from Canada
Sent from Canada
Re:
Ummm! Like the truss! You need a cab cage asap! You have moved into an entirely new level!
I don't think I'm going to do one anytime soon. When someone makes a nice WIY kit I would think about it but honestly I'll just pick my lines a bit better and remember I'mazracer wrote:Ummm! Like the truss! You need a cab cage asap! You have moved into an entirely new level!
Not in a trophy truck
Sent from Canada
- NovA ProspekT
Re:
Fixed it for you.2wagons1driveway wrote:I don't think I'm going to do one anytime soon. When someone makes a nice WIY kit I would think about it but honestly I'll just pick my lines a bit better and remember I'mazracer wrote:Ummm! Like the truss! You need a cab cage asap! You have moved into an entirely new level!
Not in a trophy truck yet
Sent from Canada
You're trucks just about at that point.
Lol ya it's pretty fun right now and I'm holding back on super charging it because that would push it alittle over the edge I mean it is what it is it doesn't like to stop or turn now so fuck it would be gnarly with another 150hp hahha
I really like the d ring mounts they mean business they are massive and doubled up. I am adding a winch fairlead brace plate out of 1/4" between the frame horns to increase the strength and side to side load it may experience during winching at the extremes. I will probably leave the light mount open to access the winch fairlead and block heater etc.
Re:
Oh shit! So much win right there lee, your front end is going to look killer!!!
Sent from Canada
Sent from Canada
Dead gorgeous super happy it's gracing my trucks front end now!
Sent from Canada
Fender liners trimmed!
Sent from Canada
Sent from Canada
- NovA ProspekT
Re:
Meh, it looks OK...needs more clearance though...
...but seriously, that's awesome..
Should be quite a difference in weight as well, eh?
Oh, and im sure you left room for an intercooler? You know, for the turbo's.
haha There's a bit of room there?!?!NovA ProspekT wrote:Meh, it looks OK...needs more clearance though...![]()
Sent from Canada
https://vimeo.com/195141229 got some boogie time in with the frankenwagon a few weeks ago. Taking atv whoops like a champ. https://vimeo.com/195141385
Sent from Canada
Sent from Canada
- Powerwagonmark
Re:
Are you in Ontario??
2008 Dodge POWER WAGON
hey man sorry I'm from Ontario I live in Edmonton now!Powerwagonmark wrote:Are you in Ontario??
