For those of you who have the 4th Gen Locker By-Pass
So I have the first 4th Gen Locker By-Pass that Morgan sold sitting in a box and never installed sitting on a shelf in my garage collecting dust, and I'm still up in the air on installing it. I know all the pros to the by-pass, but my biggest concern is having somebody flip the locker switch and screwing stuff up once its installed. Has anybody with the kit ran into any issues that made them wish they hadn't installed it?
- Low_Sky
Re: For those of you who have the 4th Gen Locker By-Pass
If you accidentally bump the locker switch, you'll have no problems going in a straight line, and realize what you did and fix it when you try to turn. If you try to turn at high speed with the lockers on accidentally, you'll probably less than pleased with the handling.
If someone else is driving and flips the lockers on, they'll probably realize they screwed up, or hopefully just stop and call to ask what's wrong with your truck when it starts bucking like a bronco when they try to get it to turn.
Yeah, you definitely dont want to install that thing on your truck. Its all sorts of bad.
I will shoot you a pm with my address and i will take if off your shelf for you.
You could remove cartridge fuse J-10 to completely power down the system and eliminate any hazards, then just pop the fuse back in when you're ready to lock up.
This has never been an issue for me. You'd feel the lockers the instant you started to turn and could simply turn them off.04Ram2500Hemi wrote:So I have the first 4th Gen Locker By-Pass that Morgan sold sitting in a box and never installed sitting on a shelf in my garage collecting dust, and I'm still up in the air on installing it. I know all the pros to the by-pass, but my biggest concern is having somebody flip the locker switch and screwing stuff up once its installed. Has anybody with the kit ran into any issues that made them wish they hadn't installed it?
4th gen bypass uses the factory rotary dial.cruz wrote:How 'bout ...
- Stickman
Yea, only down side I see is accidentally turning them on. But I'm basically the only one that drives my truck and it's kind of hard to "accidentally" turn a knob on the dash.
No issues with mine in the several years it has been on the truck.
I think its a slick upgrade. I love the 2 wd and 4 hi and locked option. But....I did on accident, leave mine on for an hr after a little Pismo action and Everything seem to be ok.
Very well made product.
Wish I hadn't installed it? Absolutely NOT! I love the bypass and the fact that it's instant on/off with no more locker dance! Not to mention, engagement in 2hi, 4hi and 4lo!
2012 RAM Power Wagon
Is someone still selling a bypass for the 4th gens?
2016 Ram 2500 Tradesman Power Wagon - Granite Crystal Metallic
This. Haven't had any luck whatoever getting even a reply about whether they are still being produced.65plymouth wrote:Is someone still selling a bypass for the 4th gens?
2016 Power Wagon SLT, 35"/12.5"/17" Toyo Open Country MT, 2 x Rigid 10" E-Series behind grille, 2 x Rigid Dually on Backrack, Smittybilt D-Ring on hitch, Uniden PRO520XL modded 25 watt CB w/300 watt 'Lil whip, and PA Horn speaker under hood, Mufflex 3.5" mandrel-bent Delete pipe, 84mm rocket launchers, Phased plasma rifle in the 40 watt range lasers and ejection seats coming soon!
