"Frankenwagon" short and sweet.
Re: "Saggin wagon" short and sweet.
Post by Will » Fri May 06, 2016 7:26 pm
I thought about some big ass concrete anchors in the garage foundation, some eye bolts, lock both sides down and place a jack in the middle. But I'm not sure how much it takes to straighten it. If I could, then I can weld Don's truss on.
Post by 2wagons1driveway » Fri May 06, 2016 7:41 pm
Will wrote:I thought about some big ass concrete anchors in the garage foundation, some eye bolts, lock both sides down and place a jack in the middle. But I'm not sure how much it takes to straighten it. If I could, then I can weld Don's truss on.
I will find the article on DTX to help you out brotha! Give me a few seconds!
Sent from Canada
Post by 2wagons1driveway » Fri May 06, 2016 7:45 pm
Post by 2wagons1driveway » Mon May 09, 2016 12:11 am
Lol I had a shitty uneventful weekend tried to help pull someone out of a bad stuck in reverse and BOoM!!
Going to have to try and find a way to increase the strength of these thinner teethed gear sets.... Cryo and rem is my first option.
Sent from Canada
Re:
Post by nts007 » Mon May 09, 2016 12:14 am
Damn!! That blows. But I never expected the gears to be that weak. Maybe you should look at 4.88s. Although that's a hell of a step backwards. Will treating them really help?
Re:
Post by Will » Mon May 09, 2016 7:04 am
Yeah, they dont look like they like reverse too much. damn.
Re:
Post by nts007 » Mon May 09, 2016 8:41 am
May sound dumb but was there a gear alignment issue too?all the damage is on the outside leading edge. I would have expected the carnage to be most flat across the whole ring gear. Or is it a leading edge thing
Post by 2wagons1driveway » Mon May 09, 2016 9:21 am
It probably looks like
That because the damage was done in reverse we figure and the coast pattern was alittle higher. I'm guessing something just barelly fractured and then the teeth piled up on the pinion and did more damage. I don't think it was alignment problem as the pattern we got was good before we bolted it all down. And backlash etc never changed. I will have to totally tear it apart and inspect everything obviously now make sure the carrier isn't fuxked
Sent from Canada
Mr.Smith
Re:
Post by Mr.Smith » Mon May 09, 2016 4:43 pm
I've fucked up in reverse pulls myself, it only takes one time to learn never again. Reverse pulls puts too much stress on a ring & pinion due to the position when torque is applied. This really sucks to hear, good luck with the R&R Sir. At least you already know the process to dial it in. :)
Post by 2wagons1driveway » Mon May 09, 2016 9:56 pm
Mr.Smith wrote:I've fucked up in reverse pulls myself, it only takes one time to learn never again. Reverse pulls puts too much stress on a ring & pinion due to the position when torque is applied. This really sucks to hear, good luck with the R&R Sir. At least you already know the process to dial it in. :)
yep lol I'll probably have buddy install them again tho the gear guy down the street. Maybe I'll do this set myself. He's building me a new t case already with some
Cryo parts so I'll just probably have him build the front end cause he can do it in a few hours and I take a day or two lol
Sent from Canada
Re:
Post by Colibri » Mon May 09, 2016 10:11 pm
Arb cough cough air locker cough. Now's the time lol
Mr.Smith
Re:
Post by Mr.Smith » Mon May 09, 2016 11:32 pm
^X2! :drool:
Post by 2wagons1driveway » Tue May 10, 2016 12:00 am
Colibri wrote:Arb cough cough air locker cough. Now's the time lol
lol I dunno I do like the simplicity of the e locker man... It's nice fast and wired already!
Sent from Canada
Post by 2wagons1driveway » Fri May 13, 2016 8:58 am
Just an update nitro and just differentials is sending me a new ring and pinion under warranty * just said I should try and get a deeper pattern next time I install them as the reason the set didn't last was because the pattern was alittle to far to the outside edge for such a heavy truck etc. so they recommended bringing the pinion in just a bit more by adding some shims etc.
Sent from Canada
Re:
Post by Colibri » Fri May 13, 2016 9:36 am
Awesome! Glad to hear they stand behind their products. Now go DEEP lol
Post by Will » Fri May 13, 2016 9:55 am
Post by 2wagons1driveway » Fri May 13, 2016 12:33 pm
Lol
Sent from Canada
Re: new gears
Post by adeluca73 » Sat May 14, 2016 7:06 pm
That's geat they're standing behind the product --did they provide a sample tread pattern to check oinion depth against or a coast side verification ?
Post by 2wagons1driveway » Sun May 15, 2016 3:05 pm
adeluca73 wrote:That's geat they're standing behind the product --did they provide a sample tread pattern to check oinion depth against or a coast side verification ?
no they didn't basically just said to add some shims if the pattern on the new set is like the old to bring the pinion in a bit deeper Image
Sent from Canada
Post by 2wagons1driveway » Mon Jun 06, 2016 4:49 pm
http://youtu.be/LpRGjskedeY
Good weekend in Bc watching rally. But I am still waiting on trail ready wheels to come in and also my rear shocks so I can start getting this bed cage together after this weekend I really really really want an RTT.... Well have to see how this bed cage turns out I may have to build something into it so it can handle boogeying
Sent from Canada
Re:
Post by olyelr » Mon Jun 06, 2016 11:48 pm
2wagons1driveway wrote:http://youtu.be/LpRGjskedeY
Sent from Canada
Hahaha, its funny how much difference in speed there is between the first few guys and the last few guys hahahah.
Re:
Post by Colibri » Tue Jun 07, 2016 12:24 am
Shit that makes me miss my evoIX! Looks like a great time :rockon:
Re:
Post by Will » Tue Jun 07, 2016 6:23 am
You would post up something about fast cars, no where to "rally" around here but I've been in a Challenger rental while my truck is in the shop and it sure is growing on me. My wife even said to get one and she'll drive the PW when I get it back. :sick: The Grand Cherokee just might be traded in on a 392 Scat Pack.
Re: Re:
Post by olyelr » Tue Jun 07, 2016 7:13 pm
Will wrote:You would post up something about fast cars, no where to "rally" around here but I've been in a Challenger rental while my truck is in the shop and it sure is growing on me. My wife even said to get one and she'll drive the PW when I get it back. :sick: The Grand Cherokee just might be traded in on a 392 Scat Pack.
HELLCAT!
Post by Will » Tue Jun 07, 2016 8:36 pm
HELLCAT!
I don't want that kind of payment. Wouldn't take much for the 392 to pump a few more horses.
