Does anyone know if the bed from a 2009 1500 is the same dimensions as a 2011 2500? I found a fiberglass tonneau cover for 150 but want make sure it fits.
Bed size
- 2011TXPowerWagon
Bed size
Re: Bed size
1500's have 2 different sized beds, most are smaller than ours.
- 2011TXPowerWagon
Re: Bed size
Damn I was afraid of that
Re: Bed size
the 1500s had a 5'7" or 6'4" option
Re: Bed size
Yep. If its the 6'4" one, then your golden... Same box.
Re: Bed size
But it won't be because they added the 6'4 bed to the crew cabs for the 2013 and later model year. Although if it is a quad cab you will be golden.olyelr wrote:Yep. If its the 6'4" one, then your golden... Same box.
Re: Bed size
Uh, maybe ask the seller how long it is?Does anyone know if the bed from a 2009 1500 is the same dimensions as a 2011 2500?
Re: Bed size
Make sure the bolt holes in the bed for mounting lines up. The cross members bewtween the 1/2 ton and 3/4 ton may be different spacing.
