3rd gen u joints
3rd gen u joints
Sorry guys for asking but have done tons of searching and different post and different sights show differnet part numbers. I know spicer changed some part numbers as well I think. Anyways looking for Spicer part numbers to replace and rebuild all joints in front drive shaft and also rear drive shaft. Spicer sealed no lube hds preferably. I have the axle joint number but confusing on the others. Also was going to give 8 lug a call possibly as well but figured you guys might uave them available. 2005 quad pw w one piece rear. Thanks in advance.
Re: 3rd gen u joints
Email George or Tommy at 8Lug Truck Gear. They can help you out. You'll probably have to measure the joints on the double cardan since they seem to be different between trucks.
2011
- GunniPWguy
Check this site out. Lots of oem drivetrain parts
http://quad4x4.com/dodgeAAM925frontAxle.html
This is the information I have gathered over time... I also had a 2005 Power Wagon
Front Driveshaft with AAM 1355 greasable cv
U joint at diff Spicer 5-795x series internal clip comparable to AAM 1344 U-joint AAM Part# 12479126
U Joint CV (2) Spicer 5-3208X series comparable to AAM 1355 U Joint AAM Part# 40085102
CV ball kit can be purchased at Advance
Later Dodge Front driveshafts use AAM 1355 series at all three joints these can be
identified by the external clips.
DO NOT USE SPICER 1330 series joints they may be close but will cuase damage...
Thanks guys. Will be looking to order everything this week along with some Balljoints and most likely a free spin kit. Now to decide dynatrac, oem, carli etc etc on Balljoints and then pick a free spin
- Mr.Smith
You may get a better deal ordering all of it straight from Dynatrac...
Dynatrac
2011
