Anyone heard of, seen, or tried the M240 Air Compressor in a .50 cal ammo can w/ complete tire repair kit? It's made by Q-industries, which makes the master flow and super flow line of tools (MV-50/90/150...). Looks like a handy piece of kit, cheaper than the Viair 440 and 450. Spec sheet below states I t's 100% duty cycle for 15min, but also read on Amazon it's a 50% duty cycle, so 15m on and 15m rested?
http://www.specialopstools.com/air-armo ... essor-kit/
http://www.specialopstools.com/content/ ... lsheet.pdf
* The Air Armor M240 is your go to system for tactical portable compressed air, tire care and repair. The core of the M240 powers directly from your vehicle’s battery and delivers air with a 25’ service hose. Keeping you in service is a box of tire parts, tools, and accessories. All this in a tough as nails steel storage locker.
* At the core of the M240 is a 12-Volt, direct drive, high volume air compressor with a 10’power cord that clips directly to your vehicle’s battery. This 40mm powerhouse provides optimal performance in the critical tire inflation pressure range.  Delivering 2.11 CFM you can inflate a full size truck tire in less than 2 minutes and fully inflate a 35” tire from 0-35 PSI in less than 5 minutes.
* The system boasts an instrument panel with built-in air pressure gauge and  type "M" style 1/4" air fitting to attach the unprecedented 25’ straight easy-to-coil air hose with lock-on ball foot commercial air chuck. Airing up has never been easier thanks to an extended 50% duty cycle and hose that reaches all 4 tires of even the longest wheelbase vehicles.
* You won’t be the operator caught dead on the road because you lost a part in the dirt - the M240 has your back. Packed in the accessory box is an arsenal of 27 tire care and repair parts which includes a tire repair kit, 4-way tire valve tool, 2 gauges and an assortment of commonly lost or damaged tire parts like valve caps and cores.
* The M240’s powder coated steel case is rugged enough for use by the military to store ammunition and explosives. This up-armored ammo can features a large folding carry handle, snap latch, and a water resistant O-ring to keep dirt and moisture out. Space to spare allows you to outfit your kit with the tools and accessories you need to be ready for action.
Product Review by Bill Dragoo:
http://billdragoo.com/2015/06/11/air-ar ... ompressor/
