Couple of technical questions from a potential PW owner
azracer
Re: Couple of technical questions from a potential PW owner
Post by azracer » Sun Feb 14, 2016 6:47 am
RustyPW wrote:Crap, the only time I run those air pressures is when I have a load in the bed. Otherwise I run 45 psi front, and 35 psi rear for a great ride. I don't feel like a basketball bouncing down the highway.
I have Toyo AT2s and run 41 front and 34 rear when unloaded. Ride is great! The mileage in not much if any lower with that PSI either. I'm going back to the Yokohama's though as they are about 15# a tire lighter and have better wet road and snow traction. They accelerate faster and get noticeably better in town fuel economy. Load capacity is the same but at a lower tire PSI. Their just not E rated and not nearly as tough.
Snowsled
Post by Snowsled » Sun Feb 14, 2016 11:16 am
I have settled in on 50 front and 45 rear for the stock duratracs. Tire wear is even as long as you rotate every 5k and the ride is pretty good. The warning light is on, sometimes the display flashes at start up but less often now than it used to (everytime) for some reason. They didn't shed mud worth a darn yesterday at that pressure though... I was almost stuck in a flat parking lot with 3-4 inches of spring mud.
loveracing1988
Post by loveracing1988 » Sun Feb 14, 2016 2:46 pm
Reloaderguy wrote:Very true. I'm not sure what the threshold is. I set my tires at 50.5 heated and the computer was ok. When the tires cooled they dropped to 49psi and the messages started. I think the threshold is 50 but you have to air back up into the 60+ range to reset the computer. I have to do more research to be sure. I'm going to have the threshold reset in a couple of weeks.
The thresholds are 20% below whatever your door sticker says the tires should be at. If you guys think your pressures are bad try driving around with the 80 psi that they want in the normal 2500's.
Post by Reloaderguy » Sun Feb 14, 2016 3:08 pm
The door sticker is 60psi front and 65psi rear. Both are grossy over inflated even 20% below max. Based on the max weight rating of the tire, the pressure in my Duratracs should be in the low 40's. I might end up just building a pipe bomb and throwing it under the driver's seat.
Here is a good read from Carli. It is for diesel trucks but the principles apply. Adjust the weight bias and difference in total weight for the gas engine. Interesting that with E and D tires you exceed the GVWR long before you get to the max weight rating. The Poser Wagon only has something like a 1500lb payload capacity before maxing the GVWR which is still more than 1000lb per tire below the max rating of the D rated tire.
http://blog.carlisuspension.com/2015/11 ... ct-my.html
Post by Bill2014 » Sun Feb 14, 2016 4:42 pm
Your pipe bomb isn't going to work with our TPMS wheel sensors - they need to be in motion. Search on this site - this idea has been discussed a few different times here over the years. :lol:
LagunaH1
Post by LagunaH1 » Mon Feb 15, 2016 5:18 pm
Well, I sold my H1 yesterday. Weird how we get attached to our trucks sometimes. I definitely have a bit of the "No truck blues" today
So, anyways: I'm naturally even more so thinking about a nice new PW and have thought about a few things:
The stock PW, as awesome as it is (and that's pretty awesome IMO), seems to have limited breakover and departure angles. The only "cure" I can think of, would be larger tires (35's probably) and possibly a lift.
Anyone here running 35's on the current generation PW? If so, how do you like on-road comfort & handling and off-road capability?
Anyone here running a lift kit on their current generation PW? If so, same questions as above
Thanks all for humoring me and my many many questions :)
2016 RAM 2500 Power Wagon SLT
NR6E
Snowsled
Post by Snowsled » Mon Feb 15, 2016 7:48 pm
You can improve approach and departure with bumpers, less so in the rear but I have never drug the rear bumper. I have however had it high centered.... The truck desperately needs 35's, I think a little level in front and 37s might be the ideal set up.
