Steering brace - fits all sway bars and torsion bars
http://dodgeoffroad.3dcartstores.com/Do ... p_152.html
Steering linkage - 2" OD .250" wall tie rod, 1.5" OD .250" wall drag link, 4140 HT chromoly hardware with 7/8" heims, totally bolt-in
http://dodgeoffroad.3dcartstores.com/Do ... p_166.html
Suspension kit - 2" lift or 3.5" lift height available on Power Wagons, Hemi-specific coils front and rear (not diesel coils like everyone else), includes shocks, bumpstops, front and rear adjustable track bars, front sway bar end links, and no drop brackets or spacers! Options for better shock packages and adjustable radius arms. Our 2014 diesel shown in this pic, will have post-worthy PW-specific pics soon.
http://dodgeoffroad.3dcartstores.com/DO ... p_183.html
Adjustable front and rear end links - 1.25" OD tube with hex adapters, 3/4" heims on both ends, the largest end links available anywhere. Available in custom lengths too. Picture is of standard end links, PW come without the bracket and are the correct length.
http://dodgeoffroad.3dcartstores.com/DO ... _p_74.html
Adjustable radius arms - part of our suspensions, also available separately. Adjust caster and axle position, better tire clearance than stock, and no loss of ground clearance like with drop brackets. Extremely heavy duty, they weigh 93 lbs each. Johnny Joints used for the adjustment. Bolt-in install.
Adjustable rear track bar - 1.5" OD x .40" wall DOM tube with 1" shank Johnny Joints at both ends, bent to clear rear diff cover. Much stronger than stock, and no need for drop brackets. Center your rear axle with any lift height. Bolt-in install.
In the works: Adjustable rear control arms, front long arms, adjustable front track bar by itself, and a 2014+ PW-specific category on the site so it's easier to find what is made for your truck.
