35" tires including spare in factory 2015
dkjager
Post by dkjager » Thu Aug 11, 2016 1:25 pm
Driving a "new to me" 2015 power wagon. Please post feedback on 35" tires on a factory 2015 PW. I'm inclined to go with AEV Katla wheels and Toyo open country Mud Terrain 35 x 12.50 17s. I'd also like to know if a 35" tire, maybe a narrower one on factory rim, will fit in stock spare tire set up. Thoughts appreciated!
2015 PowerWagon
Maximum Steel with Ram Box
37x13.50r17 Toyo MT
American Outlaw Buckshot +15 offset
GoRhino rear bumper
Marathon Seat covers
Traxda 1.5" leveling kit with shock extensions
Thuren adjustable track bar
ADD "PowerWagon" front bumper
Factor 55 ProLink
White Knuckle OffRoad rails
T Rex grill
Re: 35" tires including spare in factory 2015
Post by adeluca73 » Thu Aug 11, 2016 3:53 pm
It's gonna happen, so I might as well start it off:::::::> :excited:
37's.
:winchmob:
Mike Drop!!
:run:
Post by OffroadTreks » Thu Aug 11, 2016 4:24 pm
Toyo Open Country AT/II Xtreme 35x12.50 x17 - Fit perfectly, excellent tire, no rubbing. 2015 Power Wagon, stock otherwise.
Even fits the spare area
Overall very happy with the tire and the looks.
dkjager
Post by dkjager » Thu Aug 11, 2016 4:37 pm
Thank you for the spare photo that was what I was seeking
2015 PowerWagon
37x13.50r17 Toyo MT
GoRhino rear bumper
Factor 55 ProLink
T Rex grill
joeschmidt
Post by joeschmidt » Thu Aug 11, 2016 6:28 pm
adeluca73 wrote:It's gonna happen, so I might as well start it off:::::::> :excited:
37's.
:winchmob:
Mike Drop!!
:run:
Ditto!!
israelstanage
Post by israelstanage » Thu Aug 11, 2016 7:37 pm
35 inch RTs fit rub free on all stock 2015.
65plymouth
Post by 65plymouth » Fri Aug 12, 2016 8:39 am
I have 285/75/17 Cooper ST Maxx and although not as big as the 35's or 315/70/17, they look better than the stock 285/70/17. I am not sure how Mike fit that 35" under the truck. My 285/75/17 fits, but it is super snug. I assume he aired it down a bit, greased it up, and stuffed it under the vehicle with a pry bar! lol. :D
2016 Ram 2500 Tradesman Power Wagon - Granite Crystal Metallic
Post by adeluca73 » Fri Aug 12, 2016 8:44 am
37's.
:winchmob:
Mike Drop!!
:run:
Ditto!!
35's are truly a great choice, probably really the best all around purpose size for our truck....but if you've got $$ for 4.88's or 5.13's---->37's. :poke:
Do it.....
RamGentry
Post by RamGentry » Fri Aug 12, 2016 9:58 am
adeluca73 wrote:35's are truly a great choice, probably really the best all around purpose size for our truck....but if you've got $$ for 4.88's or 5.13's---->37's. :poke:
Drink the kool-aid man...everyones doing it :D
Post by Reloaderguy » Fri Aug 12, 2016 11:00 am
adeluca73 wrote:
37's.
:winchmob:
Mike Drop!!
:run:
Ditto!!
I agree with Dr. D. If you're going to leave your truck stock just go with 35's. If you plan on a little suspension work and maybe gears in the future, 37's are the answer.
Post by OffroadTreks » Fri Aug 12, 2016 11:02 am
65plymouth wrote:I am not sure how Mike fit that 35" under the truck. My 285/75/17 fits, but it is super snug. I assume he aired it down a bit, greased it up, and stuffed it under the vehicle with a pry bar! lol. :D
Almost. It has 18psi of air in it. And I used my foot to jam it in there. It fit though. :lol:
I have onboard air, so should I ever need it, the 18psi isn't an issue. I'll be rotating it out though shortly when it's time for my first rotation.
israelstanage
Post by israelstanage » Fri Aug 12, 2016 12:26 pm
It's true; all the cool kids have 37s. Take it from a nerd that has 35s.
