LagunaH1
Post
by LagunaH1 » Fri May 13, 2016 7:43 pm
HI guys,
Was poking around under my truck just now, and saw a couple of things I don't really understand the purpose of:
1: These are mounted to the frame, immediately behind the lower lip of the front bumper. I suppose their purpose is to protect the smart-bar, etc from too much off-road damage or contact with rocks?
2: This thing sits right behind the rear end of the T-case. I have no idea what it is, other than I *think* it's fuel system related:
2016 RAM 2500 Power Wagon SLT
NR6E
- Model Year: 2010
Post
by Will » Fri May 13, 2016 7:58 pm
The tops pieces are to keep you from running over the Prius, the bottom is fuel system related.
Post
by Colibri » Fri May 13, 2016 8:18 pm
Evaporative emissions system. The other things I have no idea. Perhaps they're there for securing them in transit or something?
Post
by FirerescuePW » Fri May 13, 2016 9:16 pm
Will is right. We think.
Post
by Low_Sky » Fri May 13, 2016 9:51 pm
On the top pic, that's where the plow mounts go on plow-equipped 2500s. As others have said, the going opinion on why they put them on our "not recommended for plowing" trucks is Prius owner protection.
Post
by adeluca73 » Fri May 13, 2016 11:25 pm
Top is mandated --protects from the up & over, I was going to remove them until I realize a lot of aftermarket numbers use them as mounting points & until I make a definitive call on Line-X the stock or find a suitable aftermarket, they're staying.
Bottom--no idea
- Garmin BT Power Switch Powering:
- Model Year: 2010
Post
by Will » Sat May 14, 2016 7:05 am
The bottom looks like an evap canister for emissions. Here is a 2004 diagram for comparison.
Post
by Retired BLM Rig » Sat May 14, 2016 2:22 pm
Will wrote:The bottom looks like an evap canister for emissions. Here is a 2004 diagram for comparison.
Correct!
2008 Quad Cab - Stock
RTI = 655, curb weight = 6081 lbs.
Abel Components Plug & Play Locker Bypass®, Abel Components Full SmartBar Bypass®, Abel Components Nanny Kill Switch®, 2000 Watt ProMariner TruePower Plus Pure Sine Wave Inverter, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God, Share the Umbrella, Make sure you're right with God before you meet him!
RamGentry
- Model Year: 2010
Post
by RamGentry » Mon May 23, 2016 1:47 pm
I have been contemplating removing the walrus teeth. Since I ripped off the lower valence they have become much more visibly noticeable. Do I really become that much more of a hazard to other vehicles?
- Model Year: 2010
Post
by Will » Mon May 23, 2016 3:39 pm
I took mine off when I first noticed them, looked like something to grab and bend the damn frame to me.
2011TXPowerWagon
Post
by 2011TXPowerWagon » Mon May 23, 2016 3:42 pm
So if these are "snow plow mounts", would are trucks be snow plow ready? According to NADA being snow plow ready adds couple thousand to trade in value. hmmm
loveracing1988
Post
by loveracing1988 » Mon May 23, 2016 8:04 pm
2011TXPowerWagon wrote:So if these are "snow plow mounts", would are trucks be snow plow ready? According to NADA being snow plow ready adds couple thousand to trade in value. hmmm
The snow plow prep package adds $300 to the MSRP if I remember right. It is just a bigger alternator and a t case skid plate.
LagunaH1
Post
by LagunaH1 » Mon May 23, 2016 8:27 pm
loveracing1988 wrote:2011TXPowerWagon wrote: It is just a bigger alternator and a t case skid plate.
I saw someone mention that the snow plow prep package also included a higher capacity radiator for engine cooling. Supposedly, the PW has that as well
NR6E
2011TXPowerWagon
Post
by 2011TXPowerWagon » Mon May 23, 2016 10:53 pm
loveracing1988 wrote:2011TXPowerWagon wrote:So if these are "snow plow mounts", would are trucks be snow plow ready? According to NADA being snow plow ready adds couple thousand to trade in value. hmmm
Just ran the info, according to NADA.com the snow plow package adds $2200 trade-in and/or $2450 retail.
loveracing1988
Post
by loveracing1988 » Tue May 24, 2016 9:46 pm
2011TXPowerWagon wrote:loveracing1988 wrote:2011TXPowerWagon wrote:So if these are "snow plow mounts", would are trucks be snow plow ready? According to NADA being snow plow ready adds couple thousand to trade in value. hmmm
Cool, seems like it was a good investment!
Post
by Retired BLM Rig » Wed May 25, 2016 12:57 pm
Will wrote:The tops pieces are to keep you from running over the Prius,
adeluca73 wrote:Top is mandated --protects from the up & over,
I vote for Prius/Smart cars with exoskeletons, rather than trucks with bumper/frame horns.
Post
by FirerescuePW » Wed May 25, 2016 4:21 pm
I admit I haven't kept up with my late model PW trivia, but when did they start offering snow plow prep on a PW? My manual specifically states you should NOT put a plow on a Power Wagon.
Post
by cruz » Wed May 25, 2016 4:27 pm
FirerescuePW wrote:I admit I haven't kept up with my late model PW trivia, but when did they start offering snow plow prep on a PW? My manual specifically states you should NOT put a plow on a Power Wagon.
My manual says the same thing. My question is, what's a snow plow?
Post
by Low_Sky » Wed May 25, 2016 5:16 pm
They don't. But this is either a case of "oh, those snow plow horns are a good safety feature, let's put them on the Power Wagons", or "those safety horns would be good snow plow mounting point on the other 2500s".
Post
by Low_Sky » Wed May 25, 2016 5:20 pm
cruz wrote:FirerescuePW wrote:I admit I haven't kept up with my late model PW trivia, but when did they start offering snow plow prep on a PW? My manual specifically states you should NOT put a plow on a Power Wagon.
I know you don't have this stuff where you're from, but imagine if it rained inside your freezer. The rain drops would turn into these little white flakey things called snow....
bones
Post
by bones » Wed Jun 08, 2016 9:18 am
Hey guys, I'm a little late to the party here but thought I would chime in. Those mounts under the front are called compatibility brackets, they are not for any type of plow. They are required by DOT or some other gov't entity. The exact reasoning I am not sure of, I've heard it could be due to the front height of the frame and/or truck and for safety in the event of an accident.
With that said, has anyone successfully mounted a new Western UltraMount II snow plow without losing the winch?
2012 PW - gone
2005 PW - gone
'03 Kawasaki Prairie 650
yooper68
Post
by yooper68 » Wed Jun 08, 2016 10:45 am
Bones -
I have only seen pictures of 2 newer power wagons with snow plows.
One was a Fisher on a 2011 PW and they were able to keep the winch & tow hooks but it was a custom mount. (See
http://www.plowsite.com/showthread.php?t=152515)
"monteholic" on this forum does have a Boss plow, but said he had to remove the winch to install the undercarriage but his photo shows winch installed so maybe he was able to put the winch back in place. (There is a photo of his boss plow mount in the "Power Wagon Picture Thread", page 79 - March 2016)
Good luck & let us know if you are able to mount your plow - I would be interested also....