LagunaH1
Post by LagunaH1 » Mon Feb 15, 2016 8:07 pm
Really good read BTW, thanks for sharing
NR6E
ramv
Post by ramv » Fri Feb 26, 2016 11:35 pm
I had similar feelings toward my '11 1500 Hemi. Completely worthless unless the traction control was disengaged, and t had to be done each time it went into 4wd or 2wd. At one point it was stuck in my drive way (40' long) so I took my avalanche and backed past it, turned around and made fresh tracks with no drama at all. The '11 was the most worthless vehicle I ever had. Good on fuel though.
My wife got a 2012 CTS and it has track settings which make it awesome on snow and ice. I realized computers are ok but the '11 Ram sucked. (as did my '10 Ducati; absolutely worthless). Computers, if programmed liked the CTS can work pretty well.
LagunaH1
Post by LagunaH1 » Sat Feb 27, 2016 1:59 am
Well, tonight I brought home my new ride, a 2016 PW:
First order of business: Get to know all the NAV, phone integration and dash info cluster. Then:
-Install a VHF / UHF HAM Radio
-Find a roll cage / chase rack to install a few lights and for permanent install of antennas.
NR6E
Post by nts007 » Sat Feb 27, 2016 2:45 am
Fantastic dude!!! Not your usual H1 eh lol. Can't wait to see what you do to it in the next while. The bug has bitten. Now everyone here will help you spend your money. It's inevitable.
Post by adeluca73 » Sat Feb 27, 2016 9:40 am
:cash: :cash: :cash:
Welcome
Post by Colibri » Sat Feb 27, 2016 10:47 am
Good looking truck! Welcome aboard officially!
Post by Bill2014 » Sat Feb 27, 2016 11:18 am
Congrats! :cheers:
Now take her out, get her dirty, and have some fun
Post by Reloaderguy » Sat Feb 27, 2016 11:58 am
Congratulations, that truck is rad!
LagunaH1
Post by LagunaH1 » Sat Feb 27, 2016 12:34 pm
Bill2014 wrote:Congrats! :cheers:
It's kinda funny... I think.... the truck was all splashed in mud when I test drove it. They got 95% of it cleaned off by the time I took delivery.
NR6E
Post by Bill2014 » Sat Feb 27, 2016 4:54 pm
Hmmmm Why does my brand new truck have 70 miles on it? :D :D :D
LagunaH1
Post by LagunaH1 » Sat Feb 27, 2016 6:12 pm
Also looks like they forgot to give me the winch controller and the winch hook.
NR6E
Post by Bill2014 » Sat Feb 27, 2016 7:00 pm
LagunaH1 wrote:Also looks like they forgot to give me the winch controller and the winch hook.
Check all of your hidden compartments - that's where those items are as delivered from the factory. All the compartments in the console, the two compartments under the floor in front of the back seats etc...
LagunaH1
Post by LagunaH1 » Sat Feb 27, 2016 7:49 pm
I wonder if there are any places left I haven't checked.....
So far I've looked in the 2 glove boxes in front of the front passenger seat, I have looked in the center console and under the center front seat and I have looked in the in-floor storage in front of the rear seats.
NR6E
Stickman
Post by Stickman » Sat Feb 27, 2016 7:52 pm
Underseat storage in the back? Otherwise I'd be going back to the dealer. Sweet truck, I'm quite fond of the gray.
LagunaH1
Post by LagunaH1 » Sat Feb 27, 2016 7:56 pm
Stickman wrote:Underseat storage in the back? Otherwise I'd be going back to the dealer. Sweet truck, I'm quite fond of the gray.
Yep, checked that too. Most of it is used by the subwoofer for the Alpine sound system which BTW sounds QUITE good :)
NR6E
Post by Bill2014 » Sat Feb 27, 2016 8:00 pm
Storage in the doors and under all the seats - then I'm tapped out...
LagunaH1
Post by LagunaH1 » Sat Feb 27, 2016 8:03 pm
-This all sounds like the perfect excuse for me to go outside and look at my new truck :D
NR6E
Post by Reloaderguy » Sat Feb 27, 2016 8:54 pm
Mine was under the fold flat on the driver's side. I specifically asked for it before I left the dealership though.
