2015 Pw rim off set
2015 Pw rim off set
Would a 0 offset give you enough clearance for 35x12.5x17 not to rub?
Re: 2015 Pw rim off set
From Thurens site.... https://www.thurenfabrication.com/tech/ ... tment.html
"2013+ 3500 and 2014+ 2500 trucks, with 0-3" lift, fitment.
Stock wheel off-set on 2013+ 3500, and 2014+ 2500 trucks, is right at +57mm. The ideal aftermarket wheel off-set, for the best overall tire clearance, is between +18mm and +25mm. This gives the best balance between keeping the tires from rubbing, on the radius arms, and the fenders. These trucks clear tires stock better than the pre-2013 platform. Most of these trucks come off the lot with tire specs measuring about 34" diameter, so fitting 35's is not even a question.
You can fit 35x12.5 tires on stock wheels with slight rub on the radius arms.
You can fit 37x12.5 on a bone stock truck, on the stock wheels, but the turning radius is reduced quite a bit with radius arm and swaybar rub.
You can fit 37x13.5 on +18mm wheels, you will need to trim the fender liner for sure, and maybe even a bit of the metal rocker seam, but usually full turning with zero radius arm or sway bar rub.
This slight trimming is easy normal stuff we do on the Dodge Ram, to run bigger tires."
