Shorter articulink, maybe?Reloaderguy wrote:Imagine if someone made a replacement articu-link for the PW radius arm that was longer to account for the additional lift. Simple welded structure that cost $200 or less that adjusted the axle to the factory 2500 angles.adeluca73 wrote:Yep, see that, factory seem more flush with the horizontal plane of the axle...Reloaderguy wrote:The spring cup angles in the lower picture are steeper if you look closely.
https://www.averagecarguy.com/wp-conten ... agon_1.jpg
