Rear axle locker/limited slip
Easttnrhino
Post by Easttnrhino » Mon Sep 19, 2016 6:23 am
I have read where the early power wagons with the10.5 rear axle had a limited slip when not electronic locked, do the 4th Gen with 11.5 rear have the limited slip when not locked also.
Enjoying beautiful east TN
usmc369
Re: Rear axle locker/limited slip
Post by usmc369 » Mon Sep 19, 2016 6:29 am
yes they have LS in 11.5's, you read wrong.
Easttnrhino
Post by Easttnrhino » Mon Sep 19, 2016 7:11 am
Do you know what type of LS
Post by olyelr » Mon Sep 19, 2016 7:28 am
Post by Bill2014 » Tue Sep 20, 2016 8:00 pm
But don't count on our rear LSD in situations where either wheel has zero traction (ice or up in the air). It won't help at all in those situations - I spent the time and tested it out - the zero traction wheel just spins.
Post by Bill2014 » Tue Sep 20, 2016 8:05 pm
Lots of detail on the subject in this thread:
http://forum.powerwagonregistry.org/vie ... lip#p61465
Post by Low_Sky » Tue Sep 20, 2016 9:07 pm
Bill2014 wrote:But don't count on our rear LSD in situations where either wheel has zero traction (ice or up in the air). It won't help at all in those situations - I spent the time and tested it out - the zero traction wheel just spins.
Helical LSD's need some torque through the drive shaft to lock up. I can feel mine when it hooks up, and I did a test last year with ice under one wheel and gravel/asphalt under the other (I got two skid marks). If you have a tire in the air, that's why we have lockers. My LSD works just fine for most driving conditions.
Post by FirerescuePW » Wed Sep 21, 2016 6:39 am
Ironically, one wheel in the air is probably the situation when the locker would work quickest, as it would definitely see a difference in wheel speed which would allow the actuator to line up and engage.
Takingatrip1
Post by Takingatrip1 » Wed Sep 21, 2016 3:12 pm
Applying the Emergency brake just enough to allow forward movement worked with my limited slip Jeeps. It may help you out of a jam sometime if your locker wont lock up. I havent tried this with the truck yet
'11 Powerwagon
'11 FWC Hawk Camper
