"Frankenwagon" short and sweet.
Re: "Saggin wagon" short and sweet.
Post by 2wagons1driveway » Sat Apr 02, 2016 8:37 pm
one side in
Sent from Canada
Post by Will » Sat Apr 02, 2016 9:23 pm
Ooooo, I like those stands
Post by 2wagons1driveway » Sat Apr 02, 2016 10:27 pm
Will wrote:Ooooo, I like those stands
get some man ! Make working on the truck a breeze
Sent from Canada
Re:
Post by Colibri » Sun Apr 03, 2016 12:01 am
Jesus! That is one huge reservoir!!!! :notworthy: :notworthy: :notworthy:
Post by 2wagons1driveway » Sun Apr 03, 2016 4:35 am
Lol ya it was a pain to get in there .... A real pain.
Sent from Canada
Post by 2wagons1driveway » Mon Apr 04, 2016 12:17 am
well my buddy who's a licensed welder came to my other buddies shop to install the long arms today and it wasn't bad really a bigger pain to take the Carli arms out! Only issue we had was welding the support tubes in for the alien arms to a certain section of frame really did not work out well at all...:/ anything over 50-60amps and the .030 wire would punch through this first layer of frame material and honestly just turn to mush and fall on the pavement the welder was getting so pissed cause we tried everything to get a decent bead out of it and we absolutely could not with the mig so we plan on blowing it out with an specialized arc rod and then re attcthing it with a 6010 or 7018 rod something to do with the metal where the support tubes were added almost appears to have glue or a substance in between it causing the welder to just either burn through it and slag everywhere or fall apart.... Literally he was laying awsome beads down on the regular metal and the sides of the frame and when we got to the cross member portion or this rear support tube it all went to shit.... Really pissed him off we tried everything adding more gas more wire speed less wire speed higher amps less amps changing grounds and tips also tried stitching it and still did not come out well at all so he kinda just threw some weld at it for now
such a shame because the welds on those long arm brackets are killer and it sucks to take away from them.... FML.
Btw they ride really nice tho!
unfortunately got a pleasant surprise when I removed driver radius arm and control shock... Looks like it hasn't controlled anything for awhile lol.... Funny wasn't even leaking.... Maybe a factory defect or something? Pretty pissed I have to buy one now just to sell these effin arms....
Sent from Canada
Re:
Post by Will » Mon Apr 04, 2016 6:55 am
Sent from Canada
They're definitely on my list, that would make everything much easier 8-)
Re:
Post by nts007 » Mon Apr 04, 2016 10:30 am
Is it possible lee that that shock blew out all its fluid cause it was filled with maple syrup over the winter?? It is a 7100 after all.
Post by 2wagons1driveway » Mon Apr 04, 2016 6:39 pm
nts007 wrote:Is it possible lee that that shock blew out all its fluid cause it was filled with maple syrup over the winter?? It is a 7100 after all.
https://vimeo.com/161547339 no it was full bud! Thin syrup If that was it!
Sent from Canada
Re:
Post by nts007 » Mon Apr 04, 2016 7:13 pm
Lol. Looking forward to your final install. Did you buy a Prius for a daily driver yet?? Cause they are sooooo sporty now hahaha. Don't know about its jumping prowess but if anyone could find it that's you!!
Hurry up and get those alien arms installed!!
Post by 2wagons1driveway » Mon Apr 04, 2016 10:57 pm
nts007 wrote:Lol. Looking forward to your final install. Did you buy a Prius for a daily driver yet?? Cause they are sooooo sporty now hahaha. Don't know about its jumping prowess but if anyone could find it that's you!!
lol they are on!
And they are smooth!
Sent from Canada
Re:
Post by Colibri » Mon Apr 04, 2016 11:18 pm
Shit, that's awesome! How do they compare to the radius arms?
Re:
Post by nts007 » Mon Apr 04, 2016 11:57 pm
lol they are on!
Sent from Canada
:jawdrop: :jawdrop: :jawdrop: :drool: :drool: :drool: excuse me while I go find a towel
Yea how are ey in comparison. The radius are supposed to the the smoothest riding so...
Post by 2wagons1driveway » Tue Apr 05, 2016 9:01 am
lol they are on!
Sent from Canada
I was telling Tim last night they feel the same if not a bit smoother truthfully. Also one thing I've noticed is they are quite a bit quieter as well as less play in the front end all together. All the Johnny joints were still good and toght in the radius arms just maybe the fact they were bolted in allowed them to move around and make noise that much more? I dunno I'm impressed so far. Hoping these stainless joints hold up better in Canada as well!
Sent from Canada
Post by 2wagons1driveway » Sat Apr 16, 2016 9:40 pm
and in!
Sent from Canada
Black Pearl
Re:
Post by Black Pearl » Sat Apr 16, 2016 11:04 pm
That my friend is setting the bar very high!
Way to go.
Re:
Post by Colibri » Sun Apr 17, 2016 12:57 am
Looking fantastic lee! Cycling the front end is such a chore but totally worth it for peace of mind, those arms and shocks are straight pornography! :rockon:
Post by 2wagons1driveway » Sun Apr 17, 2016 4:29 am
Lol Hells ya! Only true test tho is. The "boogie"
Sent from Canada
Post by 2wagons1driveway » Sun Apr 17, 2016 2:51 pm
Hoping this new synergy steering will fix this problem at full bump- steering stuff connecting is no good :/ this is at 100% bump tho boogie completely gone And only the 1/4 base plate
a straighter drag link should
Help this Thuren fab drag link is meant for a three inch lifted truck or stock-so I can only expect so much out it with a drop pitman arm that reverses the mount position. The synergy steering looks like a straighter drag link so it should function nicely if not I will take that bitch back and buy cross over steering ImageImage
Sent from Canada
Post by Will » Sun Apr 17, 2016 5:05 pm
It's not good when two shafts touch each other...
Post by 2wagons1driveway » Sun Apr 17, 2016 5:17 pm
Will wrote:It's not good when two shafts touch each other...
technically I think ones a rod :/ lol
Sent from Canada
Re:
Post by Colibri » Sun Apr 17, 2016 5:56 pm
It's only gay if the balls touch :rofl: :rofl:
Post by 2wagons1driveway » Sun Apr 17, 2016 8:52 pm
Lol ^^ I talked to don Thuren and apperantly my drag link will clear just fine when it's in the right spot lol fml I have had it installed wrong the whole time I've had it!! Need to be rotates forward more
Sent from Canada
Post by 2wagons1driveway » Tue Apr 19, 2016 9:23 pm
Boom new toyo
also clean up the 3.0's for their new owner a lot of grit got Into the drivers seal head from the wiper seal letting stuff by. So I cleaned that mess all up so now they both cycle smoothly etc....
Sent from Canada
Post by 2wagons1driveway » Wed Apr 20, 2016 11:15 pm
got my ham/ race radio in today! Excited to use it. Got a mag roof mount so I can jut keep antenna in back seat under seats when I'm Not using it
Sent from Canada
