"Frankenwagon" short and sweet.
- bstefanic
Re:
Lee buddy, those wheels are friggin bitchin
- bstefanic
Re:
Hey man, next time you're poking around under your truck....so I'm assuming today, ya mind measuring the vertical distance between the bottom of your rear bumps and the top of the axle tube? I'm sitting here overseas putting together a list of parts to order and I'm starting to think that I'm going to run into issues with my rear DS binding due to the spline length with any significant axle compression. If I can find my original order spec sheet should be able to figure out how much the shaft will shorten with the axle compressed based off of your measurements. Really hoping I don't have to send it back to Tom Wood or find a local shop to modify it. Thanks man
Re: "Saggin wagon" short and sweet.
how much spline shaft you got showing brotha? Remember you have to think of leafs like trailing arms so when the rear suspension actually compresses it pulls the driveshaft out of the slip yoke and when it droops out it pushes it further in! I can measure if you want when I get a chance!bstefanic wrote:Hey man, next time you're poking around under your truck....so I'm assuming today, ya mind measuring the vertical distance between the bottom of your rear bumps and the top of the axle tube? I'm sitting here overseas putting together a list of parts to order and I'm starting to think that I'm going to run into issues with my rear DS binding due to the spline length with any significant axle compression. If I can find my original order spec sheet should be able to figure out how much the shaft will shorten with the axle compressed based off of your measurements. Really hoping I don't have to send it back to Tom Wood or find a local shop to modify it. Thanks man
Sent from Canada
- bstefanic
Re:
Hmm, actually never realized that. Not a whole lot unfortunately, only about 1.5" or so...didn't take that into account when taking measurements to order it. I may just have to cycle the suspension when I get back and see how it looks2wagons1driveway wrote:how much spline shaft you got showing brotha? Remember you have to think of leafs like trailing arms so when the rear suspension actually compresses it pulls the driveshaft out of the slip yoke and when it droops out it pushes it further in! I can measure if you want when I get a chance!bstefanic wrote:Hey man, next time you're poking around under your truck....so I'm assuming today, ya mind measuring the vertical distance between the bottom of your rear bumps and the top of the axle tube? I'm sitting here overseas putting together a list of parts to order and I'm starting to think that I'm going to run into issues with my rear DS binding due to the spline length with any significant axle compression. If I can find my original order spec sheet should be able to figure out how much the shaft will shorten with the axle compressed based off of your measurements. Really hoping I don't have to send it back to Tom Wood or find a local shop to modify it. Thanks man
Sent from Canada
Re:
Did you ever figure out the vibration?
we narrowed it down to a t case and weirdly enough my t case guy and diff guy has never seen that situation before and then after he looked at mine a few times he had another customer with a 12' cummins that had a vibe from his t case at around same speedsReloaderguy wrote:Did you ever figure out the vibration?
Apperantly 12'z were bad for weird shit like that turbo diesel or gassers
Sent from Canada
Can't wait to get my hands on them
Sent from Canada
18" stroke 3.0 four tube bypasses from Thuren fab/ king shocks Sent from Canada
Sent from Canada
Sent from Canada
Re:
Holy hell lee....
Re:
I thought you were taller. How do you get in your truck?
- NovA ProspekT
Re:
Good God man...
You building a Trophy Truck? You're halfway there already.
I wish I could justify those where I live.
Re:
me likey but your frame might not likey
haha no maybe not especially with new bed cage I think fish plating will happen soon!Will wrote:me likey but your frame might not likey
I added a picture of the small service advisor holding them lol I'm 5'10 and he's just alittle over 4'7" I think lol
Also some nice custom lower leaf spring mounts
Sent from Canada
Bed cage starts tomorrow
Sent from Canada
Sent from Canada
Re:
Shit yeah! Canadian Godzilla is about to be unleashed
Re:
Godzilla ain't got nuttin on lee's wagon
Re:
I think you got bitten by the bug. You now need a cage!
FRANKEN-WAGEN
At what point does this stop being a PW & start becoming a generic monster truck.... Aka FrankenWagen.
- Strip LEDs
- New style tie down cleats - Garmin Power Switch Powering:
Re:
Theseus' ship for the modern age
Re:
Cage time for sure!
Re: FRANKEN-WAGEN
When he installs 42'sadeluca73 wrote:At what point does this stop being a PW & start becoming a generic monster truck.... Aka FrankenWagen.
- Stickman
Where's that meme that says "Just got a new daily!" over a picture of a stock car. Then in another picture below it where it's completely modded to hell and doesn't look anything close to stock it says "Damn, I need a daily" This is that, except with a truck.
Hahahaha exactly. Can an admin change this title to frankenwagon? Hahaha
Some updates I didn't actually go with this cage design because they fucked up and put shocks in the wrong spot so now they are tilted inwards as well as forwards for tire clearance I think I still have to run wheel spacers to clear everything however the travel numbers look pretty sweet I'm thinking 19" at least.... This is 4500lbs in bed and still not at full bump so I will have to cycle myself and set the new bump zone up with boogies etc... I do get it back tomorrow but here's a few pictures to keep y'all entertained
Sent from Canada
Sent from Canada
Re:
I've had trouble finding good help in the past, it's always frustrating to come back and find nothing has been done the way you wanted it to. I was surprised to not see any bent tube in that bedcage. Overall it's starting to really come together though lee, just hang in there and you'll be making raptors tuck tail and run in no time!
