Back on the wagon
Moderator: myoung84
Re: Back on the wagon
Send an email to lockerbypass@outlook.com. More units will be available in 2-3 weeks as I am waiting on materials.wrench04 wrote:How do I get ahold of one of these kits...
I'm slaving away out in the bat cave for you next 25 guys. Yall get ready, as I sure am.
- Stickman
My stock '12 is this, haven't had the chance to install the kit yet, weather is just getting nice enough to consider it with a day off work.
Just got home from trying out the lockers. They engage/disengage ultra fast. 2wd with rear locked does amazing donuts and 4hi locked front and back I was able to climb up hills with 2ft of snow that I tried and failed in 4low. Having the ability to have high wheel spin in 4hi has completely unleashed the beast mode in the truck.
- Stickman
Rtv'd my relays back in earlier, hoping I have this weekend off work so I can install mine. This sounds like I'm missing out now!
Are the kits model year specfic?
If I had a 2012 and a 2015 would the kit work on either truck or DJ I require 2 different kits?
Sent from my iPod touch using Tapatalk
2015 Powerwagon
Locker Mod, 35" Rubber, synthetic rope
To answer my own question they are different rear diff plugs according to CajunPW.
2015 Powerwagon
Is that what is causing both lights to come on?
I've been busy plugging away on the next 25 kits. So far only 15 have confirmed they want one of them. Send a email to lockerbypass@outlook.com to get your name on the list. These should be ready in about 2 weeks. I'll have everything complete by Friday, and then I'm just waiting on the boxes to come in.
- Stickman
Well, I guess I'm gunna have to be the first with a negative "review" with my kit. Had time to install it earlier, took about 4 hours, about 2 or 3 running the wiring and making everything look factory and making sure everything looked good. Then about an hour scratching my head trying to figure out what was wrong.
So I ran all the wiring, left the battery hookup till last to make sure nothing happened, then after I got all the wiring buttoned up I popped open the control box then hooked up the battery, nothing happened, no lights on in the box or anything. So I get in and start up the truck, no locker lights at all. I turn it off, make sure the positive and negative wires on the kits harness are both grounded and getting power, checked all the plugs, still nothing. So I started thinking maybe I used too much RTV or it wasn't letting electricity through the traces on the relay boards. So I start prying them out and scrapping as much off of them as I can. Hook it back up, nothing, so then the only thing left is the T harness that intercepts the factory harness.
I unplug it and look at it and 2 wires are not even close to being plugged into the plug, basically hanging out of the back. So I peel off the little bit of silicone on it and start checking wires, all but 3 of them are loose and I can basically pull them right out the back of the plug. I try to push them back in so they'll clip in but they won't, just keep pulling back out after I stop pushing.
Basically when I'm connecting it to the factory harness it's just pushing the pins away from the kits pins inside the plug and not connecting. So I don't know what else I can try, I tried opening the plug to see what was up but didn't feel like getting mad and breaking the plug making it completely useless.
Any ideas? Here's a couple pics of the box, the back of the boards after I cleaned them and the wires hanging out of the plug.
Not sure how that happened. Can you ship the main harness back to me and I'll correct it or ship you one that's correct.Stickman wrote:Well, I guess I'm gunna have to be the first with a negative "review" with my kit. Had time to install it earlier, took about 4 hours, about 2 or 3 running the wiring and making everything look factory and making sure everything looked good. Then about an hour scratching my head trying to figure out what was wrong.
- Stickman
Man, I guess I can, just gunna suck having to take all that back out after spending so much time running it. How do you open the plug? Are the 2 tabs on the sides of the front of the plug it? I'd like to take a look at it and see if I can fix it without ripping it back out if I can.
Also was your truck running when you tested it? My 13 didn't light up till I stared the truck.
- Stickman
Yea, didn't have lights when running or turned off. I know at least 3 of those wires in that plug weren't even capable of reaching the end of the plug just because they're too short.
Stickman wrote:Yea, didn't have lights when running or turned off. I know at least 3 of those wires in that plug weren't even capable of reaching the end of the plug just because they're too short.
Send me an email with your number and I'll call you tomorrow.
- 2016greyback
Looks like I may have to get one of these by passes soon.
patently waiting to hear when mine kit is ready!
monteholic wrote:patently waiting to hear when mine kit is ready!
What's your name or email address? Just want to make sure I have you on my list.
- 2016greyback
Can I get on the list?
2016greyback wrote:Can I get on the list?
Yes, email lockerbypass@outlook.com with your year model PW
Got a lot done in the bat cave tonight. 25 units will be ready to mail out by Mid to late next week. If you're not already on the list or you haven't confirmed that you're still in via email please do so quickly so you don't miss out on this batch.
4th generation units ready to ship immediately. Send a email to lockerbypass@outlook.com for more info.