14PowerWaggy
Post by 14PowerWaggy » Fri Aug 12, 2016 3:25 pm
I'm truly amazed you got it to fit... When I had 35's on my 14 I tried like heck to get my, worn, 35" Nitto Grappler under there and couldn't get it to go with 0 PSI... No way with the, worn, 37" spare... I just have it strapped down in front of bed... Just throw crap on it when I need to...
14PowerWaggy
Post by 14PowerWaggy » Fri Aug 12, 2016 3:27 pm
israelstanage wrote:It's true; all the cool kids have 37s. Take it from a nerd that has 35s.
37's for the win... Just do it... :rockon:
14PowerWaggy
Post by 14PowerWaggy » Fri Aug 12, 2016 3:31 pm
adeluca73 wrote:
37's.
:winchmob:
Mike Drop!!
:run:
Ditto!!
The 37's look great adeluca73!
Post by adeluca73 » Fri Aug 12, 2016 5:28 pm
Looking great, nice picture, sharp wheels!!
Post by adeluca73 » Fri Aug 12, 2016 5:31 pm
So you're saying there's a chance I can fit a 37" spare then?? yeeeeahhh
http://youtu.be/i--GdBmZPqg
dkjager
Post by dkjager » Fri Apr 07, 2017 1:46 pm
I went 35's for a few months, spare fits fine, just push the heat shield over with your boot! Now I am on Toyo MT 37x13.50 r17 and American Outlaw +15 offset wheels. 1.5" leveling kit with shock extension, Thuren track bar, lots of trimming. Still rubs a bit with full flex. Hopefully will do the full Thuren Overland or King kit over the next year. I still have the 35" spare mounted, For the 37" to work, first look for one that is more like 36" x12.50 or less. Next you'll have to move the exhaust over. Hitch might be an issue as well. I hope to get one a bit taller by summer just in case.
Toyo 37x13.50 r17 with American Outlaw Buckshot +15 offset
Note that I trimmed the bumper. New one is on order!
2015 PowerWagon
37x13.50r17 Toyo MT
GoRhino rear bumper
Factor 55 ProLink
T Rex grill
Post by olyelr » Fri Apr 07, 2017 2:14 pm
Looks good jager! Why the heck did you cut the bumper up front like that... having rubbing issues there?! I thought the rubbing issues would be on the other side at the corner of the flare/pinch weld.
MOAR PIKCHURZ !
Post by OffroadTreks » Fri Apr 07, 2017 2:41 pm
Ditto. I never considered it, but would an MT with more aggressive tread be more likely to rub vs the AT?
Numbnuts
Post by Numbnuts » Fri Apr 07, 2017 9:07 pm
I just put the R/T Toyos 35x12.5x17 on a factory rim at stock height. :rockon:
She rub at less than full lock on the control arm :jawdrop: :angry:
Post by Reloaderguy » Fri Apr 07, 2017 10:54 pm
I drove my truck today for the first time in two weeks. 35's are lame.
ljn21
Post by ljn21 » Sat Apr 08, 2017 12:32 am
dkjager wrote:I went 35's for a few months, spare fits fine, just push the heat shield over with your boot! Now I am on Toyo MT 37x13.50 r17 and American Outlaw +15 offset wheels. 1.5" leveling kit with shock extension, Thuren track bar, lots of trimming. Still rubs a bit with full flex. Hopefully will do the full Thuren Overland or King kit over the next year. I still have the 35" spare mounted, For the 37" to work, first look for one that is more like 36" x12.50 or less. Next you'll have to move the exhaust over. Hitch might be an issue as well. I hope to get one a bit taller by summer just in case.
What are you seeing for mpgs with the x13.5s?
When you say "lots of trimming", can you elaborate? I'm comfortable with what trimming is required to run x12.5s but wanted to see what else was needed for the extra width.
Post by DamageWagon » Sat Apr 08, 2017 12:45 am
Reloaderguy wrote:I drove my truck today for the first time in two weeks. 35's are lame.
Would you go bigger then?
Sent from my safe space
