MTolyelr wrote:Mt's or atm?
PW Yoga
Re: PW Yoga
Re: PW Yoga
I wanted to join the fun. I love these trucks. And 37s look good on them
- Chromolykid
Re: PW Yoga
Had fun testing the new wheels and tires the other day. Really excited to get some time off to venture out into more remote country.
									“Furiosa”
2016 Power Wagon
White Knuckle Sliders
DOR Steering Brace
Thuren Stage 1 KING 2.5’s
Thuren Coils Front & Rear
Dethloff Swaybar Spacers
AEV Procal
						2016 Power Wagon
DOR Steering Brace
AEV Procal
- 2011TXPowerWagon
Re: PW Yoga
- 2011TXPowerWagon
Re: PW Yoga
Did some yoga on the way home from work.
- 2011TXPowerWagon
Re: PW Yoga
Sway bar locked vs unlocked
Re: PW Yoga
Stubie, I forgot mine had a red pinstripe, it was exactly like yours for a week until the dealer debadged it while we were on our honeymoon in Montana.
- 2011TXPowerWagon
Re: PW Yoga
This was actually the first time i have stuffed the tire so much.  I was really surprised.  I must admit, unfortunately, mine is much more of a pavement princess than an offroad beast.
Re: PW Yoga
Is your truck bone stock and running those tires? I see you are rubbing the way bar and control arms. How bad is the turning radius like that?2011TXPowerWagon wrote:This was actually the first time i have stuffed the tire so much. I was really surprised. I must admit, unfortunately, mine is much more of a pavement princess than an offroad beast.
- 2011TXPowerWagon
Re: PW Yoga
Truck is completely bone stock.  All I have added are the tires and the crappy side steps.  It does rub but it only ever happens at slow speeds so I just back the turn off a little.  Knowing how much they rub, I would still do 37's.
Re: PW Yoga
Thanks man. I am almost due for tires and am thinking of just jumping straight to 37s. I appreciate the info.2011TXPowerWagon wrote:Truck is completely bone stock. All I have added are the tires and the crappy side steps. It does rub but it only ever happens at slow speeds so I just back the turn off a little. Knowing how much they rub, I would still do 37's.
Re: PW Yoga
I've noticed that most of everybody's pics are showing the front wheel stuffed while pointed straight ahead. I'm curious as to how well they stuff when turned close to/or at full lock. Do they (35" or 37") rub on the fender when cranked hard and stuffed?2011TXPowerWagon wrote:This was actually the first time i have stuffed the tire so much. I was really surprised.
						Re: PW Yoga
They actually are the closest while straight for the most part. It might touch the top but I haven't had any issues crawling and turning. I suppose you could lengthen the bump stops to make sure but it takes a good bit to get it all the way up.cruz wrote:I've noticed that most of everybody's pics are showing the front wheel stuffed while pointed straight ahead. I'm curious as to how well they stuff when turned close to/or at full lock. Do they rub on the fender when cranked hard and stuffed?2011TXPowerWagon wrote:This was actually the first time i have stuffed the tire so much. I was really surprised.
- 2011TXPowerWagon
Re: PW Yoga
I was actually thinking the same thing while I was playing around.  Going to try and stretch them again and see what happens when the wheels are turned.
Re: PW Yoga
Here's a couple older pics.
Re: PW Yoga
Work Yoga
DT Pro Fab sway bar end links
Rugged Ridge floor mats
AMP bed step
37" Toyo RT's
AMP bed step
37" Toyo RT's
Re: PW Yoga
Keep in mind guys who are contemplating the 37"s like tex n will. They are running STOCK wheels. So when stuffed and turning they are inside the smallest arc. Aftermarket wheels reducing backspace will defiantly rub more fender when stuffed.
Looks awesome dudes.
						Re: PW Yoga
Good pictures from all on this post...Rusty - I like your ditch story !RustyPW wrote:At work, there is an erosion ditch that's about 10ft wide and 4ft deep. I have no trouble going through it at an angle. We get these contractors at work with their rocky ridge pick-ups. All jacked up chebys and ferbs. They talk shit on my PW. I talk them after work, lets go to the ditch. They say ok. They watch me go through the ditch. I ask them to do it. 98% will not try. The 2% that try. I have to pull them out. So for the rest of the time these contractors are at work. They get hammered by my crew on what pieces of crap they drive, or how little their balls are.
Ben     CW3     2/10th AIR CAV    FT ORD CA. (retired)
Re: PW Yoga
Bump, where's some of those yoga pictures that look like something is broken!?
Re: PW Yoga
Here’s a few from the past year. Haven’t been wheeling much lately, still some backcountry snow left to be skied.
- NovA ProspekT
Re: PW Yoga
Back when I was on the 35" Mastercraft AXT's that the previous owner had installed. Not at all a bad tire, never really had a problem with them, even in mud.
August, 2016 - Does time fly or what?
				TheDirtRoad
