6.4 sound on acceleration
Hey all,
Just got my 2015 power wagon, and when I accelerate I hear what sounds like a small exhaust manifold leak. It's not a tick or a ping. It doesn't sound like metal hitting against metal. It sounds like those big old V8s in large vans that kind of made a sputtering sound (like an exhaust manifold leak) when you put the pedal to the floor. Just wondering if anyone else hears this upon acceleration? I took it to the dealer, and they said it sounded normal. However, the sound is more pronounced when the engine is cold (again like I would expect with an exhaust manifold leak). I'll probably drop it off overnight for them to listen to again, but thought I would ask here as well.
All my previous vehicles have been 4 or 6 cylinders, so perhaps this sound is normal for the V8s?
Thanks!
Thanks!
Re: 6.4 sound on acceleration
Sounds are hard to describe. But, an exhaust leak usually has a "putt putt putt" (think golf putt, not put) sound to it. I'd be surprised if your 6.4 has a leak already. But my previous 2010 had two exhaust manifold bolts break. And apparently common on the 5.7L Hemi.
I wouldn't describe it as a put put sound. Sorta of like a throaty click? It sure is hard to describe. It's not there during idle.
I wonder if it's anything like what mine sounds like, which is absolutely much more pronounced when cold and when accelerating when cold:
http://forum.powerwagonregistry.org/vie ... f=2&t=3822
I'm thinking that the 6.4's just sound that way. After I got my truck I've noticed that sound, for example, in TFL Trucks ramp test with a PW and a Raptor. In that video, you can hear a bit of the same noise as my truck makes
2016 RAM 2500 Power Wagon SLT
NR6E
NR6E
That's the sound! Funny how we describe it differently. Mine is no where that pronounced at cold idle, but that is definitely it. Thanks.LagunaH1 wrote:I wonder if it's anything like what mine sounds like, which is absolutely much more pronounced when cold and when accelerating when cold:
From what I understand it is all HD Hemi Rams. My 2012 does it. It has always done it. Dealers will say it's normal. You really can notice it next to a wall with the windows down. There is a thread here some where about it.
Not sure the answer. But you aren't alone. I have a video of mine somewhere.
What octane are you running?
old sole mopar
Your factory muffler has a silly spring loaded flap in it. At idle it's closed and opens up as exhaust goes through it harder. It can whistle and tick. Change your muffler and it's gone away.
87Will wrote:What octane are you running?
Already removed the stock muffler. That's not it.old sole mopar wrote:Your factory muffler has a silly spring loaded flap in it. At idle it's closed and opens up as exhaust goes through it harder. It can whistle and tick. Change your muffler and it's gone away.
- Chromolykid
To the best of my knowledge, it's normal. My 2016 does it, and so do all the other 6.4 trucks I've heard. Just the Hemi-tick, would be interesting to know what exactly causes it though.
“Furiosa”
2016 Power Wagon
White Knuckle Sliders
DOR Steering Brace
Thuren Stage 1 KING 2.5’s
Thuren Coils Front & Rear
Dethloff Swaybar Spacers
AEV Procal
2016 Power Wagon
DOR Steering Brace
AEV Procal
my 14 does it! at first i was worried then did research and found out not to worry. I also have a mufflex muffler and drop in filter.
2014 wagon slt black with decals
Mufflex Magnaflow
35 inch falken at3s
Thuren springs with King 2.0 shocks, Fox ATS stabilizer, Thuren track bar, Synergy drag link, Carli diff armor
Mufflex Magnaflow
35 inch falken at3s
wow does this suck.... still havent figured it out in 2018...
