Bilstein 5100, or Fox 2.0 Shocks?
Throttle 8
Re: Bilstein 5100, or Fox 2.0 Shocks?
Post by Throttle 8 » Thu Apr 09, 2015 11:53 am
I have had 5100's on mine for 2 weeks now and am very happy with them. The ride is a touch firmer, but the truck does not wallow as much in the corners now. I went with the 5100's over the Fox's because when I am off road it is a slow crawling pace rather than the dessert runner style. For me the 5100's met my needs, without the added expense. Either way you go you will get a quality product.
Post by 2wagons1driveway » Thu Apr 09, 2015 8:04 pm
Id imagine the foxes would be valved pretty close to the bilsteins. They are a stock replacement shock so id imagine thy wouldn't be anything to crazy over what you already have!
Sent from somewhere your not
Juday
Post by Juday » Fri Apr 17, 2015 1:19 pm
I found these on KORE's website:
Fronts: http://www.koreraceshop.com/collections ... hocks-pair
Rears: http://www.koreraceshop.com/collections ... hocks-pair
Looks like they might have a little more of a "special" valving that your "off the shelf" 5100 series. Any ideas, thoughts on these?
2012 RAM Power Wagon
Limamikemike
Post by Limamikemike » Fri Apr 17, 2015 2:53 pm
I had a set of Thurens Fox 2.0 on my 06 diesel, they were valved way softer than the 5100 I had previously. Rode super nice, IMHO worth the extra $$.
azracer
Post by azracer » Fri Apr 17, 2015 3:22 pm
I would not buy anything from Kore.... EVER!
Juday
Post by Juday » Wed Apr 22, 2015 10:09 am
Anyone know the Extended and Collapsed lengths for the stock front and rear shocks on the Power Wagon?
Post by Will » Wed Apr 22, 2015 11:15 am
Juday wrote:Anyone know the Extended and Collapsed lengths for the stock front and rear shocks on the Power Wagon?
I'm not sure of the "factory" specs but I have Rancho 9000 shocks on mine and have not have any articulation issues and these numbers are what they are. They hit the bumps stops and have plenty of drop.
Front
Compressed 15.95"
Extended 24.60"
Travel 8.65"
Rear
Compressed 18.24"
Extended 29.74"
Travel 11.50"
verdesardog
Post by verdesardog » Wed Apr 29, 2015 11:32 am
I put bilstein 5100's on my truck last year, it's already riding like a boat! I need some good inexpensive shocks...recommendations?
Cactus Red
Post by Cactus Red » Wed Apr 29, 2015 11:38 am
The two are mutually incompatible - good shock and cheap...
Post by 2wagons1driveway » Wed Apr 29, 2015 1:18 pm
Overlands? That's the only inexpensive decent shock I can think of....
Black Pearl
Post by Black Pearl » Wed Apr 29, 2015 2:01 pm
Rancho 9000's?
verdesardog
Post by verdesardog » Wed Apr 29, 2015 3:23 pm
I just ordered 4 rancho 9000's $404 minus $106 rebate.
Post by 2wagons1driveway » Wed Apr 29, 2015 4:06 pm
Not bad! Hopefully they hold up! And hopefully they don't limit travel !
Juday
Post by Juday » Tue Jun 09, 2015 8:37 am
Purchased and installed the Bilstein 5100 series shocks over the weekend.
Front Shocks PN: 24-066464
Rear Shocks PN: 24-186636
Steering Damper PN: 33-170794
So far, I've been extremely pleased with the purchase. For the money that I spent, I think it's hard to beat these shocks. The truck doesn't bounce over everything and reverberate after hitting the bumps. The shocks soak up the small bumps extremely well and give the truck a much more controlled feeling over uneven/broken asphalt and potholes. I've noticed less body roll in the corners, too.
They might not be the best shocks out there, but I think they're much better than the Bilsteins that came on the truck from the factory. IMO, this is what should have come on the truck from the factory. :cheers:
Post by 2wagons1driveway » Tue Jun 09, 2015 10:41 pm
I think you made a good choice! I think what comes factory is a 4600? So 5100 should be better lol! Glad your truck rides good again man! Rock on! Time to get some flex pictures!!
Try to imagine pugs living in the wild- just roaming in the forest in packs...
Post by adeluca73 » Tue Jun 09, 2015 11:15 pm
Congrats bro on coming to a decision. Did you get them from Carli or Thuren or direct from Bilstein, & how much per pair? Did you change your bump stops for something that's not visco-elastic rubber?
Like to see a long term review after a year or so!
verdesardog
Post by verdesardog » Wed Jun 10, 2015 10:04 am
verdesardog wrote:I just ordered 4 rancho 9000's $404 minus $106 rebate.
Well no wonder the truck rode like crap. I only changed the front shocks last year. The rancho 9000's make an awesome difference! I only installed the rears since I have bilstiens on the front. I run them on the hard setting on the street and soft for dirt. The old procomp shocks were toast.
Juday
Post by Juday » Thu Jun 11, 2015 7:54 am
adeluca73 wrote:Congrats bro on coming to a decision. Did you get them from Carli or Thuren or direct from Bilstein, & how much per pair? Did you change your bump stops for something that's not visco-elastic rubber?
I purchased them off of Amazon, since one of their operations is about 10 miles from where I work. One day delivery for $6.99, you can't beat that! It was around $350, for all four shocks and the steering damper (minus tax and the small shipping fee). I didn't bother changing the bump stops out, since I didn't change anything but the shocks.
MOPARManiac
Post by MOPARManiac » Wed Mar 30, 2016 12:05 am
Juday wrote:Purchased and installed the Bilstein 5100 series shocks over the weekend.
Just bit the bullet and ordered the same.
Seems to be the best bang for the buck.
How do you like yours after about a year?
PWRider
Post by PWRider » Wed Mar 30, 2016 2:20 pm
I'm sporting 25-187595 5160s front and 24-186636 rears for about 6 months on stock suspension. Very happy so far. 24-066464 fronts collapsed length of 16.34 which is 1.5" or so longer than stock OEM.
Post by adeluca73 » Wed Mar 30, 2016 9:45 pm
I think JUDAY is MIA...
MOPARManiac
Post by MOPARManiac » Wed Mar 30, 2016 9:55 pm
I checked his profile and he last logged on March 18. He'll be around sometime, I'll send him a PM so he should get an email.
MOPARManiac
Post by MOPARManiac » Wed Mar 30, 2016 9:56 pm
PWRider wrote:I'm sporting 25-187595 5160s front and 24-186636 rears for about 6 months on stock suspension. Very happy so far. 24-066464 fronts collapsed length of 16.34 which is 1.5" or so longer than stock OEM.
So is that a good thing regarding the 24-066464 fronts?
I assume so......
Post by olyelr » Wed Mar 30, 2016 10:45 pm
I assume so......
As long as they dont bottom out before the bumpstops hit. Otherwise, no.
MOPARManiac
Post by MOPARManiac » Wed Mar 30, 2016 10:54 pm
No, it is a good thing or No it is a bad thing?
I would assume that they should have increased travel on the flip side.
I was wondering about the bottoming out issue. So should a longer bump stop be used?
